Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Nov 15, 2017 at 6:17 PM
    #1981
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The blob is fine, just part of the manufacturing process or something. The lead free solders aren't the best to use, but should still get you a connection. That said as long as the connection is fine I bet the temp will regulate itself a little better soon enough. I don't think those resistors will affect the temp reading.
  2. Nov 15, 2017 at 7:10 PM
    #1982
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Thanks for the reply, I will see what it looks like tomorrow!
  3. Nov 17, 2017 at 7:05 AM
    #1983
    santas212
    Georgetown, CT
    Yep it seems like the temp has equalized overnight and has been working good now! Thanks for the people who figured this out and posted it up!
    xJuice likes this.
  4. Nov 20, 2017 at 1:51 PM
    #1984
    kydreamers
    kydreamers Well-Known Member
    David
    Franklin, Kentucky
    2005 Black Sand Pearl Toyota Tacoma Double Cab TRD
    This is an amazing diy post..I had to redo mine...
  5. Dec 5, 2017 at 12:02 AM
    #1985
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    My temp display stopped working about a month ago. Just pulled the overhead display down tonight and the 510 resistors look fine but I will solder them tomorrow after I pick up some solder. Wish me luck...
  6. Dec 5, 2017 at 12:07 AM
    #1986
    santas212
    Georgetown, CT
    Yea mine looked normal until I got them in just the right light at just the right angle and could see a superfine hairline crack on the one closest to the display on the side closest to the middle of the board.
  7. Dec 5, 2017 at 2:32 AM
    #1987
    Mxer4ever
    Mxer4ever Member
    2005 TRD Offroad SWB
    Thanks Santas212 for the pics. I'm pretty skilled, but I like to know what to expect when opening up anything on my truck.
    I had this same problem after about 2 years of age, the compass / temp display just went blank. I just said F it and got on with my life but I'm really glad to see this post and know that this is a common problem with a relatively easy fix.
    Follow up:
    as soon as I took mine apart it was clear as day what was wrong. My 510 closest to display was popped up 1/8" on one end. Soldered all 4 and all worked again. Thanks again guys for the post
    santas212 likes this.
  8. Dec 5, 2017 at 11:33 AM
    #1988
    thebaker
    Byron
    NorCal
    Just did this fix and everything work great again!!!!!!! Thank you!!!
  9. Dec 22, 2017 at 12:01 PM
    #1989
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    @santas212,
    Yep...as you discovered, the temp display will eventually settle down. From what I have gathered from clients, the worst cases of temp mis-match tend to occur when the display is powered off on a particularly warm or cold day, then powered back up on a cold/warm day (in other words, a large temp change occurred with the unit off).
    Also, I believe the controller chip does some kind of rolling average to keep the display smooth and not constantly changing, so that probably slows the catching-up process.
    As a reminder, kindly follow my repair guide here so as to drastically reduce the likelihood of permanently destroying your display. There are PCP pads very close to the resistors, and a solder bridge between them ruins the board.
    Merry Christmas / Happy New Year to all!
    xJuice likes this.
  10. Dec 26, 2017 at 5:53 PM
    #1990
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Opened mine up today one resistor is missing. The other ohmed bad. Tried reaching radio shack n no luck. Not many electronic stories near me. Can i just send it off to one of those online places for 60 or keep looking. I have sodering exp just not this small. Used to 14 guage or bigger.
    Ok found a vender but says i need to purchase 5000 resistor for $25. And what is the watt rading on these.
  11. Dec 27, 2017 at 4:45 PM
    #1991
    Siliconmethod
    Greg
    MO
    @Jckdnks,
    "Ok found a vender but says i need to purchase 5000 resistor for $25. And what is the watt rading on these." As I'm sure you probably already know, the resistor component cost is about $.05.
    The watt rating is 1/4 watt, so if you can find a couple 1/4 watt axial lead resistors you will be able to do it yourself. Otherwise, send it my way...I don't charge for resistors as I replace them both anyway (unlike the ebay shysters who just try to reflow solder onto the old oxidized components). Replacing the resistors must be done, otherwise the board will fail again within a year or so depending on conditions.
    http://www.siliconmethod.com/
  12. Dec 27, 2017 at 5:10 PM
    #1992
    Freddeez
    Freddeez Well-Known Member
    Orange County Ca
    2008 DCSB Rugged Trail Edition BSP
    I had done this yesterday. Luckily my resister was shaking around in there and I was able to attach it back on using a solder.
  13. Dec 27, 2017 at 6:23 PM
    #1993
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Can i just drop it off do some wheeling at tollhouse n pickk it on my way home?
  14. Jan 2, 2018 at 7:56 PM
    #1994
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    Did it. Stupid easy.
  15. Jan 2, 2018 at 9:05 PM
    #1995
    Eselkopf1
    Eselkopf1 Well-Known Member
    Alex
    Some of us are new. Only had mine like 5 days. What are we fixing? Mine seems fine.
    nwilli10 likes this.
  16. Jan 6, 2018 at 7:55 PM
    #1996
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I resoldered the orignal 510 SMD 51 ohm resistor last year but it fell off again. The metal contact on one end is actually gone so it could not be resoldered anymore.
    This time I used 2x 100 ohm 1/4W resistors in parallel to make 50 ohms. Hopefully this will help share the heat disapation so each resistor won’t get as hot and be a permanent fix.
  17. Mar 6, 2018 at 2:34 PM
    #1997
    el_smurfo
    el_smurfo Well-Known Member
    After fixing for the second time, I had the same idea. Stood them up with hopes of getting a little airflow.
  18. Mar 22, 2018 at 5:49 PM
    #1998
    SaphiraTaco
    SaphiraTaco Well-Known Member
    Sean
    Seattle WA
    2013 DCLB TRD Sport
    About halfway done...
    I have been living without my temp/compass for at least 7 years... So I got motivated and found this thread. About 5 minutes later its all fixed. Guess I thought this problem would have been more expensive or difficult. Thanks for the encouragement
  19. Mar 24, 2018 at 9:06 AM
    #1999
    skibum185
    skibum185 Active Member
    Big Sky, MT
    09 DCSB TRD
    Toytec Boss 3" lift URD Short Throw Magnaflow dumped 285/75/16 Duratracs SOS sliders Ext brake lines NWTI Bumpers VHF/UHF/CB Shackle flip
    My display works but the temp either goes blank (---) or fluctuates within 100 degrees.. Wondering if this would fix it or if the sensor is screwed up. Any ideas?
  20. Mar 24, 2018 at 9:19 AM
    #2000
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    Bad resistor or solder connection.
    I fixed my '07 a few years ago (bad solder connection due to heat) but it went out again 9 months later. I never tried to repair it again but it is a pretty easy thing to do.
    I would probably do the circuit board upgrade if money is no issue.
