Overall best suspension options for my tacoma?
Discussion in 'Suspension' started by calhoun, Oct 28, 2010.
  1. Oct 28, 2010 at 1:58 PM
    calhoun
    calhoun [OP] Well-Known Member
    JJ
    Polk County, Tn
    2014 Sport 4x4
    Im new to the tacomas and recently just purchased a 2006 prerunner. Im wanting to run a 265 all terrain tire but not sure wat my best options are. The truck wouldnt be in to much off road stuff just old dirt hunting trails mostly. Any one able to help on what my best bet for ride comfort and good shocks and the best tire for street and just dirt trails? any help is appreciated. Thanks
  2. Oct 28, 2010 at 2:00 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Are you looking to lift at all?
  3. Oct 28, 2010 at 2:00 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Spindles with adjustable coilovers such as king, box, or icon
    x2 cause for 265's you dont need a lift
  4. Oct 28, 2010 at 2:01 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I would say an OE after market progressive coilover. Like King, SAW or fox.
  5. Oct 28, 2010 at 6:54 PM
    calhoun
    JJ
    Polk County, Tn
    2014 Sport 4x4
    Not really worried about lift. The truck has 245 on it now but im wanting to put a 265 when these wear down. Didnt know what i would have to do to keep from rubbing i would rather change shocks than trim anything. It still has the mud flaps and i will probably leave them on it. All i really wanna do is run a 265 all terrain without rubbing when turning. And again thanks for the help guys. not real smart on the suspension side of the trucks
  6. Oct 28, 2010 at 8:27 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    265/70R16 is a tire available from the factory and will fit without any problems for you.
    Many run a 32" 265/75R16 tire without problems, but others have to remove their mudflaps.
    All you have to do is spend a little time looking around the boards for folks who've had problems as a result of lifting their trucks. VSC (1 in 5) Vibrations (more than half) rough ride (no counting for sure as its very subjective.)
    If you don't "need" to lift your truck, don't do it. If you're sure that's what you want, do your homework.
  7. Oct 28, 2010 at 8:38 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I say if your looking for more of a stock set up...I'd get some Billy 5100s set @ 1.85 and get some decent A/Ts like BFG All Terrains :)
  8. Oct 28, 2010 at 8:52 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Morty
    Outer Space
    Long travel
  9. Oct 28, 2010 at 9:46 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    before anybody can help we need to know your budget.
  10. Oct 31, 2010 at 9:31 AM
    calhoun
    JJ
    Polk County, Tn
    2014 Sport 4x4
    Dont really have one this is something that will be done over time. Im gonna buy the stuff i need over time then do all the work all at one time. im not wanting to spend a ridicolous amount on it though. Its an everday driver besides on the weekends during hunting season and then its only on dirt trails with small mudholes if any at all.
  11. Oct 31, 2010 at 9:33 AM
    calhoun
    JJ
    Polk County, Tn
    2014 Sport 4x4
    so with the 5100s set at 1.85 you can run a 265 bfg all terrain? and anyone know where to find the best deal on the 5100s?
  12. Oct 31, 2010 at 9:55 AM
    ktmrider
    Junk
    you can run a 265 all terrian with stock wheels without a lift at all
  13. Oct 31, 2010 at 7:14 PM
    calhoun
    JJ
    Polk County, Tn
    2014 Sport 4x4
    i wont have to worry about any rubbing?
  14. Oct 31, 2010 at 7:21 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    If all you're wanting to do is run 265s and use it as a deer-hauler, just leave it stock. There's really no point in risking lift side-effects if you don't need the clearance.
    At most you'll have to remove your mudflaps. That's it.
