Overhead cluster 12v ignition switched power pin outs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Sep 28, 2017.
  1. Apr 25, 2018 at 7:56 AM
    #41
    joostin420
    joostin420 Member
    Justin
    MY18 TRD SPRT DBL Cab LB Cement Prm/tech
    Tapped into the brown and black/white wires for radar detector and working perfect.
    Installing a Kenwood drv-n520 camera.
    Plan on using the same brown and black/white wires for switched and ground, but it also calls for a constant tap as well. Which wire would I tap into for the constant; I did see someone had a problem previously?
    Thanx,
    Justin
    r_to_the_k likes this.
  2. Apr 25, 2018 at 1:16 PM
    #42
    BountyOR_VF2
    BountyOR_VF2 "If in doubt, flat out!"
    NorCal Bay Area
    2017 WHITE TRD TCSB OR
    I think this is a perfect way to power the GoPro
  3. Apr 25, 2018 at 1:57 PM
    #43
    OnHartung'sRoad
    OnHartung'sRoad [OP] -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Hey Joostin- sorry, but I didnt end up doing the constant due to the DLR issue, so I took out that part of the post. The only way I know to get constant 12v in the overhead without digging into my console further (I don’t need it so didnt look further) is to run a 12v hot up the A pillar from the fusebox under the dash.
  4. Oct 11, 2018 at 12:14 PM
    #44
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    I think I am going to run this USB coverter, the adapter and the panel USB A port through the opening in the top of the LSA sensor windshield box. This will give me a USB A port right next to the GOPRO mount. I figure eventually dash cams, etc will have different USB connectors (USB Micro, USB Mini, USB-C, Apple Lightning etc.)
  5. Oct 11, 2018 at 12:19 PM
    #45
    The_Devil
    E
    Pics
  6. Oct 17, 2018 at 3:47 PM
    #46
    The_Devil
    E
    Adding the pic of the panel install. It looks clean.
  7. Dec 30, 2018 at 8:23 PM
    #47
    Vttroy
    Vttroy New Member
    2018 Black Tacoma SR5
    Thanks for the tip. I put it in today and it works great. More than one brown, black/white wires in the bundle, but I must have gotten lucky and used the right ones.
    I broke open a cheap usb charger, attached wires, and shrink wrapped it.
  8. May 18, 2019 at 6:27 PM
    #48
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    I am going to try this for my GoPro
  9. May 18, 2019 at 7:27 PM
    #49
    caribe makaira
    Caribbean, Puerto Rico
    For those without a sliding roof, the 20 amp (Battery/Hot) that is meant for it is wired up to the driver's pillar. (IN1) With a 2.3II (090) terminal crimp to a long enough wire to reach the overhead you would have another power source.
    JSX and Danbest82 like this.
  10. Sep 9, 2019 at 9:05 AM
    #50
    BSK
    BSK Keyboard not responding. Press any key to continue
    Trabant 501 Kombi
    Cigarette Lighter Delete
  11. Sep 9, 2019 at 9:10 AM
    #51
    caribe makaira
  12. Sep 9, 2019 at 10:58 AM
    #52
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I have the garmin glow as well but mine sucks, that thing never gets any signal.
  13. Sep 9, 2019 at 12:09 PM
    #53
    OnHartung'sRoad
    Sorry, so it must be an issue with your individual unit.
  14. Sep 9, 2019 at 12:13 PM
    #54
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    That’s what I was thinking, because it seemed to have great reviews.
    I was also wondering if it was because I use it in tree covered areas? I put mine on the dash and wedge it by the windshield but no luck.. I’ve also tried it at home with my WiFi turned off and it works, but it’s slow to pick up signal.
  15. Sep 9, 2019 at 12:14 PM
    #55
    OnHartung'sRoad
    Yeah, sounds like something wrong. Mine even works in my pack on the back seat with a RTT on top of the truck.
  16. Sep 9, 2019 at 12:17 PM
    #56
    OnHartung'sRoad
    Return it with a nice letter, maybe they’ll swap it if you say you wanted to review it for TW ;)
  17. Sep 9, 2019 at 2:09 PM
    #57
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    How in the hell is that possible haha. Definitely something wrong with mine.
    I believe I’ve had it for a year now, I don’t think TW will fly but maybe still under manufacturing warranty :rofl:
  18. Sep 9, 2019 at 3:04 PM
    #58
    OnHartung'sRoad
    It’s probably the satellite geometry (low on the horizon) that let the signals come in through the windows if the RTT and roof blocked it. Its not a bad receiver at all, in fact it can receive two different types of GPS bands, so it does get great coverage. Perhaps one of yours is disabled somehow. Is there a factory reset option in the firmware? I haven't touched mine at all except for disabling position recording as I only wanted to use it to relay the position via bluetooth to my ipad.
  19. Sep 9, 2019 at 3:09 PM
    #59
    OnHartung'sRoad
    Hey, try this update for firmware!
    https://www8.garmin.com/support/download_details.jsp?id=5811
    BUT be WARNED: “If attempts to upload software fail, you may need to return the device to Garmin® for service.”
  20. Dec 4, 2019 at 10:03 AM
    #60
    The_Devil
    E
