Overhead cluster 12v ignition switched power pin outs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OnHartung'sRoad, Sep 28, 2017.
  1. Dec 4, 2019 at 12:14 PM
    #61
    caribe makaira
    Caribbean, Puerto Rico
    HOPE? Don't guess, take a Multimeter and verify, Toyota loves to change wiring in same model different years...
    Danbest82 likes this.
  2. Dec 4, 2019 at 2:58 PM
    #62
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    By hope I meant that I already ordered the connectors you referenced. If the 12v is not keyed power that is great news, if it is, then I will tap a line I already ran into the cab since I will already be in there.
    I don't plan to open up the pillar until the connectors arrive but I will test.
  3. Dec 14, 2019 at 6:08 PM
    #63
    The_Devil
    E
    Update:. The pin you recommended worked great. This indeed adds a hot constant and the wore can easily be tucked under the headliner and into the over head cluster.
    This was true for 2018 TRD OR without sunroof.
  4. Dec 14, 2019 at 6:29 PM
    #64
    caribe makaira
    You did lower the fuse amp to what the cam needs...right?
  5. Dec 14, 2019 at 8:19 PM
    #65
    The_Devil
    E
    Was not too worried about it as I only have the 4.2 Amp USB converter on there, but considering adding a second. Good suggestion
  6. Dec 18, 2019 at 6:37 AM
    #66
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Not sure if this is common knowledge, but for those who don't want to tap into / splice wires or run a length of wire to the drivers foot well fuse panel, this might be an option.
    https://www.amazon.com/dp/B07DMW3DML
    I came across it on Amazon, can't vouch for it though - I went a similar route as others in this thread.
  7. Dec 19, 2019 at 8:04 AM
    #67
    BSK
    BSK Keyboard not responding. Press any key to continue
    Trabant 501 Kombi
    Cigarette Lighter Delete
    believe the above is made by a fellow TW poster. Remember posting it and he came on in a different thread. He dumped discount codes for fellow members.
  8. Jan 1, 2020 at 8:56 PM
    #68
    Team Scream
    Team Scream Well-Known Member
    Los Angeles Kali
    2018 TRD DCOR Quicksand 4x4
    Old Man $538.00 Sound System Upgrade w/Kicker DS in the doors, and a Cerwin Vega VPAS10 powered (10") sub under the drivers seat.
    Im trying to hardwire my dash cam using this thread.
    Under the overhead console/panel, the bundle leading down to the mirror has several brown(ish) wires and one or more wires with a white stripe that looks almost brown(ish) with a white stripe.
    Are all of these browns(ish) wires 12v switched? I can't imagine multiple wires that are the same color, in the same bundle being different, but would rather ask before committing.
    It is way tight up there and I have a neck injury that prevents me from spending too much time with my head wrenched around, so a little clarification would be awesome.
    Thanks!
    MR E30 likes this.
  9. Jan 25, 2020 at 7:58 AM
    #69
    FPCat
    FPCat Active Member
    I used the instructions in this thread to tap into the switched supply and it worked great. Very happy to get my dashcam hooked up without having to add a fuse and run a long wire. Thanks OP!
    m3bassman likes this.
  10. Jun 13, 2020 at 2:55 PM
    #70
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    any ideas which wire is the is the dash light wire? i'm installing a switch in the overhead console and need to tap a wire that comes on with the dash lights
    edit. it's the green wire!
  11. Jul 20, 2020 at 10:21 AM
    #71
    DarthPat1977
    DarthPat1977 Well-Known Member
    Patrick
    Alabama
    2016 Tacoma SR5 DCSB
    I wonder if my 2016 SR5 has this harness even though I don't have a powered mirror...
  12. Jul 24, 2020 at 2:56 PM
    #72
    DarthPat1977
    Patrick
    Alabama
    Nope!
  13. Mar 7, 2021 at 7:37 AM
    #73
    MillbrookMike
    MillbrookMike Well-Known Member
    New York State's Hudson Valley region
    2018 Tacoma TRD Sport
    Justin, May I ask where on your windshield you installed the DRV-N520? I'm about to put one in my '18 Tacoma and I'm curious what you found to be the best location for it. I'm thinking of behind the mirror and close to the left side of the front camera housing, but I don't want the lens to pick up that housing in the view. Thanks!
  14. Jul 7, 2021 at 6:42 PM
    #74
    Greedo
    Greedo Active Member
    Rex
    2016 D-Cab TRD Off-Road Magnetic Gray Metallic
    Toyotec Boss 2" lift & level, UWS black chest/toolbox, Xeon Led interior lighting, Toyota bed mat, Gentex Homelink Mirror, predator step bars, black TACOMA tailgate lettering.
    Shout out for this as mine were discolored as well, and I was confused. Installed the 12v converter, just waiting on the dash cam
    m3bassman[QUOTED] likes this.
  15. Nov 19, 2021 at 12:11 PM
    #75
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    I'm doing the same thing, but in my 2021. I also have a few brown wires, and a couple of white w/ black striped wires in the bundle that runs to the rearview mirror. My harness in that location does not look like the photos posted throughout this thread.
    Did you ever figure this out? I suppose I could wrench apart the wires that run down to the rearview mirror and find them that way, but it's tight up there and there is so much glue holding things together that I am worried about damaging things.
  16. Nov 19, 2021 at 12:15 PM
    #76
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    Honestly, the best way to determine this is to use a volt meter and a needle (sewing needle to poke through the insulation and to make contact with the wire). There's definitely a switched wire under there as well as constant. I got a dash camera that needed to be on constant power instead of switched and was able to find it fairly quickly using a volt meter. In my 2017, the brown was switched and the blue was constant. I used the colors going into the plug for the powered rear view mirror to help me get started on what wires to check.
  17. Nov 19, 2021 at 1:19 PM
    #77
    caribe makaira
    Touch the rear of the terminals at the connector where the wires exit for circuit verification with a multimeter probe.
    The wires differ in color, verify slot locations.
    Toyota has ground wire as white with black trace throughout the vehicle.
  18. Jul 11, 2022 at 10:53 AM
    #78
    cjpeavy
    cjpeavy Member
    Joel
    2017 Silver Tacoma SR5
    Subbed! Great freaking thread.
  19. May 27, 2023 at 1:10 PM
    #79
    dtrantaco
    dtrantaco Well-Known Member
    Great post! Thanks!
