Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. May 12, 2020 at 12:52 PM
    #2201
    MakeShift
    MakeShift Member
    2005 Tacoma 4x4 DCLB
    Thanks for this thread. I used it to fix my overhead compass/temp gauge. Yay!
    Fitz235 likes this.
  2. May 14, 2020 at 8:34 AM
    #2202
    Dragon336
    Dragon336 New Member
    06 Pre-runner SRS Crew Cab
    3" lift, add-a-leaf in rear
    The soldering fix is a snap!! Saved $110+... Resoldered both 510 in no time... SERIOUSLY, DO THIS YOURSELF!
    Fitz235, 4WDTrout and Badderup like this.
  3. May 28, 2020 at 1:13 PM
    #2203
    drich1989
    drich1989 New Member
    Don
    2008 White Prerunner TRD Off Road
    bone stock(so far)
    couldn’t figure out what was supposed to be there! now i fixed it! :drunk:super easy!
    Fitz235 and Muddinfun like this.
  4. Aug 8, 2020 at 2:26 PM
    #2204
    LightedTaco4x4
    LightedTaco4x4 Active Member
    Andrew
    Eau Claire Wi.
    2005 TRD SR5 SPORT V6 Double cab.
    Map light mod, Fogs anytime, skid plate chrome painted, LED clearance lights, Hella Rallye 4000 Halogen Chrome off road lights, bed lights, interior LED cockpit lights, mud flaps, temp/compass repair. FJ cruiser alloy wheels, Air lift Air bags! and many more coming!
    ArizonaComa and Muddinfun like this.
  5. Aug 18, 2020 at 1:04 PM
    #2205
    SpyderMan
    SpyderMan Well-Known Member
    Morgan Hill, CA
    05 TRD
    Used this to redo mine. Eventually broke again and I am looking to replace it with a used one some point down the line. The instructions were flawless. My soldering skills...not so much.
  6. Aug 19, 2020 at 6:11 AM
    #2206
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    After repairing mine a couple times, I bit the bullet and spend ~$115 to buy the updated OEM Toyota module from a Toyota dealer on Amazon. I replaced it about 8 years ago, and haven't have another issue.
  7. Aug 19, 2020 at 12:16 PM
    #2207
    taco_jacko
    taco_jacko Active Member
    Jackson
    BC
    2022 TRD Sport DCLB
    Bilstein 6112 & 1/2” Spacer Bilstein 5160, 2 1/2” AAL & 1/2” block KMC Impact (17x9, -12mm) Toyo Open Country 285/75/17 JBA HC UCA
    Even if all the connections look good, gotta look a bit closer... noticed one of the solders only a 510 was a bit mangled, first try and fixed the problem.
    My LCD had the burn mark aswell.
    Thanks TW!!!!!!!!
  8. Aug 20, 2020 at 11:44 AM
    #2208
    SpyderMan
    Morgan Hill, CA
    05 TRD
    Interesting that mine had a burn mark as well on the board.
  9. Aug 20, 2020 at 11:48 AM
    #2209
    Muddinfun
    Muddinfun Well-Known Member
    The burn mark on the display is part of the manufacturing process. After it's assembled, they electrically light a fire inside it to burn off any remaining oxygen. The same thing is done with CRT monitors.
  10. Aug 20, 2020 at 2:47 PM
    #2210
    SpyderMan
    Morgan Hill, CA
    05 TRD
    good to know, thank you
    Muddinfun likes this.
  11. Aug 21, 2020 at 4:57 PM
    #2211
    RowdyRobby
    RowdyRobby Member
    Rob
    Southern California
    04 Tacoma TRD(RIP@374K), 07 Tacoma TRD, 22 Tacoma TRD 4x4
    Problem solved!! Thank you very much to the O/P, and all the contributors!! I especially appreciated the part about the clips in the front!! I'm notorious for pulling on stuff until it breaks, so it was good know that I wasn't going to do that this time around!!!
    So when mine went out we were somewhere in Arizona over July 4th weekend, way off about a 1/4 mile from the freeway, idling through a Del Taco when all of a sudden...the compass and outside temp went blank!! It was terrible, we barely survived!! Fortunately, we were able to limp our way to Nebraska to visit with family and back home...barely. I've been driving weeks now without these vital instruments and it has been a knuckle biter, especially with my antivirus mask on (for safety!) fogging up my glasses. I mean Death Valley just hit a record high of 130 degrees....and so that was it, I decided enough was enough and went on the search. Luckily, I found this post, and entirely 111 pages later (obviously this stupid temp/compass hits a real sort spot for everyone!), I ripped that bad boy out of there, gooped some solder on the worlds smallest resister that was ever made...the 'ol #510, nasty little buggers...and probably 15 minutes later, counting waiting for the soldering iron to heat up, like magic I'm facing South and it's 95 degrees outside again!! Ugh!
