Over maintenance 30k service
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VaToy, Dec 14, 2023.
  1. Dec 14, 2023 at 3:03 AM
    VaToy
    VaToy [OP] Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My 2018 DCLB Sport 4wd just had a lot of maintenance completed over the past two days by a dear friend who is a retired master Toyota/Lexus Mechanic. He inspected everything and found no issues. I'm on 5100s, 285s, KDMAX tuned, nicely modded with OEM Pro grill, skid,TRD exhaust and CAI. So I'm almost to 30k miles and had the serpentine belt replaced, spark plugs, fuel ejection service, a/c service, power steering flush, transmission fluid changed, front and rear diffs, transfer case, brake fluid and radiator flushed. The throttle body and MAF sensor cleaned and I'm sure I'm forgetting something. All OEM fluids and parts. The oil was changed, I use the OEM paper filter as opposed to the TRD KN filter, cabin air filter, everything torqued to spec. I know this was an overkill but its a piece of mind for me just knowing I'm good for a while. I was there and learned a few things, now my Wife's 2018 4Runner is next. I can tell a little difference as it may run smoother thanks to the plugs which I seriously doubt would not make it 60k miles. The plugs looked good but the mechanic said they needed replacing soon. He has taken care of our 99 4Runner since it was new as well and its almost to 300k miles. I'm sharing this as you may want to check your plugs as they may need changing earler than expected and may not be torqued to spec. I had three plugs that were loose but causing no issues other than being dirty. Thought this nay help someone out.
  2. Dec 14, 2023 at 3:27 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Wow, you did a bunch of stuff there brother! I doubt you really needed a new belt and I bet your spark plugs were fine. But there is no harm in knocking all that stuff out early for thar "peace" of mind you seek. Good job!
    Junkhead, Chew, BMH and 2 others like this.
  3. Dec 14, 2023 at 3:36 AM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    I maintenance all of my cars this way so you’re not crazy. It’s awesome when your 200,000 mile car runs as good as new and gives you the peace of mind that you can get in your vehicle and literally drive across the country at any given moment. After 50k I do a drain and fill on my transmission fluid annually.
    Road_Warrior likes this.
  4. Dec 14, 2023 at 4:14 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    It's nice to take care of your truck but the spark plugs would absolutely last 60k.
    RIX TUX, Junkhead and Chew like this.
  5. Dec 14, 2023 at 4:17 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Your technician said u needed sparks plugs replaced at 30k ? Unless u had some bad parts no way the plugs needing replacement under 30k .
    RIX TUX, Junkhead, abodyjoe and 3 others like this.
  6. Dec 14, 2023 at 4:23 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Iridium plugs are good for 100k. Hell, I used to drive regular plugs for 80k.
    Someone is full of something, I'd say.
    RIX TUX, Road_Warrior and Chew like this.
  7. Dec 14, 2023 at 4:31 AM
    BlackCat81
    2023 Ice Cap TRD OR
    the factory recommended interval for plugs on the 3.5 Tacoma is 60k.
    soundman98 likes this.
  8. Dec 14, 2023 at 4:43 AM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    I tend to lean towards the earlier mileage intervals on consumables. I only put 8-9k per year on my vehicles, 3 Toyota’s, and I feel time breaks down the fluids as does mileage. That all being said, I need to flush the power steering on the Camry and 4R. Those are the only ones I’ve inadvertently skipped.
  9. Dec 14, 2023 at 4:43 AM
    VaToy
    Parts Unknown
    Three loose plugs, didn't look too bad but he said they would be okay but not past 60k. He was just checking them, found some loose and recommended to change them now.
    22Coma6MT likes this.
  10. Dec 14, 2023 at 4:52 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is a commonly used phrase saying that "maintenance is cheap insurance". That isn't true, maintenance is expensive and that is where all car dealerships make their profits. If you do all of the maintenance SUGGESTED in the owner's manual, and if you take it to the dealer for the work you will end up spending more on maintenance than you paid for the truck. I emphasized the work SUGGESTED because much of those items only need to be INSPECTED. Only replaced if necessary.
    Your plugs and belt are good for 100,000 miles. I'm at 243,000 and mine have been replaced twice. Will do them again at 300,000. I still have the factory hoses and coolant. The rotors and drums are still factory although I will need new rotors on the next brake job. The rear brake pads have only been replaced once. Other than that, the only parts that didn't come from the factory 17 years ago are the struts, shocks, and alternator.
    I change the oil every 10,000 miles or 6 months whichever comes 1st but have never changed transmission fluid in any vehicle I've owned over the last 50 years. Never seen any evidence that it prolongs transmission life, and you can easily spend more on servicing the transmission over the life of the truck than it will cost to just have a new one installed. And they die at about the same time regardless.
    I'd not have 2nd thoughts about taking mine on a cross country road trip tomorrow. It's done it several times.
    marc1, ricco333, StayinStock and 2 others like this.
  11. Dec 14, 2023 at 5:05 AM
    Dark_Taco
    2023 TRD Pro
    Stock
    I agree the 2nd gens were better. I should have kept my 08!
  12. Dec 14, 2023 at 5:12 AM
    golfindia
    Yes.
    pickup truck
    Ok. But 30k is half of 60k.
    RIX TUX likes this.
  13. Dec 14, 2023 at 5:24 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    And 60K is early.
    Just because it is written doesn't make it so..
    My brother pulled his 3rg gen plugs for the first time @120K and you wouldn't have known them from 15K.
  14. Dec 14, 2023 at 5:28 AM
    Buck Henry
    With modern computer controlled ignition, I agree. There really is no gain (other than this nebulous "peace of mind" everyone always references) in swapping them out early or even at 60K.
    jmneill[QUOTED] likes this.
  15. Dec 14, 2023 at 5:36 AM
    golfindia
    Yes.
    pickup truck
    nope, it's a waste.
    https://www.tacomaworld.com/posts/26027199/
  16. Dec 14, 2023 at 9:59 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Very true and often overlooked or ignored!
    You can make any vehicle last forever,,, the service and parts departments will let you,,,, trust me!
    Maintenance is great, I am believer no doubt! But, you can overdo it too.
    Rock Lobster likes this.
  17. Dec 14, 2023 at 10:13 AM
    jmneill
    SE
    Yep.
    Just dropped the transmission pan on my 5th gen 4runner @120K to replace the filter screen and get 5 new quarts of oil in there, only to find the the screen was immaculate. Waste of $100 bucks on the filter and pan gasket, and of course, my time.
    Piece of mind? - I guess, but it didn't do anything for the truck.
    Drain and fills for me from here on out.
    Chew[QUOTED] likes this.
  18. Dec 14, 2023 at 10:23 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    With 3rd gen, there's a bit of labor involved accessing the plugs on the driver's side, so if you're paying someone to do the job, might as well put new plugs in there (vs. torquing the old ones down), though you're still spending ~$100 on just the part costs for the plugs.
    b_r_o likes this.
  19. Dec 14, 2023 at 10:26 AM
    SmoothTRD
    SmoothTRD Well-Known Member
    Way overkill
  20. Dec 14, 2023 at 10:26 AM
    MGMDesertTaco
    Seems like loose spark plugs are just as prevalent as low transmission fluid on 3rd gens. o_O
    3JOH22A likes this.
