Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jul 11, 2010 at 7:36 PM
    #541
    BigV
    BigV New Member
    Vern
    Layton, Utah
    07 Tacoma
    Found the thread and it worked just like described. Thanks so much! Easy repair and the images helped so very much. I would encourage annyone to give it a try!
  2. Jul 11, 2010 at 8:27 PM
    #542
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB Tacoma TRD Sport 4x4
    Great post, did this fix today, only thing is the 510 resistors look a lot bigger on these pictures than they are in person!
  3. Jul 13, 2010 at 12:55 PM
    #543
    MrJKC
    MrJKC KCCO!!!
    Nor-Cal
    Indigo Ink Toyota, TRD Sport, PreRunner, SR5
    6000k Bi-Xenon, 6000k Fogs, 3inch lift, Tint, Horns, Grill, Weather Tech floor mats - front and back
    I just had mine go out on my 08 TRD Sport. read this and tried it. Took Maybe 5 min. and it’s working again! Thanks for the write up!
  4. Jul 15, 2010 at 2:07 PM
    #544
    Tracy
    Tracy The Silver blurr...
    TRACY
    SoCAL. IE, SGV, LA. :D
    '08 TRD Sport Edition PreRunner
    Chrome tube steps. Because a lady needs a help up when wearing a dress. :)
  5. Jul 15, 2010 at 4:02 PM
    #545
    MrJKC
    MrJKC KCCO!!!
    Nor-Cal
    Just it again, on a friends Tacoma. She said it has not worked in over a year. She told me that Toyota said it would be a couple hundred to look at it and then probably a few hundred to fix.
    It takes longer for the soldering gun to heat up then it does to do the fix. I love it! J
  6. Jul 20, 2010 at 7:54 AM
    #546
    c17flyer
    c17flyer Member
    Adam
    OK
    '05 Tacoma Double Cab TRD Sport
    Are you kidding me? I'm clueless with stuff like this, but I did it in 15 minutes and it WORKED!!!
    Thanks to everyone for being willing to take 30 seconds and pass on information to other owners to save them BIG BIG money ... This was INCREDIBLE!!!
  7. Jul 20, 2010 at 6:55 PM
    #547
    Kritter
    Kritter Member
    06 4x4 SR5 crew cab long bed
    Tint, stereo, and stock size black GEAR wheels, BLHLM, tinted tail and 3rd brake light, satoshi grill mod, tactical redeployment lights under back bumper. fog light anytime mod. HID's,
    Mad Props to the secret squirrel!! saved me dough and the annoyance of looking at a busted OAT gauge all the time!!!
  8. Jul 21, 2010 at 7:46 AM
    #548
    Joeyvalley
    Joeyvalley New Member
    Ok so I just did the repair again for the second time and again it works. However I did break off one of the 3 plastic clips that holds the device in place, I think they become brittle with age and heat. Speaking of heat the next time I have to pull the console out I'm going to stuff insulation between the roof and the circut board because I think it gets extremely F'ing hot in that area and that is causing the resistors to pop loose.
  9. Jul 21, 2010 at 8:13 AM
    #549
    murph714
    murph714 Member
    06 TRD Sport
    Tube Step Running Boards, A.R.E. LSll Tonneau Cover, Rain Guards
    It can't get hot enough bettween the circuit board & the roff to melt the solder.
    I think the problem is the heat given off the circuit board itself.
    I don't think putting insulation between the board & the roof is such a good idea.
    63/37: melts @ 361 °F
    60/40: melts @ 361–374 °F
    50/50: melts @ 365–419 °F
    Lead-free melts @ 482 °F, depending on their composition.
  10. Jul 21, 2010 at 8:29 AM
    #550
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Mine quit last week, took apart and the 510s looked normal - no separation of solder that I could see.
    I re-did the joints on both 510s anyway and it worked perfectly.....thanks for the write-up!
  11. Jul 21, 2010 at 10:43 AM
    #551
    JKD
    JKD Well-Known Member
    If they're using RoHS-compliant solder, it might be a combination of heat from the 51-ohm resistors, and the natural brittleness of RoHS lead-free solder. Over time the joint may weaken and 'go bad' electrically.
