Oven temp issue....
Discussion in 'Food Talk' started by chris4x4, Jan 23, 2012.
  1. Jan 23, 2012 at 8:05 AM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    Exactly my point :)
  2. Jan 23, 2012 at 8:07 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Good idea. WHere is it/what does it look like?
    Our oven has a heating element on the top and bottom. Seems only the bottom one gets hot.
  3. Jan 23, 2012 at 8:07 AM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    You can aim it anywhere I'd imagine. The thermostat should stop the call for heat when it is uo to temp so aim it at the probe if you can see it, otherwise anywhere shoukd be fine
  4. Jan 23, 2012 at 8:07 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    fuck....the oven is hot now.....Im gonna try to find the probe
  5. Jan 23, 2012 at 8:08 AM
    05RedTaco
    Tony
    Scottsdale
    That's within margin of error with IR. You can TRY cleaning the thermocoupler, or get an oven thermometer to verify your temp or get a new oven switch... The oven switch can range from $40 to $200 depending on oven and depending if you have an account with appliance parts place.
  6. Jan 23, 2012 at 8:09 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    hmmmmm. . . think it would be somewhat off then. check the thermocupler as an above poster said, or maybe do a test with something in your home that makes a reaction at 300 degrees.
  7. Jan 23, 2012 at 8:09 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    IR would be the wrong tool. IR would be better for a contact cooking method.
    buy a $5 oven thermometer. leave it in there. adjust oven thermostat according to what the inside thermometer is telling you.
  8. Jan 23, 2012 at 8:10 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    That's what I said! Nobody ever listens to me!
  9. Jan 23, 2012 at 8:10 AM
    aficianado
    back to bone stock.
    i dont trust the tickmarks on my fridge and freezer either. put thermometer in there too.
  10. Jan 23, 2012 at 8:11 AM
    jgwheeler17
    NC
    neglect, mostly.
    thats an obvious fix. you have to take your bare hand and place it on the bottom one for 3-5 seconds and observe the burn. maybe record audio and or video of your reaction for us to analyze. then using your other hand repeat the process on the top element and compare burns/screams/tears, etc.
  11. Jan 23, 2012 at 8:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    My thermo is accurate to 2% up to 500*, so Im thinking the readings I got are pointing to the oven being a peice of shit.
  12. Jan 23, 2012 at 8:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    i hate you
  13. Jan 23, 2012 at 8:13 AM
    jgwheeler17
    NC
    neglect, mostly.
    im just trying help chris :pout:
  14. Jan 23, 2012 at 8:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alright. Did another run up to 300*
    300* on the dial, and I got 353* on the temp probe in the oven.
  15. Jan 23, 2012 at 8:13 AM
    #35
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:.......:eek:
  16. Jan 23, 2012 at 8:18 AM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    ok....400* is 428* on the probe.....that could be within margin of error of thermo.
  17. Jan 23, 2012 at 8:19 AM
    #37
    jgwheeler17
    NC
    neglect, mostly.
    see but that's where your issue comes back even if you were to put something in there to cook. when something is cooking it is always "fighting the heat" per se. water is always evaporating/cooking the item so you can't really expect the temperature of your baked item to be the same temperature you are cooking at unitl its past cooked and starting to burn. does that make any sense to any one but me? your read on lets say, a cookie, probably wont be 350 degrees ever cause once that cookie ever actually gets to 350 it will probably be burnt to shit. the easiest, cheapest way to test would be to let it preheat to set temperature and then cook something (a pan of cookies from a roll really would be ideal) and see if they "turn out right" by following the instructions. :cool:
  18. Jan 23, 2012 at 8:19 AM
    #38
    rcbs204
    rcbs204 Well-Known Member Vendor
    yes definitely, unless your stove is a viking, or sub-zero.
  19. Jan 23, 2012 at 8:20 AM
    #39
    jgwheeler17
    NC
    neglect, mostly.
    then obviously mail us the cookies for further testing :)
  20. Jan 23, 2012 at 8:21 AM
    #40
    JDMcQ
    The upper burner, generally, only comes on during preheating and broiling. the lower burner only is used to maintain temperature during baking,
