over head console switches group buy
Discussion in 'Automotive Group Buys' started by 3378jakesr5, Dec 14, 2015.
  1. Dec 14, 2015 at 11:46 AM
    3378jakesr5
    3378jakesr5 [OP] AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    I am starting a group buy on these over head consoles with switches I have been making.
    I'm starting this now due to the talk on the other threads on here and trying to get it all in one spot. I was not ready for the response on these, but I will post more pictures of the overhead consoles and the wiring as I get them done.image.jpg
    Here is some pictures of the wiring. The one with the plug would be normal wiring if you only had on off for all of the switches. The two white switch backs and power lines are for the heated seats switches and yes they will fit down the pillar. I will post more on the install.
    Per @ramonortiz55 yes I can do this for 4runners as well
    I am using 16 gauge wire for the ones pre-wired and do not recommend over 10 amps on the switch unless it is used with a relay. I am not responsible for your ability of wiring or the over loading of a switch and wire if you do so. I am also not responsible for any shorts or failures of the system if you do the wiring incorrectly or used it other then its rated capacity. I am not responsible if you brake the console trying to remove the switch panel from the console.
    There will be a $50.00 non-refundable fee for some materials and to know you are serious about purchasing one on these before you are added to the main list.
    Consoles will be finished and paint to match as close as possible to stock will be used to cover the console.
    When the consoles are finished and ready to ship, I will request the rest of the payment in full before they will be shipped.
    The buyer pays for all shipping charges.
    I will only be working on these at my free time away from school and my welding. So I wanted to let you know that it can take up to 3 weeks from when I get the console to when I am done (in most cases it will take less but would rather tell you longer just in case)
    It will require you to ship me your console to be done. If you want a stock one for replacement you can look on threads here or on ebay to find them.
    Consoles can be retrofitted to hold a scan gauge, round temp or air pressure gauges along with switches. Please ask about a configuration to see if it will fit.
    Option one
    The console will be changed to hold 6 contura switches and will be provided with the panel to hold the switches. The panel will be taken out due to how hard it is to get back out to do wiring and if it is removed too many times there is a possibility that the fiber glass will remove where the clips hit.
    Option two
    All the parts included in option one along with otrattw switches with rockers of your choice in the location of your choice, the console will be pre-wired for the switches and will have enough wire to get you down the A pillar and into the engine bay.
    Option three
    Every thing included in options one and two, along with the addition of a blue seas 6 position fuse block and a hella 4 position relay block. They will be wired for you and only needing fuses to work and wiring from your battery to the block. They will come free floating and you will need to find homes for them in your engine bay. I can supply 4 gauge wire for the the positive power and 4 or 8 gauge wire for the ground if requested but there will be an additional charge of $5.00 for the copper crimp and $2.00 per foot of wire needed, you will need to tell me the length of wire needed to be supplied.
    Here is where the switches will be coming from and where you can make your selections for switches.
    https://otrattw.net/home.php
    prices.
    Option one $250.00
    Option two $400$
    Option three $525$
    Thank you everyone for your interest in these and I hope your as pleased with them as I am.
    CowboyTaco and kbraunphoto like this.
  2. Dec 14, 2015 at 11:47 AM
    3378jakesr5
    jake
    littleton colorado
    HAVVOKK likes this.
  3. Dec 14, 2015 at 11:49 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
  4. Dec 14, 2015 at 11:56 AM
    3378jakesr5
    jake
    littleton colorado
    i got one does that count? if you didnt go big mouthing i would have had time to finish it and have more but nooooooo..... so i had to start it early so you can blab here.. now i know why @ramonortiz55 always tells you to leave a thread :D
    Rattletrap66[QUOTED] likes this.
  5. Dec 14, 2015 at 11:58 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  6. Dec 14, 2015 at 11:59 AM
    ramonortiz55
    Ramon
    Texas
    stock
  7. Dec 14, 2015 at 11:59 AM
    3378jakesr5
    jake
    littleton colorado
    Yes I forgot to say that I just need one of your guys console to do so.
  8. Dec 14, 2015 at 12:00 PM
    ramonortiz55
    Ramon
    Texas
    stock
    id put that in the OP in red bold letters lol
  9. Dec 14, 2015 at 12:01 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :rofl: If anything I should get a kickback for referring everyone from @dakotasyota 's thread!
  10. Dec 14, 2015 at 12:01 PM
    3378jakesr5
    jake
    littleton colorado
    I can do a kick In the back? Does that work?
  11. Dec 14, 2015 at 12:02 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Okay guys. I have been working close with @3378jakesr5 for a setup on my 2001 4runner and 2015 tacoma.
    I should be getting the tacoma one here soon. I will provide a detailed review and installation thread on this with lots and lots of pictures :D
    Rattletrap66 likes this.
  12. Dec 14, 2015 at 12:02 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    also, clean it up with some proper grammar. Just CAPS and what not
  13. Dec 14, 2015 at 12:03 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :smack:
  14. Dec 14, 2015 at 12:03 PM
    3378jakesr5
    jake
    littleton colorado
    If you ever ship them out to me.
  15. Dec 14, 2015 at 12:04 PM
    ramonortiz55
    Ramon
    Texas
    stock
    crap. okay. lol
  16. Dec 14, 2015 at 12:56 PM
    Russtoy
    Russtoy Well-Known Member
    Russel
    Ohio
    2000 4Runner SR5
    I think I'll be in on this! Really excited to see the pictures!! This is Awesome!!
    3378jakesr5[OP] likes this.
  17. Dec 14, 2015 at 12:57 PM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  18. Dec 14, 2015 at 12:58 PM
    ramonortiz55
    Ramon
    Texas
    stock
  19. Dec 14, 2015 at 1:05 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Would you be able to make one of these with a solid face instead of open for a switch panel? I really like these overhead panels but I'm looking to custom install my scan gauge in one rather than switches.
  20. Dec 14, 2015 at 1:08 PM
    3378jakesr5
    jake
    littleton colorado
    I can leave it uncut for you or I can make it where the scan gauge sits centered and have a switch on either side too as an option.