  12. Jul 25, 2010 at 7:41 AM
    #552
    outd00rs
    outd00rs Member
    Virginia
    Tacoma 4X4
    Followed the instructions to the letter and it worked on the first shot back in the truck. Sorry I wasn't able to verify the 100+ temps around here but I'm pretty happy it cost me absolutely nothing to correct this.
    Thanks to everyone that wrote this up and took pictures. This was about as easy as it gets.
  13. Jul 25, 2010 at 5:41 PM
    #553
    Flugelhornjazz
    Flugelhornjazz '06 4.0L 4x4 6-sp MT Access
    New England
    06' 4.0L 4x4 6sp MT Access
    AFE CAI, all synth fluids, 2.5" exhaust w/ FlowMaster, Optima Deep Cycle battery, Fog mod, SnugTop cap, HID headlights, silicone hoses
    It wouldn't surprise me if yoda's sub-contractors are using lead-free solder. A very large number of consumer and industrial electronics manufacturers have switched, especially in California. Lead-free is difficult to get right. That would explain the wide-spread problem with the solder on the resistors on the circuit board working for awhile, then failing. :cool:
  14. Jul 25, 2010 at 8:47 PM
    #554
    klowie
    klowie Member
    Kris
    San Juan Capistrano
    21 White TRD 4x4 Off Road
    I had the same situation as Natroknot. I took it out, could not find anything wrong, but soldered the 510's anyway and it worked. Toyota wanted $147.50 for the part, and after struggling to solder the tiny 510 chip it started to sound like a deal. I am glad I did it myself though. Great write up again. This site is awesome!
  15. Jul 26, 2010 at 4:50 PM
    #555
    BLong
    BLong Member
    Denver
    Manual, Black SR5, TRD Offroad, Raised Topper
    Thanks! Worked great :)
  16. Jul 29, 2010 at 9:32 AM
    #556
    mkocpa
    mkocpa New Member
    SC
    06 Tacoma Access Cab 4x4 TRD
    I'm new to this forum, as a matter of fact, this compass/temp problem is what actually brought me here after researching this issue.
    I have a 2006 and the display went out a few months ago, so I visited my local dealer. What a complete waste of time. He informed me that he's had several with this problem and it would require a new unit to the tune of about $1,100. Obviously, I didn't jump on that deal.
    So, I ran across this forum and after pulling my console down and inspecting, I found one of my 510 chips was completely off. Luckily I found it and soldered and viola', good as new.
    Just wanted to sincerely thank everyone for this forum and help, what a great resource. Maybe someone should require the Toyota service managers to be members, they just might learn something instead of simply replacing parts at the expense of their customers who are unfortunately becoming victims of a great company reputation and degrading quality control.
  17. Jul 29, 2010 at 1:09 PM
    #557
    mad4sax
    mad4sax New Member
    Thanks to All. Another 2007 Taco fixed.
    Thanks for the pics ... great help.
    Took 15 minutes :)
  18. Aug 5, 2010 at 11:58 AM
    #558
    Biwwip
    Biwwip Member
    Ontario
    2006 SWB TRD Sport
    Repaired my '06 TRD Sport SWB just a few minutes ago. Many thanks to the original poster, and to all who offered additional advice.
    Took maybe 10-15 minutes total... 6 minute disassembly, 2 minutes soldering, and 4 minutes to reassemble. Worked first time, and I re-soldered all 4 connections. I did break one of the tabs getting the cover off, though... :^[
    My local dealer wanted (get this) $1,600.00 to replace it. So I think I'll take my wife out for dinner tonight with all the money I saved... ;-]
  19. Aug 6, 2010 at 1:57 PM
    #559
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    Worked for me thanks!
  20. Aug 8, 2010 at 5:05 PM
    #560
    ppleasants
    ppleasants Well-Known Member
    virginia
    05 TRD Sport Doublecab Longbed
    5100's set at 2.5", toytec AAL, DIY AUX port, broken mirror fix, temp/compass fix (twice), rattle-can gunmetal sport rims, debadged doors, fog-light anytime mod, DTRL mod, rear differential breather mod, drop in K&N air filter
    Fixed this in april and it just stopped working again. It could be the 100+ degree weather that we've been having lately. I resoldered and it works fine but does anyone know a more permanent fix? maybe a different resistor. And would turning off the display when not needed help preserve the soldering job? I'm not too savvy with electricity but would the resistor still be used if the display is off?
