Over heating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by literallynothing, Sep 14, 2018.
  1. Sep 18, 2018 at 5:43 PM
    #61
    literallynothing
    literallynothing [OP] I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
  2. Sep 18, 2018 at 5:44 PM
    #62
    literallynothing
    Noah
    2017 DCSB
    Steel and 37s
  3. Sep 18, 2018 at 6:16 PM
    #63
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Maybe it's a flow issue. Higher rpms when's downshifting means faster spinning water pump :confused:. Pretty sure the truck cuts fuel when downshifting. So the air pumping through the cylinders is probably having a cooling effect
  4. Sep 19, 2018 at 12:15 PM
    #64
    literallynothing
    Noah
    2017 DCSB
    Steel and 37s
    A friend of mine with a heep has been having the same issues since the trail, jeep just called him to let him know that his thermostat was sticking. Looks like I'll likely be dropping the truck at toyota on Friday
  5. Sep 19, 2018 at 1:14 PM
    #65
    Kremtok
    Kremtok Well-Known Member
    Gary
    Houston, TX
    2021 Tesla Model 3 Long Range AWD
    2018 Triumph Street Triple RS
    What’s a thermostat cost? Can you just replace it yourself and see if it fixes the problem? Dealerships are expensive, but it might be powertrain warranty if that’s the case.
  6. Sep 19, 2018 at 4:03 PM
    #66
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Thermostat is probably cheap. Getting to it is a different story.
  7. Sep 19, 2018 at 4:50 PM
    #67
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    My wife's Camry had an over heating issue that took me hours to figure out. I checked all the sensors, all the fuse's, switches and replaced the thermostat and hoses while at it. I checked to see if the water pump was working and took the New thermostat out to see what would happen and guess what, the new thermostat even though was opening in a pot of boiling water did not work. In the end I replaced the thermostat again and problem solved.$.02
  8. Sep 19, 2018 at 5:40 PM
    #68
    literallynothing
    Noah
    2017 DCSB
    Steel and 37s
    Jeep just got back to my friend and informed him the thermostat was not the problem, they are now testing his head gasket. If my issue is anything along the lines of his, I feel that my 100k mile powertrain warranty should cover it
  9. Sep 19, 2018 at 5:41 PM
    #69
    literallynothing
    Noah
    2017 DCSB
    Steel and 37s
    So a brand new toyota thermostat wasn't working?
  10. Sep 19, 2018 at 7:03 PM
    #70
    Kremtok
    Gary
    Houston, TX
    That’s a fair point.
  11. Sep 19, 2018 at 9:20 PM
    #71
    Halena Molokai
    No, I even boiled a pot of water and place it in it and watched it slowly open. I don't know what fully opened looked like but it sure was not enough to flow the coolant fast enough. I would have never thought it could be a new thermostat but that was all that was left too do so i took a chance since it only cost a few dollars.
  12. Sep 19, 2018 at 9:52 PM
    #72
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Pull your dipstick. See if it's milky / foamy.
    Jh8473 likes this.
  13. Sep 19, 2018 at 9:54 PM
    #73
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I once changed a thermostat, just for maintenance, not because it was broken. So I curiously decided to put a little butane torch on it just to confirm it was still working. Well I got side tracked installing the new one and the thing blew up in the garage :rofl:. Copper and wax everywhere haha.
  14. Sep 19, 2018 at 10:45 PM
    #74
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I had a 2 year old truck with overheating problems. Turned out the radiator needed a flush. Never found out what clogged it or how.
  15. Sep 19, 2018 at 11:13 PM
    #75
    Kremtok
    Gary
    Houston, TX
    That's exactly the answer that OP needs to be dreading since he's taking it to the dealership, because that's a maintenance procedure not a warranty repair. Since he's already tried it, there shouldn't be much to worry about, though.
  16. Sep 19, 2018 at 11:33 PM
    #76
    bagleboy
    Scott
    Norcal, Santa Rosa
    Beats a blown motor which how mine ended. Before the "clogged radiator" diagnosis the mechanic just slapped on a higher pressure cap to prevent boil overs. That "worked" but didn't lower the temp and when all was said and done it needed a new motor, new radiator, and new heater core since the motor got cooked and like our tacos had plastic tanks on the radiator and heater core which weren't designed for the higher pressure.
    Whatever it is, fix it soon and fix it right. Don't drive it running hot.
  17. Sep 19, 2018 at 11:57 PM
    #77
    PeeDeeTaco
    PeeDeeTaco Custom Title
    Effingham, SC
    2017 TRD Off Road 4x4 DCSB Blazing Blue Pearl
    5100 + OME 888 + Headstrong AAL SOS Offroad Concepts Streamline Winch Bumper Smittybilt XRC 9500 winch Method Race Wheels MR308 Roost Falken Wildpeak AT3W Image Dynamics speakers/sub Tacotunes Amp and sub enclosure
    Why would a powertrain warranty cover damage to a head gasket caused by overheating due to operator negligence?
    daddy_o likes this.
  18. Sep 20, 2018 at 12:10 AM
    #78
    Kremtok
    Gary
    Houston, TX
    Negligence means failure to exercise due care. Not sure what you see that I don’t, but looks like our guy here has not crossed that line.
  19. Sep 20, 2018 at 12:14 AM
    #79
    PeeDeeTaco
    Effingham, SC
    daddy_o and EdgeCrusher like this.
  20. Sep 20, 2018 at 5:01 AM
    #80
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Yeah soon as he did more than spray it down with a hose. Taking it apart to "fix the issue" and not being able to doesn't mean its on Toyota to sort out now for free. Sucks for OP and I get the DYI mentality but it might come back to haunt him here.
