Overdrive in low range
Discussion in 'Off-Roading & Trails' started by holapalli, Dec 3, 2012.
  1. Dec 3, 2012 at 4:20 AM
    holapalli
    holapalli [OP] New Member
    PALL
    ICELAND
    07 TRD
    39,5" TIRES
    Hello
    How can i make a 2007 tacoma take overdrive in the low range (4low)?
  2. Dec 3, 2012 at 4:26 AM
    DrewH
    DrewH Well-Known Member
    You can only use 4Lo when going really slow, I'm not sure I understand what you are trying to do. :confused:
  3. Dec 3, 2012 at 4:27 AM
    DrewH
    Nice Looking Truck by the way.
  4. Dec 3, 2012 at 4:09 PM
    BradyT88
    BradyT88 ┌∩┐(◣_◢)┌∩┐
    Somewhere Offroad
    Mostly Stock '05
    He means, when you are in 4lo, the auto tranny will only go to 4th, not 5th gear. He wants to bypass that.
    I don't know if there is a way. The best way I could think of would be to trick the ECU into thinking you are in 4Hi, or 2wd when you are really in 4Lo, but that might be really hard to do, if even possible.
    Also are you really on 39.5" tires?:eek:
  5. Dec 3, 2012 at 4:15 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    4hi 1st gear :notsure:
    Hey Brady, check out his avatar.
  6. Dec 3, 2012 at 4:18 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    Is there a way to make it bigger?
  7. Dec 3, 2012 at 4:19 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Don't think so. But looks liken some big meats. Arctic style.
    I want full size pics...
  8. Dec 3, 2012 at 4:27 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    5th gear is locked out in 4Lo? Gotta try this myself...
  9. Dec 3, 2012 at 4:30 PM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    Maybe he has (39) 5" tires :eek: heh heh
  10. Dec 3, 2012 at 4:33 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    and some specs! Has to be an SAS right? haha
  11. Dec 3, 2012 at 4:35 PM
    BuzzardsGottaEat
    Chaz
    South Dakota
    Maybe he bought it from ArcticTrucks.
  12. Dec 3, 2012 at 4:40 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    Those arctic tacos are still ifs
  13. Dec 3, 2012 at 4:47 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    5th gear in 4L... might as well switch back into 4H.
  14. Dec 3, 2012 at 4:47 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    That poor IFS... haha. I forgot they did those though. Was a while ago last I looked at that site.
  15. Dec 3, 2012 at 4:50 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Why do you need to go that fast in low range?
  16. Dec 3, 2012 at 4:57 PM
    KenLyns
    Belly of the Beast
    The Arctic Trucks Tacos have less IFS suspension travel than stock - they rely on tire flex.
  17. Dec 3, 2012 at 5:21 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    I was thinking more about the cv's trying to turn those 39.5's.... I imagine they are at least upgraded to some degree, or just aren't meant to see the abuse that crawling gives them.
    EDIT: just checked and it made no mention of a cv upgrade.
  18. Dec 3, 2012 at 7:01 PM
    Spoonman
    Jamie
    Calgary
    My truck is MAGIC
    cv's at the correct angle are plenty strong. and theyre not rock crawling. however they are jumping them...
  19. Dec 3, 2012 at 7:03 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    X2
    Is that true ?
  20. Dec 3, 2012 at 7:09 PM
    BradyT88
    Somewhere Offroad
    Mostly Stock '05
    The joints are probably fine, but I don't think the angle matters much for the shaft and I have seen people break more shafts than joints. Usually breaks inside the hub or the diff. Also rock crawling tends to get you in positions where one tire has to drive you, so yeah that would make more sense about popping cv's. If you pretty much have all 4 wheels driving at once the stress is spread out so each axle is only receiving a quarter of it.
    I'd like to see more of this Artic kit. Wasn't super detailed, but I would like to know how they fit 38x15.5 tires on only a 1.5" suspension lift and a 2.5" body lift. Where I can still rub 33x10 tires on a 3" suspension lift with a 1" bodylift....
    There are some guys on here that have cut the hell out of their fenders and all kinds of stuff just to fit 35's. Even 37's require some engine compartment components to be relocated due to the extreme amount of cutting required to prevent rubbing. Although again I guess, rock crawling causes more flex I guess. Just seems crazy though!
