Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jun 4, 2010 at 11:44 AM
    #501
    JKD
    JKD Well-Known Member
    It is not an LCD. It is a VFD (Vacuum Fluorescent Display). The mark is not a burn mark. It is an artifact of manufacturing a VFD.
  2. Jun 4, 2010 at 5:17 PM
    #502
    yamahamod
    yamahamod Active Member
    Korey
    Colorado
    06 Tacoma SC w/total chaos & King shocks
    Love this site! Fixed mine today and works like new again.
    I can't tell you how happy it makes me to fix it and not have to find one out of the junkyard.
    Awsome! Awsome! :)
  3. Jun 4, 2010 at 10:01 PM
    #503
    misc
    misc [OP] Well-Known Member
    Good job new guys... way to earn your own!
  4. Jun 5, 2010 at 6:59 PM
    #504
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    This write up was awesome. Thank you for the help, I had my Tacoma 5 days and the compass/temp quit. One of my resistors showed some discoloration, I soldered both and did the reinstall...nothing. Then I pressed the button and it works! Thanks again.
  5. Jun 5, 2010 at 7:24 PM
    #505
    HarryTaco
    HarryTaco Well-Known Member
    Pacific NW
    2016 TRD OR DCSB 4x4 V6 MGM
    Bed Mat, Bak Revolver Tonneau,
    This helped me knock $500 more off the truck when I bought it used. When I test drove I noticed that it wasn't working. As soon as I got home I googled it and it brought up this thread (how I found this wonderful site) I brought it up during negotiations and it worked. SecretSquirrel, I owe you a beer.
  6. Jun 5, 2010 at 7:25 PM
    #506
    misc
    LOL... I'll let you know when I'm in the PacNW... :D
    Congrats on the fix. Glad to help
  7. Jun 7, 2010 at 6:43 AM
    #507
    jgang
    jgang Well-Known Member
    Beers from me too Squirrel. Was about to call and deal with the stealership when I came across your fix. How in the heck did you figure out those chips had come un-soldered to the board? You can barely see them at all! I never would have found that. Anyway, all is well and working again in the Tacoma again thanks to your detective work. MANY THANKS for the writeup!!!
  8. Jun 7, 2010 at 12:35 PM
    #508
    LeadFootCaliKid
    LeadFootCaliKid It's a work in progress.
    Blake
    Temecula/North SD
    2005 DC PreRunner TRD Off-Road
    Total Chaos UCA's, Icon coil-overs, Icon gas reservoir rear shocks, Eagle Alloy 17", Nitto Terra Grappler 285/75/17, Flowmaster 40, Kenwood deck, and dual 10" Kicker subs, shorty antenna. There's more...
    does the temp. sensor need to be calibrated or something? ive noticed that mine always reads between 60 and 79 degrees. it doesnt seem like it ever reads right and its freaking hot right now. definitely not 72*F!!
    Chdog likes this.
  9. Jun 10, 2010 at 10:21 AM
    #509
    nintenDRU
    nintenDRU New Member
    andrew
    Huntington Beach
    2000 Tacoma 4x
    Camburg UCA, King w bypass Dover rear springs
    Another satisfied customer. Such an easy fix! Thanks!!
  10. Jun 10, 2010 at 10:23 AM
    #510
    victheyankee
    victheyankee Well-Known Member
    arizona
    upgraded sound system eclipse and alpine and mb wheels.
    I lost one of the clips.
    Does anyone know where I can buy them?
  11. Jun 10, 2010 at 5:40 PM
    #511
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I cannot believe how easy that was to fix. I'm amazed that I was able to accomplish that myself! THANKS!!!!!!!!!!
  12. Jun 13, 2010 at 5:24 PM
    #512
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Thanks for this write up
  13. Jun 15, 2010 at 6:22 PM
    #513
    Joeyvalley
    Joeyvalley New Member
    Exactly one year later mine went out again so I'm going to do it again soon.
  14. Jun 16, 2010 at 7:09 PM
    #514
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    just did mine, talk about easy, 10 minutes! back in business!!!
  15. Jun 18, 2010 at 2:32 PM
    #515
    straitmc
    straitmc New Member
    Houston
    06 Tacoma
    I have the same problem, but i am miising one of the 510 resistors. Does anyone know where i can find one?
  16. Jun 18, 2010 at 3:17 PM
    #516
    murph714
    murph714 Member
    06 TRD Sport
    Tube Step Running Boards, A.R.E. LSll Tonneau Cover, Rain Guards
    Refer to Post # 471
  17. Jun 22, 2010 at 6:21 PM
    #517
    WhyFlare
    WhyFlare New Member
    David
    Tampa, FL
    2005 Tacama Longbed Crewcab Silver TRD 4x2
    Stock.
    Help. I solder my 2005 and it work except resistor got very HOT. So hot, it melted the solder off and failed again.
    Has anyone else had this problem? Should I re solder both 510 resistors?
  18. Jun 23, 2010 at 2:01 AM
    #518
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    Even though the resistors heated up, chances are they are still good. Be sure your solder pencil is in good shape, heat up each of the two 510 resistors and remove them. Add a little solder and/or flux to make this easy. If you have access to an ohm meter, measure the resistance. If they're broken or read 20% higher or lower, replace them.
    Use eutectic solder (63% Tin, 37% Lead..Radio Shack sells it) and #2 solder wick. A little water-soluble flux would be very helpful.
    Now use the solder wick and completely clean all 4 pads to shiny condition. Clean each end of each resistor if they look grungy. A 3rd hand/girlfriend works great to hold the part with tweezers while you operate.
    Place the parts back on the board, solder the connections with new solder, and you're done. The connections should be bright and shiny.
    you've corrected the original problem with Toyota's supplier, which is contamination and poor soldering. :cool:
  19. Jun 23, 2010 at 9:45 AM
    #519
    RecklessTaco
    RecklessTaco Livin the Dream
    Topaz Lake, Nv.
    08 Dbl Cab Prerunner TRD Sport Debadged
    ENGAGE LT KIT, King 2.5x 8" coilovers w/600lb 18"coil springs, a custom built leaf pack in the rear by OMD, and a custom built prerunner bumper by SurfInferno. 35x12.50-17General Grabbers on 17x9 Black MB Wheels rims, Volant CAI w/Amsoil dry filter, Volant Ram Air, Poweraid Throttle body spacer, URD MAF Calibrator, Flowmaster40, Uniden Bearcat cb w/ 4' fire fly firestick antenna, & a Icom V80 Handheld(Modded for race channels)
    Well my compass/temp guage went out day before yesterday! So today at work i took it apart and one of the 510 resistors was completely off the board:eek:. I re-soldered it and it is working excellent:cool:. Thanks so much for the write up on this problem!:D
  20. Jun 23, 2010 at 7:48 PM
    #520
    Flugelhornjazz
    New England
    Man, I apologize for not including pics. I should have taken photos when my gauge stopped working and I pulled it to resolder the resistors. Oh well...You can clean the resistors after resoldering with rubbing alcohol on a toothbrush if you have a lot of flux residue. The residue will collect dust over time and possibly become conductive. Alcohol cleans the flux away, drys quick, and is harmless to all the other parts on the board. If the board and resistors are pretty clean, leave it alone and get busy doing something wild like installing that blower on the motor :cool:
    Tacos rule!
