OV Tune Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDitalia, Sep 13, 2020.
  1. Sep 13, 2020 at 8:28 AM
    TRDitalia
    TRDitalia [OP] Active Member
    2020 TRD Sport DCSB
    Can anyone help me decipher the differences in the latest OV tune? I just got the tune today and there are a few things i'm not sure about.
    I take it Premium and Reg are just referring to the gas type, 33 and 35 is tire size, 4.88 and 5.29 are gear ratios, the only thing i'm not sure about is what "Thx" is referring to?
    Also what are the benefits of running the premium tune?
    Thanks for any help with this.
  2. Sep 13, 2020 at 8:38 AM
    BrettsMac08
    BrettsMac08 Well-Known Member
    Kansas
    2016 DCSB TRD Sport | 2002 Camaro SS
    KDMax Tuned | MagnaFlow Exhaust | OEM Audio Plus Reference 450Q | TRD Pro Wheels | AT Tires | LED Interior Lighting
    From their 2.0 Final release page:
    I ran both and ended up liking the stock one better than THX but it's just a personal preference. Normally I'd go for enhanced throttle but it behaved strangely on my individual truck (04B04).
    I'm running 04B04 (2016) Prem Stock 33" (265/70/17 in my case) and love it. The 91 vs 87 difference is power. 91 octane can make more HP/TQ than on 87 but even on 87 all the tunes benefits are present other than a peak power increase. Torque curve is still improved with any octane level. It may not be very noticeable but I run 91 simply because it's offering the most benefits.
    And they are OLE (Octane LEarning) so if you swap gas it will eventually tune itself to what's in the tank but the files set the starting point for whatever you have in it or plan to run. Flash 87 then fill up with 91 and it'll eventually run the 91 tune, flash 91 and run 87 and it'll run poorly for a while but eventually tune down to 87 from what I've heard, though I think the range was more OLE for 87-89 and 91-93 but I'd expect it would go outside of that range and still be fine.
    TRDitalia[OP] likes this.
  3. Sep 13, 2020 at 8:40 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All 2.0 tunes are octane learning. Reg and Prem are just the ignition starting points.
  4. Sep 13, 2020 at 9:03 AM
    TRDitalia
    2020 TRD Sport DCSB
    Awesome, thanks for the break down!
  5. Sep 13, 2020 at 10:35 AM
    Shellshock
    Iowa
  6. Sep 13, 2020 at 11:11 AM
    Xer0 SiN
    Xer0 SiN Well-Known Member
    Hilo, HI
    19 TRD SPORT TACOMA / 21 LIMITED RAV4
    this and that...
    pulled this from another thread.
    "OVTune said:
    Even though the premium octane tune *can* degrade ignition for regular octane gas, it has to move the amount of ignition further than it would if you were running the regular tune, which means higher initial detonation readings.
    if you plane to use regular grade gas you should not use the premium tune.
    regular > learning zoned 85 to 89 octane
    premium > learning zoned 90 to 94 octane.
    Using less than 90 octane will significantly degrade performance."
    TRDitalia[OP] and Junkhead like this.
  7. Sep 14, 2020 at 3:36 PM
    Venum
    Venum New Member
    Is there a set of instructions on how to upgrade from a 1.5 tune file to 2.0? I have the flash kit (cable) and can't figure out how to reflash based on the instructions in the above link. Any help? Thx!!
  8. Sep 15, 2020 at 7:53 PM
    TRDitalia
    2020 TRD Sport DCSB
  9. Sep 15, 2020 at 9:31 PM
    Venum
    Venum New Member
    Thank you very much. I was finally able to get it installed!!
    wrightme43 likes this.
