Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Mar 3, 2011 at 9:57 PM
    #761
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    this post saved me hundreds of dollars... Thanks...
  2. Mar 9, 2011 at 8:45 PM
    #762
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    I was hoping to find a post here about this issue. You guys didn't dissappoint! I found both of the resistors had cold solder joints. Broke out my cordless soldering iron and had it repaired in less that ten minutes! Works great for now. Thanks for the help.
  3. Mar 10, 2011 at 11:51 AM
    #763
    tarandus
    tarandus Well-Known Member
    Montucky
    '17 TRD DCab OR Supah White
    ProComp/Headstrong leveling kit, AllPro rock sliders.
    I fixed mine last winter and it has worked fine until about a month ago. I'm going to try and solder it again this weekend, but am wondering if I did something wrong the first time?
    Any tips on soldering would be greatly appreciated ~ like can you really heat up the small plastic piece without melting it, or do you just heat the solder and melt it onto the chip?
    Thanks!
  4. Mar 11, 2011 at 7:00 PM
    #764
    LGE RAW
    Rob
    Dothan
    Got some pics to show the results.
    When opened, I found two resistors with cold solder joints.
    I pressed down with my fingernail and reflowed the solder by placing the tip of the iron at the edge of the resistor and the board. At about 5 seconds, I felt the resistor heating up and removed the iron. There should be enough solder on the board to hold the resistor, it does not take much. The result was nearly as clean as the originals.
    This looks like a process control issue at the factory where these boards were assembled. It does not appear to be an issue from over heating beyond the fact that the joints were bad to start with. The board shows no signs of the damage that would be done by currents high enough to melt this solder.
    It took about 20 minutes to remove, disassemble, repair, reassemble and reinstall. Well worth your time to check it out!
  5. Mar 13, 2011 at 9:58 AM
    #765
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    tarandus,
    See my writeup here for soldering tips and general recommendations for repairing the display. I'm not sure what you mean by heating up the small plastic piece...are you referring to the 510 resistor itself? If so, then yes...apply iron tip the the metal end segments of the resistor, and simultaneously feed in a bit of solder. Don't put solder on the iron and transfer it that way.
    Note that I don't recommend using your original resistors...the metal is oxidized, and solder won't adhere well to it. You will only get a temporary repair. Do it right by buying replacements at radio shack (see the writeup for more info.) Good luck!
  6. Mar 13, 2011 at 10:33 AM
    #766
    stabngrab
    stabngrab Active Member
    Louisiana
    '17 TRD Off Road 4x4
    Bought my truck thinking that my busted compass unit was just a small price to pay, until I read this post. Took me about 20 min and has been working flawlessly since. Thanks for the tip.
  7. Mar 13, 2011 at 7:08 PM
    #767
    tbone12
    tbone12 j.o.w.c.o.
    Terra
    central valley california
    success!! let's just hope my new found soldering skills will do the job!:woot:
    thanks again
  8. Mar 13, 2011 at 8:46 PM
    #768
    waynorth
    waynorth New Member
    Anchorage, AK
    05 Tacoma V6
    Hey, great fix. Glad I found this thread.
  9. Mar 14, 2011 at 5:26 PM
    #769
    BlueBullet
    BlueBullet New Member
    Canada
    07 Blue SR5 DblCab
    Any chance of getting a picture of the axial lead resistors soldiered in place ... showing the orientation of the coloured bands? (I'm assuming the direction matters?) A pictures worth a thousand words as they say ... especially for us 'electrically-challenged' types
    Thx
  10. Mar 14, 2011 at 7:15 PM
    #770
    LGE RAW
    Rob
    Dothan
    Resistors can go in either way.
  11. Mar 14, 2011 at 10:26 PM
    #771
    waynorth
    waynorth New Member
    Anchorage, AK
    05 Tacoma V6
    No pics, but it was just soldering the #510 resistor back in place. I got the pics I used off of this thread.
  12. Mar 16, 2011 at 3:07 PM
    #772
    morgancr
    morgancr Member
    Mo
    orange county
    06 TRD Sport 4x4
    Amazing!! bought my tacoma with my overhead display not working. saw this thread and thought i would give it a shot. neither of my 510s looked disconnected so i went ahead and soldered all 4 sides anyways and sure enough, BOOM!!! like magic i got my temperature and my direction back. so stoked!! thanks for the help!!! and a side not: those suckers are frickin small and they are not easy to solder just to give you a heads up.
  13. Mar 17, 2011 at 5:54 PM
    #773
    stratton
    stratton Well-Known Member
    My display went out last week. Just under 40,000 miles on it. I remember reading this thread a while back. Just wanted to say thanks. Worked like a charm. My soldering skills our really terrible. But it works. And those 510's are smaller then i thought. My iron tip was to big.lol
  14. Mar 19, 2011 at 9:02 PM
    #774
    poodleracer
    poodleracer Member
    Josh
    Monterey
    White TRD Offroad w/ Locking Diff
    Hey Guys,
    I'm new to this site looks like a great source of information. Does anyone know if you can tap into this power source to power a GPS or Radar Detector? It would be really clean to mount either of these above the rear view mirror.
  15. Mar 20, 2011 at 12:17 AM
    #775
    LGE RAW
    Rob
    Dothan
    most likely, but make sure that the radar detector is 12v. Most GPS units have a circuit in the cig. plug that drops the voltage to 5v for the USB input. If you direct wire, you will fry your GPS. You probably can get a cig. plug adapter with a USB out and shove it above the head liner. Or a 12v jack that you can plug your GPS plug into, and shove that above the headliner.
  16. Mar 25, 2011 at 6:29 PM
    #776
    sell66
    sell66 New Member
    Hi All,
    I opened up my overhead compass/temp computer and saw that one 510 resistor was completely missing. Does anyone know the specs on the resistor such as ohms, watts, etc. so I can buy a new one. Any help would be greatly appreciated.
    Sincerely,
    David
  17. Mar 26, 2011 at 3:41 PM
    #777
    mattb1968
    mattb1968 Member
    Monrovia, CA
    07 TRD off road
    Pioneer in dash navigation
    That's awesome! if I knew it was that easy, I'd have done it months ago.
    Thanks for the great right up!
  18. Mar 29, 2011 at 3:03 PM
    #778
    Memphis Taco
    Memphis Taco Member
    Bartlett, TN
    Thanks for the post. Worked like a charm!
  19. Mar 29, 2011 at 3:17 PM
    #779
    TFT
    TFT New Member
    Troy
    Mountain View, Ca
    Tacoma
    I have had to do this twice now, nice to see its not just my truck with the problem..
    The first time this happend i was going to send it in to a place thats fixes these, but i saw that 510 thingy was off the board at a 30 Degree angle.. Just re-soldered it, and it worked fine.. I dont know if the 510 thing gets hot or if its my bad soldering, but it has come off again.. It is currently working!
    Thanks for the post..
  20. Mar 31, 2011 at 8:45 PM
    #780
    1Baddtaco
    1Baddtaco Member
    Sacramento
    06 PreRunner SR5 LongBed
    KN Amsoil fluids BFG Long Trails 265/70/17
    Awesome!! Worked liked a charm. I feel pretty good and prideful.
