Over heatedphones
Discussion in '4th Gen. Tacomas (2024+)' started by porterx, Jul 7, 2025.
  1. Jul 7, 2025 at 10:08 AM
    porterx
    porterx [OP] Well-Known Member
    Lately, I've been getting the message that Google Maps can't display 3D buildings because the phone is too hot. Huh? I've got the phone on a magsafe disc on top of the built in charger so it's not lying flat, it is stood off by the thickness of the disc. I may have to figure out a way to vent the A/C over the phone.
  2. Jul 7, 2025 at 10:37 AM
    Chupacabraz
    Chupacabraz Well-Known Member
    2025 SR5 Tacoma 4x4
    Or a short USB-C cable and charge it that way. Should keep the temps down. I find the wireless charging is OK for short times. Phone gets warm on our CRV too when using charging pad, although I've never had it shut down due to heat. Mine came with an $80 accessory bag of some charging cables, maybe you got that to and can find one in there that will work? :D
    porterx[OP] likes this.
  3. Jul 7, 2025 at 11:05 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Do you need 3D buildings? Turn it off problem solved. If it's a customer with this issue tell them they're an idiot and figure out how to get around with out a phone. This is the dumb stuff that Consumer Reports gets complaints on and scores the Tacoma low on initial quality.
    SR-71A and b_r_o like this.
  4. Jul 7, 2025 at 11:09 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Sounds like it's a problem with your phone, not the truck.
    Do you have an Android or iPhone? What model is it?
    What other software are you running that may be causing the processor and graphics to be running generating heat in addition to the heat caused by charging?
    Are you using CarPlay/Android auto? Is the phone screen on? Full brightness?
    So many questions and in the end, it's an issue with your phone, not the truck.
    porterx[OP], JB_TN and batacoma like this.
  5. Jul 7, 2025 at 11:23 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I agree. Makes it more confusing when you posted that CR "article" last week and talked about how "these articles are helpful because it gives you input about other people's experiences with the new truck"
    I wasn't arguing with you about posting the article. I was trying to argue that the quality or value of the input was pretty useless. .. seems like most of the complaints against the new model are made by people that can't even read the owner's manual
    SR-71A and batacoma[QUOTED] like this.
  6. Jul 7, 2025 at 11:29 AM
    CultivatingMass
    CultivatingMass Well-Known Member
    2024 SR5 DCSB
    TRD Front skid, softopper, Prinsu rack, GMRS & CB
    Wireless charging creates more resistance (heat) when charging because it’s not a wired connection. When your phone heats up, the processor in your phone heats up. When that happens it has to “underclock” the processor so the processor doesn’t overheat and blow up.
    When it has to limit the amount of processing power it’s capable of producing, you lose features - in your case 3D rendering - until the temperature cools down.
    I’m sure someone smarter than me could explain this much better but that’s the gist.
  7. Jul 7, 2025 at 11:31 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you have a case on the heating problem compounds too
  8. Jul 7, 2025 at 11:34 AM
    CultivatingMass
    2024 SR5 DCSB
    That’s good point as well.
    Basically OP, phones don’t have any active cooling measures. It’s like opening 1,000 tabs in google chrome and turning your computer fans off and then trying to play GTA V. Something’s gotta give.
    SpencerTacoSC likes this.
  9. Jul 7, 2025 at 12:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    The whole wireless charging thing just seems a little weird to me. Like how is that not showering the entire cabin with radiation?
    I know BT and wifi emit radiation too but the energy required to physically charge the battery without a wired connection has to have some side effects.
    The phone is getting hot.. lord knows what's happening to your testicles :anonymous:
    Is it really that much trouble to hook up a cord? Seems like a solution in search of a problem. I don't get it
  10. Jul 7, 2025 at 12:23 PM
    timetoeatpotatoes
    timetoeatpotatoes Well-Known Member
    2024 Bronze Oxide Trailhunter
    Not hooking up a wire is more convenient than hooking up a wire. I've also had USB ports go bad long before the rest of the phone did. wireless charging is just electromagnets; nothing scary there.
  11. Jul 7, 2025 at 12:23 PM
    CultivatingMass
    2024 SR5 DCSB
    You bring up a valid point. I don’t think we have a full understanding of the way Bluetooth Wi-Fi and cellular effect cells when they radiate. Wireless charging bleeds EMF radiation and I’m not sure we know how much, how strong, and what effect it has on us long term.
    Likely it will be like plastic 2.0. use a thing for 30 years and then realize it’s bad. We’reall guinea pigs in that sense
  12. Jul 7, 2025 at 12:29 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Gotta die of something
  13. Jul 7, 2025 at 12:35 PM
    Speedytech7
    Maybe look up the difference between ionizing and non-ionizing radiation before y'all start getting preventative cancer screenings and tinfoil hats.
    JasonLee, WhakoDog, Delta09 and 3 others like this.
  14. Jul 7, 2025 at 12:42 PM
    Thegreatgretz
    Thegreatgretz Well-Known Member
    New England
    1992 hilux blue & rust; 2011 OR AC silver; 2025 OR LB terra
    Please don't spread baseless theories intended to create fear. People have a tendency to believe nonsense without verifying it.
    Radiation is just transfer of energy. Ionizing radiation is the end of the spectrum which has obvious dramatic health effects. X rays, gamma rays etc. Moving down the power scale of the electromagnetic spectrum you pass visible light before getting to the gigahertz/10^9 Hz (wifi, bluetooth) range.
    Any time there is current, a magnetic field is induced. Wireless charging uses the opposite principle. Create a magnetic field and induce current to charge. In terms of the amount of power needed, perhaps half again more power is needed for wireless charging than for corded, for reasons I don't know. But if you're usually charging at 20W, maybe 30W is used in wireless charging. Many TVs use 200W.
    So if you're worried about radiation from wireless charging causing you any health effect, don't let visible light anywhere near you ever because it's closer on the spectrum to ionizing radiation. And don't have an electric TV, refrigerator or computer because they all use much more power and create more of this "radiation" you fear.
  15. Jul 7, 2025 at 12:44 PM
    CultivatingMass
    2024 SR5 DCSB
    First off, mine is made of aluminum foil. And secondly, it’s a custom handmade piece. Jealously is a sin sir.
    Speedytech7[QUOTED] and Delta09 like this.
  16. Jul 7, 2025 at 12:45 PM
    CultivatingMass
    2024 SR5 DCSB
    Never thought I would get a science lesson on radiation on TW.
    Thank you sir.
    I told you guys someone more smarter than I would chime in!
    Speedytech7 likes this.
  17. Jul 7, 2025 at 12:46 PM
    CultivatingMass
    2024 SR5 DCSB
    Cigars and coffee my friend
  18. Jul 7, 2025 at 12:48 PM
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Currently drinking a Gin and Tonic. Looks like I’m going for cirrhosis of the liver.
  19. Jul 7, 2025 at 12:48 PM
    timetoeatpotatoes
    fun fact: all USB chargers function wirelessly and all of them use electromagnetic induction. The only difference is "wired" USB chargers use electromagnetic induction in the 120 to 12v step down transformer in the wall wort itself rather than using electromagnetic induction to get the energy into your phone. Functions exactly the same.
    SpencerTacoSC and Speedytech7 like this.
  20. Jul 7, 2025 at 12:52 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    @Thegreatgretz
    my guy, I'm not posting with the intent to "create fear" or "spread baseless theories". I'm just chatting, calm the fuck down
    Yes I'm obviously uniformed about this stuff but that doesn't mean I have nefarious intent.
    If you're that upset I'll delete the post geez
