Overdrive vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hunter McCabe, Aug 29, 2021.
  1. Aug 29, 2021 at 6:49 AM
    Hunter McCabe
    Hunter McCabe [OP] New Member
    Hunter
    2006 v6 blue Tacoma
    3 inch lift, wheels and tires.
    Good morning, there are countless of threads of tacoma vibrations but I cannot find one that relates exactly to my situation. I’ve got this vibration from 30-40 mph in overdrive at medium gas but I can accelerate through it and it will stop or if I take my foot off the gas it will go away. At first I thought it was transmission related so I brought it to a shop and they hooked it up to the scanner and they didn’t believe it was the transmission but I had them change the fluid anyways, didn’t help. They suspected it would be the carrier bearing or a u joint that is a little stiff. I replaced the carrier bearing and all three u joints on the rear driveshaft. None of them helped so I decided to take the rear shaft out and drive in 4 high and it still had the vibration but not as severe. Figured ok maybe it’s the rear end even though this is the second rear end in the truck. I drained the fluid and there wasn’t an alarming amount of metal on the drain plug. Any ideas??
  2. Aug 29, 2021 at 6:59 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    total mileage
    why 2 prev rear ends
    3 u jooints ......carrier bearing inadvertently could be out o phase
  3. Aug 29, 2021 at 7:04 AM
    Hunter McCabe
    Hunter
    2006 v6 blue Tacoma
    It’s got 210k on the clock but the only thing original on the truck is the front diff and the transmission. I knew the previous owner and the rear end needed to be rebuilt so he decided to buy a new one.
  4. Aug 29, 2021 at 8:11 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Sounds like u-joints Which are all the same part number. Or your carrier bearing need replacing
    I would suggest that with the low cost. Doing everything
  5. Aug 29, 2021 at 8:20 AM
    Hunter McCabe
    Hunter
    2006 v6 blue Tacoma
    I replaced them all this week and even without the driveshaft in the truck it still does it so it can’t be the shaft.
  6. Aug 29, 2021 at 8:42 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Do a google search for torque converter shudder and "rumble strip"
    TnShooter likes this.
  7. Aug 29, 2021 at 8:42 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You shouldn't be in OD at that speed. But the way these trucks transmissions are programmed it will shift to OD too soon. If I'm driving in a place where top speeds will never exceed 40-45 mph I shift out of "D" and put the truck in "4". At that speed IN OD your engine is really lugging and struggling. I'm betting that is the source of the vibration. Try driving in "4" and only manually shift to OD after you're at sustained speeds over 45. This may, or may not stop the vibration, but the truck has more power, gets better fuel mileage and you'll be a lot happier.
    cryptolyme and BMOW71 like this.
  8. Aug 29, 2021 at 9:14 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Output shaft bearing?
  9. Aug 29, 2021 at 12:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    When in overdrive, can you tap the brake pedal for a sec and get it to go away.
    (You will still need to be applying the gas to maintain speed)
    Gearcruncher has a great explanation here.
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
  10. Aug 29, 2021 at 10:11 PM
    ROAD DOG
    FEW
    i agree
    a compression test cold will probably yield UNeven ignition pulses
    I would never drive 30-45 mph on OD ................Ur perogative
  11. Aug 30, 2021 at 7:55 AM
    Hunter McCabe
    Hunter
    2006 v6 blue Tacoma
    Thank you guys for the tips. I started driving in 4 under 45 instead of D and the shudder is gone.
  12. Aug 31, 2021 at 7:15 AM
    ROAD DOG
    FEW
    5th is only good 55mph =
    i never drive below 2300 rpms any gear.....................sweet spot for my engine I4 6speed
    Ur taco may be diff engine /trans / rear end
