Over heating
Discussion in '1st Gen. Tacomas (1995-2004)' started by AKTacoma, Jun 9, 2010.
  1. Jun 9, 2010 at 10:31 PM
    AKTacoma
    AKTacoma [OP] Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    I recently had my head gasket and head replaced due to an overheat a long time ago, and today my truck started to get hot just 2 days after the job was done. I saw my temp gauge move up and down a little at first, then after sitting in traffic for a little, the gauge stayed up almost in the red. When i got home and shut the truck down before it got into the red, my overflow was boiling. So i figured that it may possibly by a thermostat. I changed that and it seemed to be working fine so far, but I talked to the guy who did my head gasket job and he said that if when the motor is hot and running, you shouldn't be able to stop the fan blade. Stupid i know, what can I say, most mechanics would do the same, but given that I stopped the fan blade with my hand while the truck is running hot, and then spinning with little resistance when shut off and still hot, does this mean a fan clutch change??
  2. Jun 10, 2010 at 3:29 AM
    ScottyB
    ScottyB Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Sounds like a weak fan clutch. That's some amazing advice though. Sounds like a good way to tell someone how to get their fingers torn up. I've also had heating problems with a car due to a clogged up radiator that wasn't passing water through a large chunk of it. Not sure what the previous owner was putting in it to get it that clogged up though.
  3. Jun 10, 2010 at 8:57 AM
    Yamasaki
    Yamasaki Yamaha + Kawasaki!
    Denver, CO
    2003 Tacoma Limited TRD 4x4
    I'm not trying to thread jack here but did not want to start a new topic about a similar discussion.
    Where is everyones temp guage sitting at? Mine looks like the following and sometimes creeps just a slight bit higher but never into the red. Its pretty consistent and does not bounce around.
    My 4Runner that had the same design guages always had me in the lower 1/3. I am just wondering if this is normal. Thanks!
  4. Jun 10, 2010 at 9:00 AM
    Coolidge
    Coolidge Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    My last 2 Tacos (04/03) both were exactly as pictured above.
  5. Jun 10, 2010 at 9:37 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That could be my gauge. Pretty much stays right there most of the time. The only exception is when I'm on the trail, in 4lo, going up hill for an extended stretch of time. In those situations the gauge will go up a small amount.
  6. Jun 10, 2010 at 12:58 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    my gauge always heats up to that exact point, the other weekend i towed a trailer up 6000 feet to go camping, total weight of the trailer and extra cargo was around 3000 pounds, temp gauge never moved even when i was climbing hard, good taco :)
  7. Jun 10, 2010 at 1:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Sounds like fan clutch.
    Also, if you get a scangauge, you can monitor the temp exactly. Mine stays beteween 191 and 195.
  8. Jun 10, 2010 at 5:34 PM
    AKTacoma
    Houma, Louisiana
    08 Tacoma DCLB
    well I replaced the thermostat, radiator cap and fan clutch, and everything ops checks great!
