Overall height for 3” lift with 33s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by American AF, May 24, 2019.
  1. May 24, 2019 at 8:45 PM
    American AF
    American AF [OP] Member
    Sean
    2017 Tacoma TRD off road std trans
    What’s up fellas. I’m new on here. I have 2017 Tacoma off road trd. I want to put 2.5- 3” lift probably icon and 33” tires but my garage door is old style swing out type and truck is stock at moment and I only have like 8” max to fit in garage. Stock tires 265/70R16. About 30”. Logically 3” lift +3” tire difference =6” but just want to make sure before I spend a bunch of money and can’t fit in garage after. So if someone knows how much height exactly those add or could measure their truck roof height that has what I want that would be great. Thank you!
  2. May 24, 2019 at 8:51 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Just FYI a 3" bigger tire will only provide 1.5" of lift.
  3. May 24, 2019 at 8:52 PM
    American AF
    Sean
    Oh wow. Ok. Good to know. Thank you!
  4. May 24, 2019 at 9:05 PM
    ferntr33
    ferntr33 Well-Known Member
    30” to 33” is 3” diameter and 1.5” radius. Also depending on lift, the springs start higher then settle over time. I’ve installed a lift and then put new tires on in a garage. Then couldn’t back out. Had to put old tires on and back out of garage. Good idea measuring beforehand.
  5. May 24, 2019 at 9:12 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Just drop tire pressure everytime you park in garage.
    Haust and Bishop84 like this.
  6. May 24, 2019 at 9:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Also spring rebound/compression is a thing to becareful of, measurements change if you're pissed off parking your truck.
  7. May 24, 2019 at 9:18 PM
    TacomaParamedic
    TacomaParamedic Active Member
    Nick
    Southern Indiana
    2018 Tacoma TRD Off-Road
    17" Black Rhino Rush Wheels 265/70/17 Amp Terrain Tires Black Out (chrome) Bak Flip Cover Roof Rack
    Or you gotta poop!
    71tattooguy likes this.
  8. May 24, 2019 at 9:21 PM
    SpeySquatch
    2016 TRD OR DCSB
    Why Icon? Just curious... They get a bad rep from their horrible customer service and shock issues. Seems the only thing they make well is leaf packs...just sayin
    Also 3” lift is the absolute max you will want to go in a suspension lift, but logically 2” would be better so your components don’t suffer and the ride won’t suck
    JoeCOVA likes this.
  9. May 24, 2019 at 9:22 PM
    American AF
    Sean
    Lol. Quality advice. Or I could spend $ for lift on getting new garage doors that roll up instead of swing out which should give more room but then no lift for a good while
  10. May 24, 2019 at 9:25 PM
    American AF
    Sean
    Icon seems good. Not necessarily stuck on it I really don’t know shit about lifts. This will be first lifted truck.
  11. Sep 11, 2019 at 4:06 PM
    Sancruz88
    Sancruz88 New Member
    I agree that the max you want to lift your taco truck is 2.5 inches and max out tire size at 275 70 17 or equivalent. Plenty of tire charts out there that can give you equivalent tires sizes. Be aware of gearing issues when increasing tire circumference. Going to 3” lift will put stress on the rest of your components. If you serious about off-roading more than looks, look no further than what they do in Australia. I think the massive lifts and tires sizes are defiantly a North American fixation.
    Haust likes this.
  12. Sep 11, 2019 at 6:23 PM
    American AF
    Sean
    Good info, thanks a lot! I don’t want to go big. Want to keep performance a priority. So I will most likely follow advice of 2.5
  13. Jan 30, 2021 at 8:16 PM
    ChiefRitz2
    ChiefRitz2 Member
    Richard
    Vacaville CA
    2013 Toyota Tacoma 4X4 Quadcab TRD
    3 inch lift, 285/65/R18, 18 inch x 9 Rims, side step, sliding bed cover, Overhead Rails, Window Wind Deflectors
    My truck is 2013 TRD 4X4, 3-inch lifted in the front, and 1 & 1/2 block in the back. I have 18/9 rims. I don't have any modifications on my suspensions front and back, my tire size 285/65/18's. Never took my ride yet to the mountains so only all roadside driving. Will this be resulting a problem later on? What do you recommend ASAP to avoid anything mechanically or gears issues later. I just put on the tires and rims two weeks ago. Thanks for your advices.
  14. Jan 30, 2021 at 8:48 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Except they typically run 35s...
