Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jun 16, 2018 at 5:39 PM
    #2021
    Muddinfun
    Muddinfun Well-Known Member
    I would think so. If no connection is no illumination and 51 ohm is proper illumination, then 510 ohms resistors could certainly make it dim.
  2. Jul 1, 2018 at 4:25 PM
    #2022
    OttStSilverTaco
    OttStSilverTaco New Member
    2008 Silver Dbl Cab Tacoma
    Thanks so much! Got this done in about 20 minutes!
    Freeheelbillie likes this.
  3. Jul 11, 2018 at 5:18 PM
    #2023
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    The fix I did only lasted until today, I have read that others have had the same issue pop back up. Guess I'll have to resort to snagging one off ebay too :annoyed:
  4. Jul 11, 2018 at 5:40 PM
    #2024
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    circuit board has heat issues, best to upgrade circuit board, fix is temporary...imo
  5. Jul 11, 2018 at 5:59 PM
    #2025
    Freeheelbillie
    Billie
    Saint Clair, MI
    Have a good link for a better than OEM board?
    kimo[QUOTED] likes this.
  6. Jul 11, 2018 at 6:05 PM
    #2026
    kimo
    Knuckle Head
    Kauai
  7. Jul 12, 2018 at 3:09 AM
    #2027
    Freeheelbillie
    Billie
    Saint Clair, MI
    Sweet thanks! Still cheaper than a "new" OEM part on Ebay and it sounds like this service will actually be a true fix for the weak board.
  8. Jul 12, 2018 at 3:13 AM
    #2028
    Freeheelbillie
    Billie
    Saint Clair, MI
    Another memeber sent this repair service to me https://circuitboardmedics.com/tacoma-temperature-compass-display-repair/ I plan on giving this a shot after my repair failed a few months later. They use better parts that don't flex in the heat...so this shoulbe be a fix for the life of the truck.
  9. Jul 12, 2018 at 1:29 PM
    #2029
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Did you re-use the factory resistor or use a full size?
  10. Jul 12, 2018 at 4:27 PM
    #2030
    Freeheelbillie
    Billie
    Saint Clair, MI
    I was able to find the original loose in the compartment and reuse it.
  11. Jul 13, 2018 at 1:52 AM
    #2031
    Fitz235
    Rob
    New Hampshire
    If you look back through the thread, you'll see that re-using the original resistor is the problem. Go pick up a standard size 51 ohm resistor, and solder that in. I think the issue has more to do with not getting enough solder on the original (because of how tiny it is), than anything else.
    I went through the same process. Re-soldered the original in, held for about a month, then shit out again (I think I may have even done it twice). I then used a standard size resistor, and it's been just about a year so far, and it's been holding up. Your able to get a much better connection between the board, and resistor, with the bigger resistor.
  12. Jul 13, 2018 at 4:45 AM
    #2032
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Solder choice is also a big part. The lead-free stuff blows. I got some 60-40 tin lead rosin core off ebay for like $3.
  13. Jul 19, 2018 at 1:22 PM
    #2033
    tacos2015
    tacos2015 Well-Known Member
    Memphis, TN
    2006 DCSB Prerunner
    Toolbox, running bords
    Thanks for the write up, i just did this last weekend and it's back to working like new!
    Fitz235 likes this.
  14. Jul 20, 2018 at 2:06 PM
    #2034
    Freeheelbillie
    Billie
    Saint Clair, MI
    Did mine again this afternoon...back up and running. The resistor next to the one I soldered last time was loose. Note to others doing the repair, solder both resistors while you have it apart.
    tacos2015 and dborrer like this.
  15. Jul 27, 2018 at 4:09 PM
    #2035
    Freeheelbillie
    Billie
    Saint Clair, MI
    Broke AGAIN :annoyed:!!!!!!!!
  16. Jul 27, 2018 at 8:16 PM
    #2036
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    http://mdpub.com/compass/index.html
    I have some resistors ordered to give it a try. Mine is working since the fix. Have these for when it happens. I have 50x 150ohm coming in.
  17. Jul 27, 2018 at 8:54 PM
    #2037
    Muddinfun
    I hope you fat fingered that post and meant 510 ohm resistors.
  18. Jul 27, 2018 at 9:14 PM
    #2038
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Did you go to the link?
  19. Jul 27, 2018 at 9:51 PM
    #2039
    Muddinfun
    Oops, I had a brain fade and should have typed 51 ohms.
    Well, I went to that link and looked at what he did. Well........ uh...... OK, so he reinforced 1/2 of the circuit to a level that it will never fail. However, the other 1/2 of the circuit is still destined for failure.
  20. Jul 28, 2018 at 3:18 AM
    #2040
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    And then guess what will be done again. Come on give the guy a bone.
    dborrer likes this.
