Overdrive on/off button?? Do any of the tacomas have this feature
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jreaka13, Jan 23, 2010.
  1. Jan 23, 2010 at 6:59 PM
    Jreaka13
    Jreaka13 [OP] COLORADO!!!
    Jon
    Colorado
    Tacoma extended bed Sport
    Everything that i have done so starting first with the shell, westin sportsman front grill,PIAA fog lights, westin rear light guards, dee-zee side steps, Nice upgradred rims and tires, dvd player,12 inch sub, Halo headlights, K&n Cold air intake, bed mat......
    I love my new tacoma... but one thing i am really bumed about is not having a way to disable overdrive!! Every truck i have ever driven has always had a way to disable overdrive.. even some cars have it!!! Whats up with this?? is there a reason for not having it???
  2. Jan 23, 2010 at 7:00 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Just drop it into 4th. Same thing.
  3. Jan 23, 2010 at 7:01 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    +1
  4. Jan 23, 2010 at 7:10 PM
    05TRD4WD
    05TRD4WD Well-Known Member
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    ; 17 x 9 xd revolvers wrapped in 295/70-R17, volant cold air intake, Gibson exhaust, BHLM, Yellow fog covers, access rollup tonneau, kenwood dnx-9960, all jl audio, jl stealth box, 900/5 amp, Fab Tech 6" lift
  5. Jan 23, 2010 at 7:11 PM
    gcwaterski
    gcwaterski Well-Known Member
  6. Jan 23, 2010 at 7:12 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
  7. Jan 23, 2010 at 7:14 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    It's not quite the same thing... There is no way to use 5th gear w/o the possibility of Overdrive kicking in...
    BUT,
    For most situations where you don't want overdrive, shifting to 4th is your best bet. It will use 1-4, no 5th, and no overdrive...
  8. Jan 23, 2010 at 7:17 PM
    eschmunk
    eschmunk Well-Known Member
    Stuttgart, Germany
    09 Prerunner TRD Off-Road
    GrillCrafter Upper and Lower, Lamin-X Fog Light Covers, Di-Noc Carbon Valence Cover, WeatherTech Digital Fit Liners, Rubbermaid "ActionPacker" containers for bed storage.
    what they said :)
  9. Jan 23, 2010 at 7:29 PM
    weidjd
    weidjd Well-Known Member
    '10 DC TRD OR 4x
    Saw COs/RR,TSB + 1.5AAl, LR UCAs
    We concur
  10. Jan 23, 2010 at 10:04 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Try the other gears ie 1st to 4th ,
    OZ
  11. Jan 23, 2010 at 10:31 PM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    what is the overdrive do on or off i was wondering
  12. Jan 23, 2010 at 10:33 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Its like another gear.
  13. Jan 23, 2010 at 11:19 PM
    00taco
    Casey
    cali
    black 00 tacoma v6
    i kno that but why would i turn it off what is it for?
  14. Jan 23, 2010 at 11:31 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Towing a trailer.
  15. Jan 23, 2010 at 11:43 PM
    S-M-R-T
    S-M-R-T Well-Known Member
    For the purpose of most automatic transmissions the "overdrive" refers to the highest gear. Anything higher then a 1:1 ratio is generally considered to be an overdrive gear (5th being 0.72:1 on the Taco). All the button does is electronically prevent the tranny from shifting up into that top gear. Like everyone said dropping into 4th gear does exactly the same thing. It is used anytime you need more power but the tranny isn't downshifting on its own (climbing long hills for instance).
    Cars have the button when your truck doesn't because the shift lever on the car doesn't give you the control to choose any gear like the Tacoma does. Generally you just get "D" and the "OD" button is the only way that you have to force the tranny to downshift that one gear.
  16. Jan 24, 2010 at 2:13 AM
    Pyrite FD
    Pyrite FD Well-Known Member
    Indiana
    09 DC TRD Off Road
    5th = overdrive gear = they are the exact same thing, not seperate
    its not 5th gear, then overdrive (6th gear)
    putting it in 4th is the exact same thing if you were to place the transmission in D and used a button to turn off overdrive.
    if a 5 speed auto was in Drive normally and was an equiped with overdrive, that 5th gear is the overdrive gear. if you hit a button that turned off overdrive, the highest gear the transmission would shift to is 4th then.
    its a 5 speed. the 5th gear is what people would call overdrive
    overdrive just means your running a gear in the transmission numerically lower than 1.00. because, by doing so your drivetrain output is moving faster than the engine input...ala it is overdriven.
    there no such thing as an overdrive kicking in, thats just a misconseption of what it really is. in reality your just shifting to a higher gear.
    some of the older transmissions had the highest gear at a 1:1 ratio. this was like a direct drive off your engine (maybe thats why they call it drive i dunno) but at some point someone had the idea to put in a taller gear after that direct drive gear for the economy and at somepoint someone called that overdrive. but again, its just shifting to another gear.
    overdrive is not like the same concept of an afterburner where something is happening additionally to something.
  17. Jan 24, 2010 at 3:15 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    5th is overdrive, there is no 5th + pverdrive.
    The poster above is right, it is just a gear that is higher (i.e. numerically lower) then a 1:1 ratio.
    On our trucks you can feel the torque converter lock (and unlock) when going up hills etc. before it will shift into 4th.
    As others have pointed out, shifting to 4th is the exact same thing as turning off OD.
    Shawn
  18. Jan 24, 2010 at 6:43 AM
    braggman7
    braggman7 Well-Known Member
    GA
    '23 Trail Edition
    So, it's recommended to throw it into fourth when towing a trailer?
  19. Jan 24, 2010 at 6:47 AM
    eschmunk
    Stuttgart, Germany
  20. Jan 24, 2010 at 6:51 AM
    Burgman
    Stephen
    Ric VA
    i used alot of 4th and 3rd gear when driving down the mountains... worked really well and saved my brakes, didnt waste any gas either.... i actually got better gas mileage than i do in the city
