Outter wheel seal not seating right on hub
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoNH, Aug 15, 2012.
  1. Aug 15, 2012 at 4:58 PM
    TacoNH
    TacoNH [OP] Well-Known Member
    Nü Hampshire
    07 Blue Tacoma 4.0/6speed
    887s, 5100s, Light Racing UCAs, Nitto 285s, Leer Cap.
    I am in the process of replacing my drivers side front wheel bearing and hub assembly, however when trying to dry fit the pieces together my outter wheel seal does not seem to seal on hub, it's almost an big in ID. Is this a classical case of wrong part? My old wheel bearing and seals are FUBAR so comparing comparing parts is a no go.
    The parts i ordered from rockauto are
    Outter wheel seal #710477
    Inner wheel seal #710573
    Thanks
  2. Aug 15, 2012 at 6:55 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    the outer seal( seal in between bearing and hub) should fit tight onto the outer bearing cage rim. It needs to be tapped on it fits so tight.
  3. Aug 17, 2012 at 3:25 PM
    TacoNH
    Nü Hampshire
    Thanks. Does anyone know if these are the correct parts
