over heating and 4-L problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by fireturk41, Nov 12, 2010.
  1. Nov 12, 2010 at 5:48 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    okay first off my trucks overheating after i changed the coolant, i put in toyota red coolant, 2 gals of it, the radiator and resivour are full, the heater isnt blowing hot, but the water temp is getting up to 125*F
    also when i put it in 4L the AT/P light comes on, i just replaced the damn transmission and the old one had the same problem
  2. Nov 12, 2010 at 6:03 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Um, did you mean 225*F?
    Maybe you have air in the system?
    No idea with the tranny.
  3. Nov 12, 2010 at 6:16 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    update...i think it was air...im slowly getting heat back but its still not hot, although the truck now stays at 195*F much better than 225*
    also any input for the 4lo problem?
  4. Nov 12, 2010 at 7:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    There was a thread a while back that discussed the AT/P lite. IIRC the purpose of the light is to tell you the 4WD lever is in Nuetral. :confused: Doesn't make sense to me either.
    On your rig, it may be a position sensor thing. :notsure:
  5. Nov 12, 2010 at 7:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
  6. Nov 12, 2010 at 7:22 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    thanks! maybe soon i can get my new d-shaft and tires to put it into 4wd
  7. Nov 12, 2010 at 7:43 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    exactly what i did. i kept filling the resevoir tank and let it run with out the cap on to bleed out the air
  8. Nov 12, 2010 at 7:59 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I hope I don't screw up by asking this but-did you stick with the 50/50 mix of water and coolant I hope? or did you put straight red coolant?
  9. Nov 12, 2010 at 8:00 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    straight coolant, it was pre mixed and said not to add water
  10. Nov 12, 2010 at 8:01 PM
    Ridgerunner
    Frank
    San Francisco
    OK I just wanted to make sure it was mixed.
  11. Nov 12, 2010 at 9:12 PM
    pittim
    pittim mittip backwards
    Pink slider.
    go on an incline and rev your engine.
