Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Sep 29, 2010 at 2:47 PM
    #621
    highside7r
    highside7r Member
    TX, USA
    05 PreRunner SR5
    Blank canvas but ready, stock for not much longer...
    Thanks, first issue I noticed on my new truck, off to make this easy fix!
    Great job on the DIY sticky's!
  2. Sep 30, 2010 at 1:21 PM
    #622
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    Outstanding post... mine failed last month, I followed these instructions and it's good as new. It actually took me longer to properly replace the little clips that popped off during the disassemble than it did to actually solder the board.
    Note: if your console wants to sag away from the headliner when you press it back into place, simply open each clip with a pair of needle nose pliers, place the clip over the plastic pillion and then roll the clips' center retention tab, (the small one located inside the clip body) back snugly against the pillion itself.
    This keeps the clip at its intended location, seated low on the the pillion and restores the factory tension of the console to keep it firmly against the headliner.
    Good stuff OP! My wallet thanks you! :)
  3. Sep 30, 2010 at 7:43 PM
    #623
    Bluewater
    Bluewater Big Bruddah
    Kailua-Kona Hawaii
    Speedway blue 06 TRD Sport 4x4, 4dr, Long bed
    K&N Replacement filter, 3" leveling kit, Chrome side steps. Mud flaps removed.
    I tried to do it and must have fuc*&^ it up.. Temp came up along with direction and started flashing slowly then the display went black again.. WTF!!! So pissed!! Should I try resoldering?? Or just say screw it?? Anyone??
  4. Oct 2, 2010 at 11:19 AM
    #624
    cdcalpoly
    cdcalpoly New Member
    Sacramento, CA
    07 Toy Tacoma 4x4 TRD-Off Road
    Place some solder flux on the pads then try to solder down. If you have a multimeter, you can check for proper connection. Also heat up the pad and not the resistor, and let the solder melt onto the pad then the resistor.
  5. Oct 2, 2010 at 9:10 PM
    #625
    joes06tacoma
    Joe
    Central Coast, CA
    Thank you all you guys that have posted in this thread. I finally got to use this information today. Mine had been acting up for about six months, had it apart once and couldn't see anything wrong with the resistors. Finally quit completely and the broken solder joint was obvious this time. Soldered both 510s to be sure. Works great! Thanks again for the help.;)
  6. Oct 3, 2010 at 6:52 AM
    #626
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    just fixed mine the other day....
    thanks for the write up
  7. Oct 3, 2010 at 7:44 AM
    #627
    IslandBoy71
    IslandBoy71 Well-Known Member
    Reggie
    Lakewood, CA
    06 TRD PreRunner Sport SR5 DC
    TRD Intake,Flowmaster Super 10 exhaust, King 2.5 c/o adjusted to 3inch front and King 2.5 rears w/AAL. Custom bed rack, rock sliders and rear tire carrier.
    Great write up! did mine in less than 10 minutes,
  8. Oct 3, 2010 at 9:09 AM
    #628
    Przemekmsu
    Przemekmsu Well-Known Member
    Przemek
    South Jersey
    2006 Toyota Tacoma, SR5 V6, 4x4 TRD Off Road
    K&N Air Filter, WickedFlow Exhaust muffler
    Okay so I followed the write up from the link above and I got nothing. Basically everything is together. What I did noticed was a black burned looking spot in the bottom right corner of the display. (Pictures included). Do you guys think that this is the problem????????
  9. Oct 3, 2010 at 10:03 AM
    #629
    jns
    jns New Member
    ontario
    2006 BLK DCab
    cold air,cat back
    Did you solder the two ends of both 510's
    I dont' know about the black spot.
  10. Oct 3, 2010 at 10:31 AM
    #630
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I, like others, had the same burn mark. I don't know what that's all about.
    I soldered both ends of both 510 resistors and I am back in business. YMMV.
