Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Oct 21, 2009 at 9:57 AM
    #241
    619Tacoma
    619Tacoma Baja bound
    Call me Rocco
    San Diego, CA
    07 PreRunner SR5, Sport, 4dr
    - Billstein 5100's all around with OME 885 coil springs. - K&N Air Filter - HID Headlights & Fogs - Kenwood Stereo & Infinity Speakers - CB Radio, - Fog On Anytime mod - Anti Tailgate theft mod. More comming...
    You are probably right.
  2. Oct 21, 2009 at 8:18 PM
    #242
    woody55
    woody55 New Member
    Los Angeles
    SR5
    It happens with my truck too but it finds the right temp as I start driving. That's normal.
  3. Oct 24, 2009 at 3:34 PM
    #243
    TreeStump
    TreeStump New Member
    Alaska
    TRD Sport
    Great help! I now know how cold its getting in Alaska again. Thanks.
  4. Oct 27, 2009 at 10:55 AM
    #244
    ask
    ask Member
    SF Bay Area
    Going to give this fix a shot... Piercy Toyota just quoted me $1200 to fix this. Seems like this should be a recalled item not a 36 month / 36k warranty item.
  5. Oct 28, 2009 at 3:07 PM
    #245
    AZ Taco
    AZ Taco New Member
    Lee
    Phoenix
    05 Tacoma 4x4
    I was going to follow the advice found here to fix the temp/compass on my 2005 Tacoma but when I took the console off, the 510 chip was missing. I looked everywhere with no luck. Does anyone know where to get another 510 resistor?
  6. Oct 29, 2009 at 8:48 PM
    #246
    Boomer
    Boomer New Member
    Las Vegas NV
    06 PreRunner TRD
    Thank you! Thank you! Thank you!
    This fix is EXACTLY what I needed. I didn't read the entire thread, so maybe this was already mentioned: if you lose track of that metal clip the holds the overhead piece up (like I did), check the headliner real good. Mine ended up way over on the passenger side of the headliner. A 90 degree twist on the visor "clip" pops it loose so there is enough room to reach in there and grab the clip.
  7. Oct 29, 2009 at 9:28 PM
    #247
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    thanks for the info!
  8. Nov 5, 2009 at 6:18 PM
    #248
    botero
    botero New Member
    medford or
    05 tacoma trd sr5
    Thanks for the info and pics as mine hasn't worked since I got it but hopefully will soon. -b-
  9. Nov 5, 2009 at 10:09 PM
    #249
    misc
    misc [OP] Well-Known Member
    Good luck on the fix to all that have recently stumbled upon this thread. We're glad we can help.
    Hang out an learn some more about your truck...
  10. Nov 6, 2009 at 12:25 PM
    #250
    botero
    botero New Member
    medford or
    05 tacoma trd sr5
    Well I took it apart and the resisters looked good and soldered and weren't loose along with anything else so I decided to go ahead and resolder the 510's anyway as long as it was apart as I figured I had nothing to lose. Plugged it back in before I put it all together and turned on the power(key)...nothing, bummer, oh well put it back together and hit the on/off button not knowing what it was(never used it) and presto...magic display!! Thanks very much for the info and help, now just have to fabricate a small catch for the rear window slider latch as the old one was glued in to the slider frame and is gone and of course you have to buy the whole slider window for 700.00 to fix it...nothing that can't done with some small aluminum channel and a dremel tool eh. Thanks again. -b-
  11. Nov 8, 2009 at 2:00 PM
    #251
    Eddie81
    Eddie81 Member
    Los Angeles
    05 Prerunner
    Tint, Nerf Bar, Nitto TG, Konig Countersteer
    my console broke monday. I was checking this thread that same day cause I know TacomaWorld has tons of info. Borrowed the soldering iron from my uncle and tried it for the 1st time. I've never soldered before. I think removing the console is the hardest part. Then I checked Youtube on videos of how to solder. And bit the bullet to try it cause I figured its broken either way and there is no way in hell I paying close to $1000 for a compass and temp. I'll just buy a compass ball and stick a temp sticker on my window before I let toyota rip me off. In the end, I plugged everything back in, and prayed that it works and I didnt F**k anything else up. So if I can do it, anyone else can. Thanks for the help OP.
  12. Nov 11, 2009 at 5:40 AM
    #252
    coolreed
    coolreed Well-Known Member
    Reed
    OKC
    2019 Toyota Tacoma TRD Pro
    Goodyear Wrangler Dura Track Pro Tires, K&N Cold Air Intake, Pedal Commander.
    My overhead compass failed on my 06 Tacoma and I followed the instructions on this post. It worked like a champ. As soon as I touched one of the 510 resistors with a soldering iron the resistor came loose. This told me the other side of the resistor was unsoldered. Resoldered all the 510 resistors and reinstalled the compass and 'Viola' it works again.
    Great post! And an easy fix. Took me about 15 minutes. :)
  13. Nov 12, 2009 at 2:17 PM
    #253
    calicoupe
    calicoupe Well-Known Member
    mine took a dump today; going to try in a few minutes. thanks for the thread.
  14. Nov 12, 2009 at 4:36 PM
    #254
    segman67
    segman67 New Member
    Serge
    Mascouche Quebec
    Tacoma 2006 4x4
    I want to say, Thank you very much ! I just rewelded it , like your information, and it works.....like a charm.
  15. Nov 12, 2009 at 4:41 PM
    #255
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Damn nice post...I gotta do this...AGAIN! Only one of the 510s was soldered last time so it must be the other one ruining my life :frusty:
  16. Nov 13, 2009 at 7:43 AM
    #256
    morphius1023
    morphius1023 New Member
    norcal
    07 4x4 tacoma 4door
    3 in lift
    Thank you for this post post. My 07 Tacoma's gauge wasn't working and within 10 minutes, it was done- working perfect. The directions were exact!
  17. Nov 13, 2009 at 11:30 PM
    #257
    jerris
    jerris Well-Known Member
    jerris
    utah
    07 double cab, 6 inch fabtech 35 duratrac
    6 inch lift, 35 inch duratrac's
    hey i have the over head harness but not under the hood do you know where i can run two wires to so i could hookit up?
  18. Nov 14, 2009 at 8:35 AM
    #258
    macp
    macp New Member
    New Hampshire
    2006 TRD off road
    Great job on the fix. I just bought a 2006 with this problem and didn't know what to do until I joined this forum. Good move on my part. Easy fix. Thank You.
  19. Nov 17, 2009 at 8:54 AM
    #259
    DBowers
    DBowers New Member
    I just made this fix for a coworker. I resoldered both terminals on both 510 chips. It powered right up after it was reconnected. Very quick and easy fix.
  20. Nov 17, 2009 at 4:31 PM
    #260
    misc
    Welcome to the new guys that found TW via this fix. Glad we could help.
    There's alot more here than just this post. Check it out and stay a while...
    Rich
