outside windshield condensation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalake09, Sep 29, 2016.
  1. Sep 29, 2016 at 12:20 PM
    tacomalake09
    tacomalake09 [OP] New Member
    james
    09 silver tacoma
    I have noticed this summer that I am having a small amount of air come out of my defroster when I have my air conditioning on. I have the air positioned on my panel Vents and floor but still there is a small amount of air coming out of my defroster and on very humid days I get a lot of condensation forming on my outside windshield is it common for an 09 Tacoma to have air blowing out my defroster when the setting is on the floor and panel vents
  2. Sep 29, 2016 at 12:29 PM
    Pigpen
    Dan
    Northwest Montana
    It's common for the little door that controls where the air flows from to break.
    greeneggsnspam likes this.
  3. Sep 29, 2016 at 12:39 PM
    tacomalake09
    james
    09 silver tacoma
    thanks 58 siesta I assumed there was some type of door system that directs the airflow I am sure this is where the problem lies after your confirmation
  4. Sep 29, 2016 at 1:29 PM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    If you notice that condensation is forming on your windshield near the bottom, turn off the air re-circulation. That should fix your problem...
  5. Sep 29, 2016 at 1:55 PM
    tacomalake09
    james
    09 silver tacoma
    so are you saying not to recirculate indoor air but to bring air in from the outside
  6. Sep 29, 2016 at 2:05 PM
    Zac of all trades
    Zac
    fwpfab.com
    Correct! Many people experience condensation when running the defogger, in high humidity like dallas of late, the windshield will not get condensation if you do not re circulate the air inside the cab. I have tried it, and it works.
