Outside temperature while changing gear oils do you warm up truck a bit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DiscoYaker, Dec 10, 2020.
  1. Dec 10, 2020 at 5:45 PM
    DiscoYaker
    DiscoYaker [OP] Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Question
    Its been around 35°F lately and ment to change fluids during the summer but life happened.
    Do yall usually get the oil a touch warm before changing when its colder out?
    I plan on doing front and rear diff, transfer case and manual transmission fluid change and it'll be close to freezing temps. Not ready for an engine oil change yet. I don't think I've ever changed ANY fluids during chilly weather so I'm just curious what others do.
    My instinct is to just change it as it sits even though it might be a bit cold/thicker
  2. Dec 10, 2020 at 5:51 PM
    Brian_d
    Brian_d Well-Known Member
    Socal
    Up to you - may take a little longer to drain if the fluids are cold. Me personally, I'd drive it a little just to get any sediment up in "suspended animation" before pulling the plug.
    SR-71A likes this.
  3. Dec 10, 2020 at 6:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It would probably help if the fluid was warm.
    I don’t usually make a special effort to get it warm, if it’s not already.
    I usually let it drain for a long time anyways.
    Just be sure to remove the fill plug first.
    That’s more important to me.
  4. Dec 10, 2020 at 6:19 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    It is really up to you.
    The cold oil will drain slow, but it will drain. Just give it time.
    Take a short drive, warm the oil up a bit. It will drain faster.
    A reality check. You will likely spend more time getting the plugs to break loose, especially the front diff drain plug. Have a hammer and cold chisel handy for that one and a replacement plug.
  5. Dec 10, 2020 at 6:20 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Everything except synthetics flow better when things are warm.
    With that said, the little that remains won't make a huge difference.
    DiscoYaker[OP] likes this.
  6. Dec 10, 2020 at 7:03 PM
    DiscoYaker
    SE USA and Alaska
    Thanks for the input @Brian_d @TnShooter @Knute
    Thats interesting, never heard that before
  7. Dec 10, 2020 at 8:19 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Both conventional and synthetic base automotive engine oil become less viscous with temperature.
    The viscosity of synthetic base oils are typically more stable over temperature ranges than conventional base oils are, but the viscosity of both has an inverse relationship with temperature (i.e. both flow better when hotter).
  8. Dec 10, 2020 at 8:47 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Depending on how you're getting at the t-case, you'll probably be getting close to the exhaust and a cat, I'd be leery of driving too far and getting that all too warm.
    On the other hand, it might make a nice little radiant heater when you're under there ;)
  9. Dec 10, 2020 at 10:12 PM
    DiscoYaker
    SE USA and Alaska
    Thanks for the heads-up
    I think I'll get the gears moving a bit but not to much and start with rear diff and move my way forwards
    Appreciate the input everyone
  10. Dec 11, 2020 at 4:48 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Won’t make any real difference honestly.
  11. Dec 11, 2020 at 11:25 AM
    SaratogaTaco
    SaratogaTaco Well-Known Member
    I usually do once around the block to stir up any crap sitting on the bottom before draining. It probably doesn’t matter but I seems like a good idea.
  12. Dec 11, 2020 at 12:29 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Just drive around for a little bit,then do the change.
