Over $1900 in maintenance at 35k miles??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by victory357, Jun 27, 2023.
  1. Jun 28, 2023 at 6:16 AM
    #41
    Tacoma Mike
    Southern Maine
    No Sir
    1997TacomaSR5[QUOTED] and MQQSE like this.
  2. Jun 28, 2023 at 6:26 AM
    #42
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Ive seen where the service writer would say “ your battery only checked out at 60% and should be replaced” “ winter is coming and you don’t want to be stranded” that will cost $350.
    Typically… this was told ONLY to the Female customers. I was glad to see many declined.
    Ive worked flat rate as a mechanic and would say the probability this was done by the service writer as part of their incentive training.
    As others state, find a trusted local shop and or learn how to do the work yourself.
    Barsoom, MQQSE and DetroitDarin like this.
  3. Jun 28, 2023 at 6:30 AM
    #43
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Replace ATF and differential fluids at 50K. Power steering fluid is easy to do with the turkey baster. Do it at 50K-ish. Difference between new and old power steering fluid was most noticeable at low temps.
    Replace brake fluid at 80K. I've lost a vacuum booster due to corrosion from old brake fluid, so I change it at 80K and then at 160K, use top of the line Bosch fluid.
  4. Jun 28, 2023 at 6:30 AM
    #44
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    To be fair, they didn't say the pads were unusable. They just said the outer ones were wearing faster than the inner ones.
    But I'd definitely seek a second opinion.
  5. Jun 28, 2023 at 6:36 AM
    #45
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Back in the day when I raced mx for an area yamaha dealer, they pushed a bg additive for anything with wheels. BG has decent products, but it was crazy how many bikes they serviced with some sort of bg product in it.
    1997TacomaSR5[QUOTED] likes this.
  6. Jun 28, 2023 at 6:41 AM
    #46
    Commocean
    Commocean Well-Known Member
    St. Petersburg, FL
    2023 Tacoma SR5 DCSB 2.7L Ice Cap
    It's like the pool store. I have my own test kit that I paid quite a bit of money for. Every now and then, I'll take a sample up to the pool store for the heck of it. Every single time they tell me I need $100+ worth of chemicals to correct some sort of imbalance.
    Barsoom and MQQSE like this.
  7. Jun 28, 2023 at 7:19 AM
    #47
    DetroitDarin
    DetroitDarin Specified
    York County PA
    Scratches and Whatnot
    It's like going to the Psychiatrist. I have my own grain-based or potato-based coping mechanisms, but when I show up they wanna sell me $100 worth of chemicals to correct some sort of "imbalance". :)
  8. Jun 28, 2023 at 7:24 AM
    #48
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    You spelled $1000 wrong.
  9. Jun 28, 2023 at 7:27 AM
    #49
    DetroitDarin
    York County PA
  10. Jun 28, 2023 at 7:32 AM
    #50
    Cement_wheels
    No dis to OP for changing subject, but what is BG? Been doing auto/truck/MC work for a loooong time and I've never heard of it.
    Sdswingr likes this.
  11. Jun 28, 2023 at 9:59 AM
    #51
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    You just need to find a better (more honest) shop,,, the truck is fine. There is a decent upfront cost for proper maintenance,,, none of which the stuff you listed is.
    This quote is so far off base, I am questioning if there is even a point in discussing with them.
    DetroitDarin likes this.
  12. Jun 28, 2023 at 10:04 AM
    #52
    jdmfreak1992
    jdmfreak1992 Well-Known Member
    Taylor
    2017 Tacoma TRD Off-Road
    Stock for now
    Tell them you don't appreciate being taken advantage of and to have your truck ready for pick up as you will be taking your business elsewhere. I hate scum bag dealers. Also, side note OP brake jobs are super easy on these trucks I would do it yourself if you feel comfortable and have the time to do it.
  13. Jun 28, 2023 at 10:16 AM
    #53
    raw2136
    raw2136 My Pro-Nouns are Dude/Bro
    2018 Gray Tacoma SR Access Cab
    Rear Speakers, Intermittent Wipers, Side Step tubes, Wheels & Tires, Towing Hitch & Harness
    I was in the business for 30 years. This is a common practice of offering "Fluid Exchange" services at dealerships and independent shops. I would start with the owners manual, and then adjust accordingly based on your own driving habits. For example if you do a lot of towing, perhaps a transmission service before the owners manual recommends would be appropriate. What they are offering sounds quite excessive. Try and find a good reputable independent shop. I would go to the dealership and have them show you the brake pads. I also always ask for the dealership to return my old parts within reason so I can inspect them.
    Barsoom and Chew like this.
  14. Jun 28, 2023 at 10:17 AM
    #54
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That's the way I do it. I haven't spent $1900 total in maintenance on my nearly 17 year old truck with 238,000 miles on it.
    MQQSE, 1997TacomaSR5 and DetroitDarin like this.
  15. Jun 28, 2023 at 10:19 AM
    #55
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Did they mention the timing cover leak or rear coolant pipe,of course that's under warranty.
  16. Jun 28, 2023 at 10:29 AM
    #56
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Dealership rates are high I agree.
    I will also say that keeping fluids fresh/in good condition can help make the components they are used in last longer.
    I have always been on board with changing brake fluid, p.s. fluid etc. Just do it yourself or find a trusted shop so you dont pay as much.
    The pads weren't unsafe, just wearing uneven. If the calipers/pads cant slide back to center easily this will happen so I would be cleaning and addressing that
  17. Jun 28, 2023 at 12:36 PM
    #57
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Ahhhhhhhhhh the old dealer digital finger exam. Are you mechanically inclined ? Pop off the front wheels and take a peek at the pads. If indeed they are wearing noticeably different from each other. Get some brake cleaner and some silicone brake pin grease and disassemble clean and re-grease the caliper pins. Basically a 6 of Heineken job. Fug Da Dealer
  18. Jun 28, 2023 at 1:24 PM
    #58
    Chucky1953
    Chucky1953 Active Member
    2018 TRD Off-Road
    Pro-Grille
    I have a totally awesome wrencher I bring my truck too. Last year I went though that stuff with my dealer when they were doing a small warranty thing for me. Told my mechanic, he chuckled and I politely called them back and declined. Turns out I didn't need even 1/3 of what they said..............They much be trained to say this shit.
  19. Jun 28, 2023 at 2:42 PM
    #59
    Starman2112
    Starman2112 Well-Known Member
    2018 SR5 AC 4X4 Blazing Blue Pearl
    LMAO. What a ripoff!
    MQQSE likes this.
  20. Jun 28, 2023 at 5:06 PM
    #60
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Simple answer: Your truck doesn't really need anything at 35,000 miles except maybe an oil and filter change. If they mess with anything else: like the brake fluid flush (!), the power steering flush(!) MAS (!!!!???) the chances are high that they'll introduce new problems it didn't have when it went in. As for the brakes: take it to another place for a second opinion and never go back there. They'll be out of business soon anyway.
    I might do the diffs if I was running the Baja or Rubicon while towing a huge boat at high speed up a hill.... but I doubt it.... and definitely not at that place.
