overdrive and fourth gear
Discussion in 'Towing' started by thanospro98, Apr 15, 2010.
  1. Apr 15, 2010 at 1:07 PM
    thanospro98
    thanospro98 [OP] New Member
    Tennessee
    08 Double Cab Off RD
    I am a 08 Double Cab off rd. auto tranny with tow package Tacoma owner 47,000 miles, and after spending the day reading the post's here I must say I feel very happy about the purchase. My question..When towing the pontoon(2700lbsTW of tandem trailer/motor/boat) obviously I start in 4th but after reaching cruising speed on relatively flat ground is it ok to shift her into OD then going back to 4th when it starts getting hilly?
  2. Apr 15, 2010 at 1:12 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    First off welcome to TW. Secondly, with a load that light, you shouldn't have much trouble maintaining speed on level ground in OD. Like you said yourself, when it comes to towing in hilly areas, it would be best to slap it in the appropriate gear as to not labor the engine and more importantly, overheat the transmission.
    Your truck comes equipped with the towing package and therefore has a trans cooler which will also help keep your trans temps to a minimum.
  3. Apr 15, 2010 at 1:17 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    If you notice your truck downshifting alot just to maintain a speed then lock it in 4 otherwise I think you're fine in D
  4. Apr 15, 2010 at 1:34 PM
    thanospro98
    Tennessee
    Thanks for the help.
  5. May 8, 2010 at 5:23 PM
    Lunercrab
    Lunercrab AKA "06tacosport"
    Beth
    Lehigh Valley area, PA
    2010 timberland mica dcab sport
    Sorry to bring up an old thread but I was curious as well. I towed for the first time with my 2010 auto. I have a pop up that weighs around 1400lbs. On straight highway if I kept in 4th my rpms were about 2500 at about 60-65 but the truck sounded really wanted to "shift" and was on the louder side. When I had it in overdrive the rpms dropped down to about 1500 and the truck was so much quieter. I was under the impression the over drive was a no no when towing. But I'm guessing on straight highway with a light load overdrive would be better for the engine and mpgs?
  6. May 8, 2010 at 8:09 PM
    1980 Well-Known Member
    The Dust Bowl
    With a 1400 pound trailer and the towing package you are only at 21% of your rated towing capacity. The manual says to tow in Drive; if the computer detects too much strain it will downshift for you. I don't specifically know what my fully-loaded utility trailer weighs but I have hauled a lot of stuff in it and I've towed it all over the place, even on 1500 mile trips with the truck in Drive and no problems.
  7. May 28, 2010 at 7:00 AM
    dfltil
    dfltil New Member
    Don
    Dunnellon Florida
    07 Prerunner
    My 07 doesn't have overdrive only drive. There is nothing to shift down from drive. The dealer says that's ok and not-to-worry about the transmission shifting down. Any feedback?
  8. May 28, 2010 at 12:42 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    drive is an overdrive as the final ratio if higher than 1:1
  9. May 30, 2010 at 8:44 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    I always wonder if I should be putting it in 4th, when it locks and un-locks. I hope that this is factored in when Toyota programs the trans. Then again....
