Oven temp issue....
Discussion in 'Food Talk' started by chris4x4, Jan 23, 2012.
  1. Jan 23, 2012 at 8:33 AM
    #61
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm surprised the oven in still functional after that.
  2. Jan 23, 2012 at 8:34 AM
    #62
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Are you serious or trying to get me killed?
  3. Jan 23, 2012 at 8:35 AM
    #63
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Try cleaning it with oven cleaner now that you know what it is.
  4. Jan 23, 2012 at 8:36 AM
    #64
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Does this oven have a cleaning cycle?
  5. Jan 23, 2012 at 8:37 AM
    #65
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    :notsure:
  6. Jan 23, 2012 at 8:37 AM
    #66
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, thats how I got all the tree sap out of it.
  7. Jan 23, 2012 at 8:38 AM
    #67
    Fightnfire
    Marysville, WA
    You got the sap out, did you forget the tree?
  8. Jan 23, 2012 at 8:39 AM
    #68
    jgwheeler17
    NC
    neglect, mostly.
    though in all seriousness, baking oil might cause it to flash burn if it gets too hot. . . so maybe don't do that. i am just using the mental reference in my head of calibrating fryers by using the temperature of the oil im heating up.
  9. Jan 23, 2012 at 8:41 AM
    #69
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Jan 23, 2012 at 8:42 AM
    #70
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Umm...Open the door to look?
  11. Jan 23, 2012 at 8:42 AM
    #71
    Fightnfire
    Marysville, WA
    I think this could all be solved with a cheap oven thermometer. Set the oven to 400, put the thermometer in and check it when it says it's preheated. Set the timer for 5 minutes and check again, rinse and repeat a few times.
    At 400 the oven should go from 385 to 415, it could spike after you open the door to re-heat to 400.
    Remember ovens don't have low power or re-heat power, it's all or nothing. That's why you don't want to open the door all the time. Every time the oven kicks on to bring the temperature back up it can exceed by 15 degrees. If your baking cookies for 15 minutes and open the door 2 or 3 times you could really be baking those cookies 20+ degrees hotter than intended.
  12. Jan 23, 2012 at 8:43 AM
    #72
    JDMcQ
    You're welcome, BTW.
  13. Jan 23, 2012 at 8:45 AM
    #73
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah....I guess Im gonna have to break down and get a dam oven temp thing....
    you could have told me the door was gonna lock on me :cool:
  14. Jan 23, 2012 at 8:46 AM
    #74
    JDMcQ
    picky picky
  15. Jan 23, 2012 at 8:48 AM
    #75
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not picky at all. I thought I was locked out and it was gonna go meltdown on me. AND YOU never told me to get the shit away from the top of the fucking thing......
  16. Jan 23, 2012 at 9:09 AM
    #76
    4Wheelin4Banger
    Randy
    Try cleaning that.
  17. Jan 23, 2012 at 9:10 AM
    #77
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. Any idea with what?
  18. Jan 23, 2012 at 9:19 AM
    #78
    4Wheelin4Banger
    Randy
    Oven cleaner, green scratchie, comet.
    No blow torch, flamethrower, gasoline or other flammable substance.
  19. Jan 23, 2012 at 9:21 AM
    #79
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Got it. Would steel wool work too, or is that too harsh?
  20. Jan 23, 2012 at 9:23 AM
    #80
    4Wheelin4Banger
    Randy
    Lightly with a fine grade should be OK.
