Overfilled gas.. twice.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mistermcgoo, Sep 27, 2021.
  1. Sep 28, 2021 at 7:35 AM
    #41
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    my truck doesn't do this but my car does. it cleans the license plate area so its okay
  2. Sep 28, 2021 at 8:03 AM
    #42
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    Report those stations to the state department of agriculture who usually handles fuel pump problems (most people don't know that.) I believe federal law requires a sticker on every pump somewhere with contact info. The pump may be over pressured so the flow is too high, or the handle sensor may need replacing, etc.
    Either your truck has a bend or block in the fill tube going to the tank (possible, may want dealer to take a look) or you have been unlucky by using the same station's faulty pumps. I always lower the pump handle and let the hose drain out on the ground before I put it in my vehicles (especially motorcycle) to get the dribbles out (cue eco-nuts spamming me...)
    That being said, I bought a new Kia 15 years ago or so and on my first fill up I was unable to get *any* fuel in the tank. I had the station owner try and he couldn't either. The nozzle went all the way in but every time I pulled the trigger it would BLOW back out with force as if the fill tube was blocked. We were able to dribble a pint or so in after a while since I was empty. I took it to the dealer and they went "yep, we'll fix that." Turns out I got a warranty "sensor" replacement, and still can't understand why Kia would put a valve in the fill tube that closes it off completely unless it has to do with getting in an accident or something. Weird.
  3. Sep 28, 2021 at 8:06 AM
    #43
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    That was likely a defective valve to close the fuel tank in a roll-over accident. Not weird, requirement in the FMVSS code.
    blu92in99 and NorrinRadd[QUOTED] like this.
  4. Sep 28, 2021 at 8:08 AM
    #44
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    It happens every now and again, doesn't matter what type of vehicle. It's not common for me but it happens on occasion.
  5. Sep 28, 2021 at 8:12 AM
    #45
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I was filling a diesel VW in the state of Washington once. Click never happened and it sprayed diesel all over my pants, flip flops, car etc. I went inside to bitch at them, and the attendant just said “oh, it happened again?, yeah that pump has been doing that”. Worst part was losing my $70 flip flops, then my ex, not at the time ex, finding out I was wearing $70 flip flops.
    airforceb2cc likes this.
  6. Sep 28, 2021 at 8:14 AM
    #46
    Knute
    $70 flip-flops........
    Walmart has flips for about $5. You could wear a pair and have 13 spare pair in the trunk. You know...just in case.
    Vmax540 and auskip07 like this.
  7. Sep 28, 2021 at 8:24 AM
    #47
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    That’s kind of what she said. But those cheap ass flip flops hurt. I hated those things when I was a kid, never understood why anyone would wear them. Those times are over and I have a newer pair of $70 dollar flip flops that I don’t often wear.
    Toyko Joe likes this.
  8. Sep 28, 2021 at 9:06 AM
    #48
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    When the tank gets close to full, move the catch on the nozzle to the slower rate notch or hand pump.
  9. Sep 28, 2021 at 9:46 AM
    #49
    danadavenport
    danadavenport Well-Known Member
    2021 SR5 DCLB
    I have filled up my 21 sr5 5 times and twice is has done that where a bunch off gas comes spilling out. I just assumed it was a "tacoma thing"
  10. Sep 28, 2021 at 10:19 AM
    #50
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    topping it off intentionally or because of what is stated here is not good. when i got my 16 the salesman made a point not to top off because gas will fill into some kind of canister gizmo and could result in that it will not start.
    Canadian Caber likes this.
  11. Sep 28, 2021 at 10:23 AM
    #51
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    Never happened to me, but then again I dont leave the pump unattended. Just asking for trouble if you do.
  12. Sep 28, 2021 at 11:04 AM
    #52
    NorrinRadd
    WA
    I believe that refers to the gas fumes charcoal canister. All of the sloshing causes fumes which are filtered through charcoal and if that gets saturated with liquid gas by overfilling (thus why they say to never overfill) then it causes a too rich condition that takes quite a while to evaporate. My Suzuki DL1000 has that problem regularly so I've learned to pull out the hose right when it clicks off and no more.
  13. Sep 28, 2021 at 11:43 AM
    #53
    Kirk2620
    Kirk2620 Member
    Kirk
    Happens everytime on my wife’s 2021 Off Road. All different gas stations. This is obviously a real issue with some of these trucks.
    sparty83 and mistermcgoo[OP] like this.
  14. Sep 28, 2021 at 11:50 AM
    #54
    Cipher94
    Cipher94 Well-Known Member
    Madison, WI
    2016 TRD OR
    I've never had an issue but have a 2016. I tend to use the autofill flip thing on the pump and never top off. all the pumps I've used have shutoff and the last few drips never spilled out. I do stay right next to the pump
  15. Sep 28, 2021 at 12:16 PM
    #55
    Kirk2620
    Kirk2620 Member
    Kirk
    I had a 2019 SR5, now a 21 TRD Pro, and my son has a 2021 TRD Sport. No issues on any of those.
    But my wife’s 21 just pours out. The pump clicks, then here it comes. It’s a total mess.
    mistermcgoo[OP] likes this.
  16. Sep 28, 2021 at 12:19 PM
    #56
    mistermcgoo
    mistermcgoo [OP] Well-Known Member
    PA
    2021 Super White TRD OR DCSB
    Judging from the varied responses on this thread, it must be a real hit/miss issue.
    Kirk2620[QUOTED] likes this.
  17. Sep 28, 2021 at 12:40 PM
    #57
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    When you live in flip flops (here in Socal) and wear them 90% of the time you're putting something on your feet good quality slaps are important.
  18. Sep 28, 2021 at 1:03 PM
    #58
    Tim010
    Tim010 Member
    In Alberta we have nozzle locks on the gas hoses.
  19. Sep 28, 2021 at 1:08 PM
    #59
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    When you're using the hold open latch, what setting do you use? Typically they have three notches. You should always use the "slowest" setting to minimize vapor. If you're pumping too fast, the vapors can mess with the auto-shut off in the nozzle.
    NorrinRadd likes this.
  20. Sep 28, 2021 at 1:50 PM
    #60
    Kirk2620
    Kirk2620 Member
    Kirk
    I always and have always used the fastest fill setting. I have never once had a overfill problem on any car including 3 other Tacomas of the same generation.
    This definitely isn’t an issue with people not pumping gas correctly. It is 100% something going on with some of these trucks. I called my dealer and they said they’ve had this on RAV4’s recently as well.
    airforceb2cc and mistermcgoo[OP] like this.
