Over revved engine, need new motor
Discussion in 'Technical Chat' started by Tmigratorius, Mar 29, 2015.
  1. Mar 29, 2015 at 9:06 PM
    Tmigratorius
    Tmigratorius [OP] New Member
    Fairbanks, AK
    '12 TRD
    Hi there,
    sad post...
    Friend was doing donuts on ice and apparently over revved the engine. Had a deep knock, prognosis was a bent rod :(
    I'm looking for the best motor replacement source, anyone done this before?
    I'm doing the taking out and putting in, I was going to get it rebuilt locally (Fairbanks AK, rebuild is beyond my skill) but the shops here don't offer nationally recognized warranties, and I'm leaving in a couple months.
    2012 v6 4.0L TRD, 60000 miles. I want something with less than 75K, and comes with some sort of warranty, if thats possible.
    Thoughts?
  2. Mar 29, 2015 at 9:27 PM
    BamaToy1997
    Bill
    Navarre, FL
  3. Mar 29, 2015 at 9:32 PM
    Tmigratorius
    Fairbanks, AK
    '12 TRD
  4. Mar 29, 2015 at 9:58 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    Ex-friend...?
  5. Mar 29, 2015 at 10:03 PM
    Tmigratorius
    Fairbanks, AK
    '12 TRD
    I wish, here's what she sounds like
    http://youtu.be/BvxakkiXsrA
    I asked three mechanics and they all said the same thing.
  6. Mar 29, 2015 at 10:37 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Ahhh, that just gives me chills.
  7. Mar 30, 2015 at 5:06 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I loaned a buddy my car way back in HS to go to lunch. Came out to go home and he had thrown a rod. Not happy, aaannnndd said it didn't sound that way when he brought it back. Remained friends but I knew, and I learned a valuable lesson.
    Even with a fuel shut off it is possible to over rev the engine a bit. You floor it on a ice and it spools up pretty fast and overshoots the limit. Also there's the old mechanical over rev when you down shift at too high a speed for that gear, and the engine winds out as you let the clutch out too fast. BOOM.
    Sorry man.
  8. Apr 5, 2015 at 9:45 PM
    BamaToy1997
    Bill
    Navarre, FL
    I would check with the mechanics and get quotes for tearing into the engine and seeing what needs to be replaced. Sometimes a new bearing set and a polished or new crankshaft will fix the issue, and cost a LOT less that replacing the entire engine.
  9. Apr 6, 2015 at 12:14 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    The hell they using in Alaska ?
    Peanut oil. ?
    I am with Bamatoy. Check first whats wrong before dropping all the money on new engine.
    Those engines are not easy to kill unless you help them a bit.
