OVERDRIVE BUTTON...HELP!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MWCTEXAS, Nov 26, 2012.
  1. Nov 26, 2012 at 10:50 AM
    MWCTEXAS
    MWCTEXAS [OP] Member
    MIKE
    FLORIDA
    LIMITED TRD
    Hi...I've got a situation Toyota is having a problem figuring out....
    OD switch on shifter is working properly.....but...
    the overdrive system (downshifting) is not working.....
    transmission does not engage.....and there is no light on the dash....no codes..
    it's a 2001 V-6 automatic.....
    i'd appreciate suggestions or ideas for the fix?.....thank you...Mike
  2. Nov 26, 2012 at 10:52 AM
    BamaToy1997
    Bill
    Navarre, FL
    Could you be a little more specific about what is happening? Sorry but your description is a bit vague. Perhaps a more detailed explanation to include vehicle speed and what you are doing when this failure you are mentioning occurs?
  3. Nov 26, 2012 at 12:54 PM
    Sittingbull2
    Sittingbull2 Old N.R.A. Hippy
    Mitch
    Southeast texas
    2000 Xtra Cab SR5 White
    3" Body lift, ARB Front Bumper w/9000 lb. Warn Winch, Chevy Alum. Rims w/ Kelly 285's M/S
    Did they check and see if it is the Shift Lock Solenoid or Shift Lock Control Switch
    Sittingbull2
  4. Nov 26, 2012 at 3:54 PM
    MWCTEXAS
    MIKE
    FLORIDA
    LIMITED TRD
    ..Sittingbull....thanks for the PDF's...I'll print them out and give them to the mechanic...thanks!..Mike
  5. Feb 20, 2013 at 10:24 PM
    rafaelojeda73
    rafaelojeda73 New Member
    Rafael
    California
    01 sr5 4 cyl.
    Help!!!!
    I have a 2001 Toyota Tacoma SR5. Automatic. 4 cylinders
    I got it used from a non-toyota dealer. When I turn it on, the "overdrive" button automatically sets itself to "on". I felt that the accelerator was a little heavy, and when I hit the "overdrive" button, I saw the dashboard light read "O/D OFF"... Meaning that the overdrive was on the whole time. Any help?
  6. Feb 20, 2013 at 10:29 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I believe that's normal, OD is on by default, and is turned off by pressing the button. My 2nd gen doesn't have this, but I know on previous fords I've drivin that's how it works.
    Rachelsdaddy likes this.
  7. Feb 21, 2013 at 6:23 AM
    BamaToy1997
    Bill
    Navarre, FL
    Rafael, you are describing normal operation of the transmission. Please refer to my response to your PM. MCWTexas, did you get your problem resolved? If not let us know what we can do to help more.
  8. Oct 30, 2015 at 4:09 PM
    itsgeorge
    itsgeorge New Member
    I have an 04 Tacoma, just got it and it rocks :D....i have a similar question when i press the O/D button, a light on the dashboard pops up. the light says O/D OFF << does this mean that the O/D is on all the time and when we press the button its turns OFF?........also if i do normal driving here in Cali, no towing, should i leave the O/D ON?
    Thanks!!
  9. Oct 30, 2015 at 4:30 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Yes, and Yes.
  10. Jul 23, 2020 at 7:05 AM
    Howarda
    Howarda Active Member
    Howard
    2004 SR5 Tacoma 4WD
    I know this is an old thread but I'm having the same issues as the OP. I'm confused to how the shift lock is related to the O/D switch...
  11. Jul 23, 2020 at 1:42 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Consider it as this: With the OD on, you have a 4 gear transmission. 4th being overdrive. Overdrive was made for fuel economy, not towing. When the OD is off, you get a 3 gear transmission, and can tow without destroying your tranny. Look for a Gearcruncher thread or reply and look at the sig on his posts. You will see what towing in overdrive will get ya. OD is always on by default. Off when needed.
    There will be a test!
    Hellicoopter and Rachelsdaddy like this.
