over inflated tires.
Discussion in 'Wheels & Tires' started by tacomalimited, Apr 9, 2013.
  1. Apr 9, 2013 at 6:43 PM
    tacomalimited
    tacomalimited [OP] Well-Known Member
    Northern NJ
    2013 tacoma limited double cab long bed 4x4.
    I got a nail in my tire and needed to have it patched. the guy that patched it said all my tires were over inflated by 10lbs, so he set the pressure in all my tires.I don't know how they could of been over inflated I got it brand new in January and never touched my tires until now. shouldn't the dealer have picked up on this before letting me drive off the day I bought it?:confused:
  2. Apr 9, 2013 at 6:56 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What are they set at now?
  3. Apr 9, 2013 at 6:58 PM
    tacomalimited
    Northern NJ
    I think 30lbs
  4. Apr 9, 2013 at 7:01 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    What kind of tires and what load rating?
  5. Apr 9, 2013 at 7:01 PM
    Pugga
    Massachusetts
    F-150 Mod
    Well, that's about what they should be set at... so yeah, sounds like the dealership didn't check it when it left the lot or the other shop is exaggerating.
  6. Apr 9, 2013 at 7:01 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Your truck gon' blow up.
  7. Apr 9, 2013 at 7:01 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    possibly warming up in your area can cause the pressure to go up because the air expands with warmer temps
  8. Apr 9, 2013 at 7:03 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    In CA, idk about other states, all the auto shops have to check tire pressure and most cars are aired over i think it gives the false "Good MPG"
  9. Apr 9, 2013 at 7:06 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2000 SR5 TRD 4x4 Ext Cab V6 Manual
    30psi? Dang that seems low...
  10. Apr 9, 2013 at 7:17 PM
    OffroadToy
    4X4 Offroad
    If they're the p rated stock tires check the door jam sticker for the best psi. I've got light truck e rated tires and 40 psi is even too much for them (with no load.)
  11. Apr 9, 2013 at 7:20 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    The dealership routinely overinflates mine to 40psi. I have to tell them specifically the proper PSI (26 front, 29 rear) even though it is plainly printed on the sticker in the doorjamb...
  12. Apr 9, 2013 at 9:58 PM
    Buckoma
    Buckeye, AZ
    WTF that seems insanely low.
    Seems to me it would depend more on the specific tires being used and user preference rather than what's on a door jamb anyway.
  13. Apr 10, 2013 at 2:53 AM
    tacomalimited
    Northern NJ
    there Bridgestone Duellers on 18" rims, stock.
  14. Apr 10, 2013 at 5:01 AM
    Pugga
    Massachusetts
    F-150 Mod
    That's way too low and backwards. For an unloaded truck, you want the front higher than the rear. 30 - 32 on the front and 28 - 30 in the rear for an unloaded Tacoma on stock tires works pretty well.
    I also tell the dealership not to touch anything besides what the truck is there for.
  15. Apr 10, 2013 at 5:06 AM
    169.254.255.201 Well-Known Member
    Interwebs
    Do you have the tires that came with the truck? Because it took a few times for the techs to realize I had different tires so they couldn't go by the door sticker.
