Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Nov 6, 2018 at 11:31 AM
    #2081
    327
    327 Well-Known Member
    Mark
    Covington, LA
    Former 06 TRD Sport Silver Current 06 Sport 4Runner
    I'd fixed mine once before in the past by soldering the little 510 chip onto the board. Well after another hot summer the compass stopped working again. When I pulled it, the 510 little piece was completely off the board. I looked around for someone locally to fix it, but no luck.
    I found these guys on ebay named Module Master, and couldn't be happier with it. It's a rebuild service. So you pay them like $20ish and send your module to them. They fix it and test it. They also beefed up a few of the other weak looking solder points. I couldn't be happier with it. I don't have any stake in their company, just happy with their work.
    kydreamers and 4x4Taco09 like this.
  2. Dec 1, 2018 at 1:54 PM
    #2082
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    @327.....did the rebuild service use new components or did they re-solder your old resistors back in? Hopefully they installed new ones; the old resistors are oxidized and won't take solder well.
    I also heatsink them (actually a form of heatpipe) as they are slightly overloaded. I've not had a repair fail in almost a decade using this technique. The attached pic shows essentially how it is done, although I have a slightly modified system now (but don't have one to take a pic of)
    For the folks interested in the DIY option, see my page here: https://siliconmethod.com/diy-tacoma-display-repair-guide/
    cleats50 and kydreamers like this.
  3. Dec 12, 2018 at 6:33 PM
    #2083
    Siliconmethod
    Greg
    MO
    By the way, for those looking for how to pull the overhead display down, here's the ancient video I made:
  4. Dec 25, 2018 at 7:55 PM
    #2084
    blake68
    blake68 Well-Known Member
    Sessions
    Utah
    2005 Black Tacoma
    Thanks for this it works perfect in my truck now.
  5. Dec 27, 2018 at 11:51 AM
    #2085
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Thanks again for sending those out! Super cool of you :thumbsup:
    I got my resistors and fixed the overhead display. Works like new!
  6. Dec 27, 2018 at 4:46 PM
    #2086
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    Nice
  7. Dec 31, 2018 at 2:53 PM
    #2087
    mperl
    mperl Well-Known Member
    Texas
    Impulse Red 2006 PreRunner SR5 TRD Quad Cab
    I lost the single screw that holds the entire overhead display. What size screw do I need to replace?
  8. Jan 8, 2019 at 1:19 PM
    #2088
    kydreamers
    kydreamers Well-Known Member
    David
    Franklin, Kentucky
    2005 Black Sand Pearl Toyota Tacoma Double Cab TRD
    Thanks for the info...this little problem is still on my fix-it list...
  9. Jan 8, 2019 at 1:20 PM
    #2089
    christian06
    Cali
    I still have some resisters if u need any, free
    4WDTrout and kydreamers[QUOTED] like this.
  10. Jan 8, 2019 at 2:10 PM
    #2090
    christian06
    Cali
    It is dim, but works, it's been over a yr now, I have just recently got some 510s, hopefully it will be brighter, only thing is, the 510s are a lot smaller in size, does this mean anything?
  11. Jan 9, 2019 at 3:22 PM
    #2091
    CBenfell
    CBenfell I don’t know sh*t about f*ck
    Christian
    Western Washington
    21 DCSB TRD OR Midnight Metallic Black
    Crippling Debt
    Fixed mine today. Very helpful thread. Was something I intended on doing but was “too busy”. Happy it’s done now.
  12. Jan 14, 2019 at 8:17 PM
    #2092
    TK11
    TK11 Well-Known Member
    Tom
    N. CA
    2019 TRD OR MT
    Bilstein 6112 / 5160, 275/70/17 BFG KO2, Caliraised Sliders, SSO bumper, Warn winch
    Just came across this thread. My compass / temp hasn't worked for a while now. I figured it was because I have a satellite radio antenna magnetically attached to the roof nearby. The manual says that could cause problems, so I figured that I caused it. But, maybe the only problem caused by the magnet would an inaccurate compass reading! I will look into this resistor fix unless someone can tell me that I caused a bigger issue. Thank you.
  13. Jan 15, 2019 at 4:25 PM
    #2093
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Took mine out a year ago to fix it. Still havent fixed it yet.
  14. Jan 17, 2019 at 1:33 PM
    #2094
    dt123
    dt123 Member
    '07 taco
    I'm glad I ran across this thread last night, fixed it this morning.
    4WDTrout and Muddinfun like this.
  15. Jan 22, 2019 at 7:48 PM
    #2095
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Mine just bit the dust. I guess tomorrow after class I know what my project is. Hopefully it just broke contact and I don’t need new 510s
  16. Jan 24, 2019 at 6:40 PM
    #2096
    Siliconmethod
    Greg
    MO
    A lot smaller in size...compared to what? The OEM resistors, or components you installed later?
    If the resistors are smaller than the OEM's, don't use them...they won't be rated for the heat dissipation (wattage) necessary. Buy some 51 ohm axial lead 1/4 or 1/2 watt resistors and use those instead.
    If you used other resistors, what are their ohm values? That might explain the dim display...
  17. Jan 25, 2019 at 6:41 AM
    #2097
    96carboard
    96carboard Well-Known Member
    NOPE.
    Those 1/4 or 1/2 watt axials you suggest are only good for 1/4 or 1/2 the current that the factory 1 watt resistors are capable of.
    Also be aware that a 1218 (package size, not releated to the resistance value) is physically about half the size of 2512 (factory size) resistors, and can handle equal power (1W).
  18. Jan 25, 2019 at 5:18 PM
    #2098
    Siliconmethod
    Greg
    MO
    Your statements are wrong on a few levels. P = I2 x R , so the correlation between current handling and wattage capability is a function of the square.
    Also, the factory design is not failing because of current handling capability of the resistors. They fail because:
    -factory use of lead free solder (not their choice or fault, but the board design doesn't account for the RoHS directive)
    -thermal cycles
    -the entire assembly hangs upside down.
    So, a 1/4 or 1/2 watt resistor is more than enough to handle the milliamp levels of current to power the VFD. Leaded solder and the heatsinking capability of the axial leads allow the repair to last.
    Putting physically larger and heavier components (as 1watt resistors are) will only increase likelihood of failure, up to and including pulling the copper pad off the board.
    Muddinfun likes this.
  19. Jan 25, 2019 at 6:50 PM
    #2099
    96carboard
    Before your brain melts from all the numbers, THE FACTORY RESISTORS ARE 1 WATT RESISTORS. I am not suggesting to go with anything bigger or heavier than factory. I'm suggesting that you stick with components that at least meet the original specifications.
    If you feel like going off on an uneducated rant about why you think that something considerably smaller will be sufficient, then you will need to PROVE your position.
  20. Jan 31, 2019 at 9:51 AM
    #2100
    ChadsPride
    Sponsored by TacomaWorld.com
    Well, my dads temp/comp display went out on Wednesday.
    He's asking for my help fixing it and this thread is really great.
    Going to pic up a soldering iron kit and try to repair it for him.
    4WDTrout and Fitz235 like this.
