Overfilling rear differential with 5 Qts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Edslittleworld, Mar 5, 2020.
  1. Mar 6, 2020 at 8:42 AM
    #41
    madcity27
    madcity27 Well-Known Member
    2016 Tacoma TRD OR DCLB
    When I changed my diff/t-case fluids, I recall the rear diff taking more than 4.2 qts. I was slightly worried it was overfilled, but 40k miles later there are no issues.
  2. Mar 6, 2020 at 8:51 AM
    #42
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I did something similar. I drilled and tapped a fitting into it and then attached a regulator and 30psi gauge with air fitting. The bottle was cheap from Princess Auto. (Canada's Harbor Freight)
    tonered[QUOTED] and shakerhood like this.
  3. Mar 6, 2020 at 8:56 AM
    #43
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice work!
    I've seen Princess Auto talked about. Canadian Tire is also a big parts store, right?
    I do miss GI Joes that we had here. It was automotive and sporting goods plus a bunch more. They closed up shop during the 2008 crisis. Thankfully HF is going strong. I'm not sure about their up market push though.
  4. Mar 6, 2020 at 9:00 AM
    #44
    Steve Urquell
    Steve Urquell No Pants
    2017 2.7L/5MT AC Utility 4X4
  5. Mar 6, 2020 at 9:03 AM
    #45
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Back when I had an 8.4 axle, I would tip my truck on its side, take an axle shaft out and fill the axle all the way to the top, put the axle shaft back in and tipped the truck back over. Took about 20gallons, but you can never have too much fluid in there because heat. I did come to the conclusion that the diff service caused my doors and bedsides to dent, so you may want to lay a few old mattresses down or something to prevent that.
    loastad, Walkdog, Al Hoff and 4 others like this.
  6. Mar 6, 2020 at 9:03 AM
    #46
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Yes, Canadian Tire is Automotive, sports, outdoor and retail. They are even trying to move into groceries a bit. We have lost a lost of major retailers the last 10 years and they are working to fill that gap and stay relevant.
    tonered[QUOTED] likes this.
  7. Mar 6, 2020 at 9:06 AM
    #47
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very cool. Hopefully HF stays away from groceries. :rofl:
    We do have Tractor Supply Company which is really cool if you need some light industrial stuff, or baby chicks.
    Speedfreak[QUOTED] likes this.
  8. Mar 6, 2020 at 9:10 AM
    #48
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    :eek:
    tonered and GreyBaldTaco[QUOTED] like this.
  9. Mar 6, 2020 at 9:30 AM
    #49
    StillNoPickles
    StillNoPickles Well-Known Member
    2020 RAV4 Hybrid LE
    Did you make sure to use 0w-20 for the best mpg?
    Edit: or R. Kelly’s urine supplemented with a LSD additive?
  10. Mar 6, 2020 at 9:33 AM
    #50
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I pro tip is to drill a hole in the diff for a zerk fitting and pump the whole thing full of red’n’tacky greaze. Stop pumping when it starts coming out the breather.
    lamjam, MannyS, tonered and 2 others like this.
  11. Mar 6, 2020 at 9:34 AM
    #51
    StillNoPickles
    2020 RAV4 Hybrid LE
    Only if you fill it first with acetone and run a 500 mile interval to clean out all the old fluid.
  12. Mar 6, 2020 at 9:45 AM
    #52
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I use a gravity feed system. I put a barrel of gear oil in the truck box and then run a hose from the bottom into the top of the diff. At the bottom of the diff I install a controlled orifice. That way I change the oil regularly as it drips out and I don't worry about being empty for months at a time with the barrel. As a bonus when driving dirt roads the oil keeps the dust down.
  13. Mar 6, 2020 at 9:47 AM
    #53
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The automatic chain oiler of the Taco world. :cheers:
  14. Mar 6, 2020 at 9:53 AM
    #54
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Why does this bruise my brain? Good thing most people drive automatics I can't image how hard that would be to deal with another fill plug.
    tonered likes this.
  15. Mar 6, 2020 at 9:55 AM
    #55
    StillNoPickles
    2020 RAV4 Hybrid LE
    Automatics have sealed transmissions. The fluid is good for eternity. You can make your own drain and fill holes with a 1” drill bit though. Rubber stoppers seal it up nicely.
    Speedfreak and tonered like this.
  16. Mar 6, 2020 at 9:57 AM
    #56
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nah! FlexSeal. Seals anything.
  17. Mar 6, 2020 at 10:00 AM
    #57
    StillNoPickles
    2020 RAV4 Hybrid LE
    Drill holes into your transmission and turn it into a boat!
  18. Mar 6, 2020 at 10:10 AM
    #58
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    If you place a Tacoma on its side, the differential will hold more fluid.
    lamjam, Speedfreak and tonered like this.
  19. Mar 6, 2020 at 10:12 AM
    #59
    Quacktacular81
    Quacktacular81 Unknown Member
    SW Colorado
    2020 Tacoma TRD Off-Road
    Why are we including a pic of a BMW with IRS and a Euro-Dick?
  20. Mar 6, 2020 at 10:17 AM
    #60
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    what brand is the best to use?
    Paul631, shakerhood and MannyS like this.
