outside termperature
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michigantacoowner, Jan 31, 2010.
  1. Jan 31, 2010 at 2:22 PM
    michigantacoowner
    michigantacoowner [OP] Member
    SouthEast Michigan
    2010 DC 4 x 4
    Jason truck cap trailer two brake Excalibur remote car starter
    My 2010 DC does not have the outside temperature in the cab. Has anyone seen an aftermarket way to add an outside temperature guage?
  2. Jan 31, 2010 at 2:26 PM
    MNTaco
    MNTaco Newbee
    Twin Cities, MN
    2010 DoubleCab TRD Sport Long-Bed
    Bet mat, bug shield, running boards, tonneau cover
    When I purchased my 2008 Camry SE, I purchased an auto-dimming mirror through the dealer that had temp and direction on the bottom of it. My 2010 Tacoma TRD Sport DoubleCab Long-Bed came with the separate temp/direction, but maybe the mirror is the way to go. I want to say it was under $200 installed by the dealer. I'm sure others on the forum can give you a better mod, though.
  3. Jan 31, 2010 at 2:31 PM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    15 DCSB TRD Sport 4x4 - Pyrite Mica
    FWIW, the thermometers that come with certain packages on these trucks seem to give "warm" readings. Not surprising since it's on a "warm" object that emits radiation...
  4. Jan 31, 2010 at 3:23 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    i added a $10 accurite wireless indoor/outdoor thermometer from WalMart. I painted the plastic (its white) flat black using testors model paint. Then velcro'd it right under the climate controls. The sending unit is velcro'd inside one of the plastic cubbies in the bed. It works great! Also to see it at night, I added a #4.99 bendable small light that plugs into the cig lighter. It also was at Walmart. Will post a pic tomorrow. This has been a nice inexpensive mod to get the outside temp & inside temps for me.
  5. Jan 31, 2010 at 3:34 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Are you suggesting the 3 degree reading i saw this morning driving to my job was more like 0 degrees?
    That would explain why my pens kept freezing out there...
  6. Jan 31, 2010 at 3:38 PM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    Well... I'm just saying that mine seems to read about 5-10 degrees higher than actuality. I'm a meteorologist, and I'm kind of a geek when it comes to stuff like this, so one of the first things I did when I got my truck was checked to see how accurate my thermometer was :D
    Yesterday it was 17F when I left work, and my truck read 24F the whole way home.
    It's no big deal to most, I'm sure...
  7. Jan 31, 2010 at 4:25 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    x2,done it in 18 wheelers before.works great.
  8. Jan 31, 2010 at 4:29 PM
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    Very interested and watching. :popcorn: I need a Compass and Thermometer.
  9. Jan 31, 2010 at 4:32 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  10. Jan 31, 2010 at 4:34 PM
    FishErTaco
    FishErTaco Well-Known Member
    Chapel Hill, NC
    10 DoubleCab 4x4 SR5
    Extang Trifecta tonneau, black textured N-Fabs, AFE Pro Dry S, WeatherTech vent visors, WeatherTech floormats
  11. Jan 31, 2010 at 4:37 PM
    Jason'sLawnCare
    You could also get something that reads off the obdII port like kiwi wifi and get the intake temp which is close to the outside temp.
    Or duck tape a meat thermometer to your bumper and check it.
  12. Jan 31, 2010 at 5:40 PM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    Sounds like a cool mod cant wait to see the pics. :thumbsup:
  13. Jan 31, 2010 at 5:59 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
  14. Jan 31, 2010 at 9:58 PM
    automoto
    automoto Well-Known Member
    jersey shore
    07 SR5 4X4 AC
    :laugh:
  15. Feb 1, 2010 at 7:07 AM
    RL_Engineer
    RL_Engineer Member
    Warner Robins, Georgia
    Updated to Pioneer sound system
    Compass/Temp Display Install
    Yes it can be done. However it requires some modification of the existing overhead console.
    I went to Toyota and purchased the meter assy only. It is part number 83290-04011. I think it was $125. I then removed the overhead console and took off the door for the garage door placement. I took a dremel tool and put a notch on the front half and another on the rear half. The cable is already there to accomodate the module. You do not have to buy the temperature probe that fits in front of the radiator as it is already there. It is just a matter of fitting the meter assy in the hole left by removing the garage opener door.
    The new compass/temp indicator has improved the the wattage of the 510 resistors that plagued the 2005-2008 tacoma owners. The meter assembly comes with the plastic cover over the display and it looks quite nice once installed. Works good too.
    http://members.cox.net/mangoldd1/100_0028.jpg
  16. Feb 1, 2010 at 7:17 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    I bought a AAA powered, wired unit from Wally World, velcroed the display (which has a push-button back light) just above the vent on the driver's side of the cab. I ran the probe under the door seal, along under side of hood lip, down and put it on the backside of the grille (attached by 3M HVB tape). Works great on a cold vehicle, or when running about about 25MPH.....but when stopped for a light, engine compartment heat will cause it to rise.....but it will drop back down when you move again.
    I think I paid $7.95 for it. I've found it very useful.
    Here's what I installed:
  17. Feb 1, 2010 at 10:25 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    Here is my inexpensive temp/compass mod, tho Mark C.'s setup looks pretty cool too.
    No issues all winter and does the trick for those w/o factory unit & cost under $20 for everything including compass & light.
    The temp display unit comes white so I painted it to blend in better with the interior.
    Daytime pic
    Night time with adjustable light (3 settings, off/blue/white light)
    Compass though the OP did not ask for this ....this little guy works!
  18. Feb 1, 2010 at 12:23 PM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Nice job with the thermometer! I have GOT to get a digital camera! Sheesh!
  19. Mar 29, 2016 at 7:57 AM
    jim1234
    jim1234 Active Member
    jim
    pocatello Id.
    2009 tacoma 4 cyl base
    intermitent wiper review mirror Cruise control 4cyl manuel 09
    YES ON THE DUCT TAPE,,,,,,,,,,everyone knows "DUCT TAPE ftw"
  20. Mar 29, 2016 at 7:59 AM
    jim1234
    jim
    pocatello Id.
    Your link doesnt work,,,,,I NEED PIC, I want to do this.