    Thanks again everyone!! -Rob
    Taco 422 and Asianguywithatruk like this.
  12. Aug 24, 2020 at 7:05 PM
    #2212
    Single2coil
    Single2coil New Member
    2007 Tacoma
    Method, is your business open?
  13. Aug 24, 2020 at 7:30 PM
    #2213
    Muddinfun
    He hasn't been on TW in about 10 months. Try contacting him through his website.
    https://siliconmethod.com/contact/
    DL at 8800 ft likes this.
  14. Aug 25, 2020 at 7:44 AM
    #2214
    Single2coil
    2007 Tacoma
    Muddinfun,
    Thank you for your link. SiliconMethod is open, I just got a reply to an email.
    Thanks again,
  15. Sep 10, 2020 at 2:56 PM
    #2215
    Reid865
    Reid865 Member
    Reid
    2022 Tacoma Access Cab Sport
    Thanks. This worked for me. However, I'll add that my circuit board looked a bit different than the one in the picture. My 510s were flat and more integrated into the board. They did not appear to be loose. I simply floated/reheated the solder already in place rather than adding any new or repairing an obvious broken connection, put it back together and it worked great. Thanks again.
  16. Sep 12, 2020 at 9:01 AM
    #2216
    Single2coil
    2007 Tacoma
    I had Method, link is above, rebuild my circuit board. Excellent job, installed and works perfectly. This is the place to go.
    They have the right tools and know how to do a top rated job.
    RL
    DL at 8800 ft and Muddinfun like this.
  17. Oct 15, 2020 at 5:53 PM
    #2217
    tacomage
    tacomage Well-Known Member
    Orange County CA
    I just want to say thanks for this thread! I took mine apart, and everything looked perfect as it should. No broken joints or burnt looking areas. It look just normal. I read others who had just added solder to the 510 resistors (even though there was no sign of damage) anyway as there was nothing to lose at this point. So I added solder to each of the 4 joints and voila it worked! Thanks!
  18. Nov 21, 2020 at 2:59 PM
    #2218
    irenemichelle
    irenemichelle New Member
    Did everything as directed here. No visible defects in the solder. Still, as other people here, I touched the hot iron to the solder and it worked!!!
  19. Nov 23, 2020 at 9:40 AM
    #2219
    The Romens
    The Romens New Member
    Hey Crew!
    New to TW, seems like a GREAT community!
    I have a 2010 2.7 4cyl Taco and wanted to upgraded the overhead console to the temp/nav gauge. Found one at a wrecker, 2009 unit and sensor. Installed and all I get are the dash marks (no temp numbers) and can't seem to calibrate the nav (only displays as 'N'). There was a stock sensor along the middle support in front of the rad with wires. I tried both the stock sensor and the sensor I got from the wreckers and no change to the display.
    Do I have the wrong gauge? (need the 2010 version?) Or can is it possible to make this one work and I am simply missing something?
    PLEASE HELP!
    Cheers
    crazytacoman and Hotrodroxie like this.
  20. Dec 9, 2020 at 9:51 PM
    #2220
    FishHook1963
    FishHook1963 New Member
    Howie
    British Columbia
    2009 Tacoma Double-Cab 4 x 4 TRD
    Pushbar, Canopy
    Thanks to all for covering this off. Prompted me to go to YouTube. Followed tips shown. When I opened up my overhead console, could not see any indication of a scorch or loose connection on the resistors. Was thinking I was screwed. Followed tips offered. Went ahead and re-soldered both resistors anyway. Worked like a champ! Seriously... took longer for my soldering gun to warm up than the repair did!!
    20-30 seconds to touch-up the connections. My dealer quoted me $1100.00!! They do not repair -- they replace. Crazy. Likewise, dash-lamp was out in the heater controls. Quote was minimum $125.00 to fix.
    Followed YouTube tips. Bought the bulb for $16.00. Took all of 30 seconds to pop it in, and push the panel back into place.
    Hotrodroxie likes this.
