Overextending rear Bilstein 5100s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by whiteknight4x4, Oct 31, 2020.
  1. Oct 31, 2020 at 10:56 AM
    whiteknight4x4
    whiteknight4x4 [OP] Well-Known Member
    Drew
    Missouri
    2008 SR5 Reg Cab Taco
    2.5 inch lift: Full Dobinson's suspension kit, Freedom Off-road UCAs, 265/75r16 tires on factory Baja alloy wheels. x2 Baja Designs Squadron Sport Led Pod lights. CBI Moab 2.0 Aluminum Bumper w/full hoops, Warn Evo 8k winch. Ultraguage. Midland CB radio with 3ft Firestick Firefly. Tacomabeast/Spyder Headlights. Rear diff breather. Cruise mod. A.R.E. Topper. Prinsu topper roof rack. Hail damage mod.
    So I noticed several times after driving around on our hunting property (rough logging roads, holes etc) that my dust boots on my rear billies keep coming off.
    My guess is that means they are reaching their limit and I'm worried they're gonna take a dump on me eventually.
    My truck has the Deaver 2 inch aal and the TSB springs. I was considering switching to Nitrochargers since I already have 884 coils, I hear the ride is better. If I remember right, there's a 90000 and a 90021 series?
    Anyway, do y'all think my Bilsteins are fine or should I dump some more money into my truck?
  2. Oct 31, 2020 at 6:17 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    whiteknight4x4[OP] likes this.
  3. Oct 31, 2020 at 8:09 PM
    whiteknight4x4
    Drew
    Missouri
    Thank you, sir
    TnShooter likes this.
  4. Nov 1, 2020 at 1:14 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Simply put new zip ties on them and pull tight and that was the fix for my 5100 with Dakars.
    whiteknight4x4[OP] and Key-Rei like this.
  5. Nov 1, 2020 at 1:36 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Same.
  6. Nov 1, 2020 at 5:27 AM
    whiteknight4x4
    Drew
    Missouri
    I actually did exactly this last night. Hopefully they stay. I've had my rear axle at pretty extreme angles and the shocks have been okay so far.