  11. Oct 3, 2010 at 10:38 AM
    #631
    joes06tacoma
    Joe
    Central Coast, CA
    I repair appliances. I've seen those black spots on microwave oven displays. I doubt that's your problem, check those 510 resistors really close. I took mine apart the first time and saw nothing wrong. Six months later the problem went from intermittent to completely dead. The resistor solder joint was obviously cracked at that point.
  12. Oct 3, 2010 at 6:26 PM
    #632
    MadTaco
    MadTaco Well-Known Member
    Bill
    Home: Kingsbay, GA **** Work: Southern M
    05 4X4 TRD Sport
    Factory Bars (Running Boards) ARE MX Series Topper Towing Package AFE Cold Air Intake (Magnum Force) Flowmaster American Thunder CAT-Back Bilstein 5100 and ToyoTec AAL (3" Lift) PA-TOY-15 Ipod/MP3 Adapter Fog Light Mod. *** UPCOMING *** Seat Covers Bull Bar
    Thanks for the hint. When mine fails I'll know what to do. You guys rock!
  13. Oct 4, 2010 at 3:45 AM
    #633
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
  14. Oct 4, 2010 at 8:20 AM
    #634
    netboy27
    netboy27 Well-Known Member
    NJ - Southern
    '16 TRD OR 4x4 DCLB
    2006 Lund with a 60 hp Merc 4 stroke
    Yo -
    After Toyota told me $200 for the whole thing, I found this link and was excited to be able to fix it cheap. I opened up my display and found one of my 501's WAS NOT THERE! It's undoubtably rattling around in my chassis somewhere.
    I found mutiple sites that talk about sending away for repair, including ebay. One of them (yes, I can't remember which) said use either a 51 ohm or 47 ohm resistor.
    Off the radio shack I went, spent $1.06 on 5 resistors, and poof, I'm in bidness...!
  15. Oct 4, 2010 at 8:22 AM
    #635
    netboy27
    NJ - Southern
    '16 TRD OR 4x4 DCLB
  16. Oct 4, 2010 at 8:24 AM
    #636
    netboy27
    NJ - Southern
    '16 TRD OR 4x4 DCLB
    Oh yea, this guy says the black spot is normal
    http://www.siliconmethod.com/
  17. Oct 4, 2010 at 10:19 AM
    #637
    2k6750
    2k6750 Well-Known Member
    Naples FL
    2005 SWB Prerunner Double Cab TRD Offroad
    Toytec coilovers set at 3", 5100 shocks all around, rear AAL and 1"block, 18" Moto Metal 951's with 285/60/18 Terra Grapplers, Leer Topper, de-badged, T-rex billet grille, BHLM, K&N intake, Jardine catback, Doug Thorley Long Tube headers, 8" kicker solo barik, Clarion 7" in dash dvd player. 12.1" flip down screen
    Looks like I'll be doing this on mine tonight. Driving to work today and the overhead display isnt working. I tapped on it and it came back on, but went away about 5 min later. I've got 70k and 5 years on my truck. Do I win for longest lasting?
  18. Oct 5, 2010 at 12:35 PM
    #638
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Add me to the list of successes. One of my 510's was bent about 45 degrees and snapped when I bent it back. Patience when attempting to solder a loose resistor.... Thanks.
  19. Oct 6, 2010 at 1:26 PM
    #639
    netboy27
    NJ - Southern
    '16 TRD OR 4x4 DCLB
    I don't know about that ;).
    My truck is a 2006, but has 128,000 on it. I think I have you beat if you consider "ON" time!:D
  20. Oct 6, 2010 at 1:44 PM
    #640
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Another success. I did the fix last week. As usual one of the resistors did not have contact, so I resoldered them all just in case. Dealership quoted me $60 for diagnosing the problem and then if the part was faulty around $250 for labour, and $800+ for the new part itself. Of course out of warranty. No thanks. All it took was 20 minutes and did not cost me a single dollar. Thanks again TW.
