Oven temp issue....
Discussion in 'Food Talk' started by chris4x4, Jan 23, 2012.
  1. Jan 23, 2012 at 7:52 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How can I verify the temp my oven is opperating at when set to a certain setting? Can I turn it on, set it at 300* (for example), then once it stops heating, use an IR thermometer to see if its right?
  2. Jan 23, 2012 at 7:54 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    yes actually.
  3. Jan 23, 2012 at 7:56 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    An oven thermometer might be more accurate. The IR would likely register the surface temp of whatever you are aiming at.
    Wait...Why the F are you using the oven? Does Julie know about this?
  4. Jan 23, 2012 at 7:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cool. Now wheres a good spot to aim the IR thermo at? The back?
  5. Jan 23, 2012 at 7:57 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    That is correct. If you turn it to 300F and it doesn't stop at 300F and goes all the way to 500F+ you have what's called a "run away thermostat". All you need to replace the oven temperature switch - very easy job to do. Hit me up if you need more help, I have fixed countless stoves, fridges, dishwashers, etc...
  6. Jan 23, 2012 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ever since she blew up pork chops in the oven, shit has come out burned after cooking. I dont know if these things get calibrated, or whatever, but Im wondering if the temp sensor is knocked out of spec.
  7. Jan 23, 2012 at 7:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    i hate this fucking oven. I want nothing more than to yank it out of my house, and drop it from an airplane.
  8. Jan 23, 2012 at 7:59 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    what kind of wood are you cooking now?
  9. Jan 23, 2012 at 7:59 AM
    05RedTaco
    Tony
    Scottsdale
    Taking it to a desert and shooting rounds through it works too :eek:
  10. Jan 23, 2012 at 7:59 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    Yes, or get an oven thermometer from a kitchen store (or maybe even Walmart or the likes) they are rated to about 500 degrees and built to stay in the oven
  11. Jan 23, 2012 at 8:00 AM
    JDMcQ
    Neither of you should be allowed in the kitchen.
  12. Jan 23, 2012 at 8:01 AM
    jgwheeler17
    NC
    neglect, mostly.
    that would be my first place, yeah. i work in food production and we obviously have kick ass internal thermometers on a relay that control the burners, but when we shoot the IR in an oven its always close.
    i will say pine wood is not a great way to test it though :D
  13. Jan 23, 2012 at 8:02 AM
    05RedTaco
    Tony
    Scottsdale
    The IR will be off +/- 15F or so...
  14. Jan 23, 2012 at 8:02 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :laugh:
  15. Jan 23, 2012 at 8:03 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Maybe the thermostat just needs cleaning. Look for a metal probe at the top back of the oven.
  16. Jan 23, 2012 at 8:04 AM
    jgwheeler17
    NC
    neglect, mostly.
    well if he's aiming for 300 (no pun intended) and 290-320 shows up, it would be definitive enough to prove it's not too screwed up.
  17. Jan 23, 2012 at 8:04 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    There should be a thermocouple somewhere inside the oven. I would check and see if is not damaged. If the oven is convection, the thermocouple is located by the fan outlet. Aim your IR at the thermocouple and the will tell you if they coincide.
  18. Jan 23, 2012 at 8:04 AM
    JDMcQ
    Gas oven? Put your head in there and give it a look.
    :popcorn:
    Deebs on the boat
  19. Jan 23, 2012 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :mad:
    yeah.....I dont want to waste my ammo on it :(
    I dont have any money to get one....Are they easy to shop lift?
    SHUT IT!
    Ok......Ive taken a few reading, 1 at the back about halfway up, 1 reading from the grate thing that goes accross the over....its silver.....looks like a grill.....So far, I have come up with the following temps:
    300* is actually 346* at the back, and 376* on the silver grate thing
    400* is actually 436* at the back, and 441* on the silver grill thing......
  20. Jan 23, 2012 at 8:05 AM
    jgwheeler17
    NC
    neglect, mostly.
    :rofl:
    :popcorn:
