over heating issue... possibly a head gasket?
Discussion in 'Technical Chat' started by RickSavage, May 16, 2013.
  1. May 16, 2013 at 10:15 PM
    RickSavage
    RickSavage [OP] raised in north plains
    Rick
    north plain
    92 toyota pickup 3.0 v6
    no mods... yet!
    so I have a over heating issue with my 92 3.0 and I haven't been able to figure out why.
    Whats been done:
    changed thermostat
    checked for plugged radiatior
    plugged coolant circulation
    and none of that has changed it. itll overheat and blow coolant out the overflow after about 2 miles and say its overheated but the block will barely be warm to the touch. iv had people tell me that it might be a cracked head gasket that's allowing pressure to get into the cooling system and over pressurize and then over heat. I know the head gasket isn't "blown" because it has no symptoms in the oil or exhaust. any help would be MUCH appreciated. this is my first Toyota so im kinda learning as I go.
  2. May 18, 2013 at 7:56 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Does sound quite similar to a head gasket since it blows out coolant so fast. Most parts stores have a tool loan/rental system and they usually have what looks like a turkey baster which is used to check for and measure combustion gasses in the coolant. If the tester shows a positive indication, then the highest probability is a head gasket.
  3. May 19, 2013 at 3:23 AM
    RickSavage
    Rick
    north plain
    no mods... yet!
    This is true, what about a water pump? And would the tool still get a reading if I JUST put in new collant?
  4. May 19, 2013 at 3:53 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Yes the test would pick up the presents of exhaust gasses in the new coolant. You could also pull the spark plugs, a very white deposit indicates coolant getting into the cylinder as does a sweet smell to the exhaust.
    My guess is the coolant circulation is impeded, water pump impellers dissolved/eroded, collapsing or blocked lower radiator hose.
