Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jul 11, 2011 at 2:28 PM
    #881
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Nice Thread. Compass went out today and got fixed today. Thanks!:headbang:
  2. Jul 11, 2011 at 5:35 PM
    #882
    Hbsurftaco
    Hbsurftaco Member
    Zack
    HB
    05 Prerunner Trd sport SR5 3" lift
    great post! Had everything i needed at home.
  3. Jul 12, 2011 at 2:23 PM
    #883
    MT_mudflaps
    MT_mudflaps Just playin' on the runways
    Clint
    Bellflower, CA
    Indigo SR5 PreRunner with TRD off road
    I just completed this fix today. Thank you for sharing -- sure saved me some coin! ;)
  4. Jul 12, 2011 at 6:08 PM
    #884
    Curtamous
    Curtamous Member
    Austin, Tejas
    06, TRD Off Road, Super White, SB..
    Damnit.. mine went out. I attempted soldering both, although neither showed they were loose. One of the 510's came loose during surgery and I put it back the best I could. Then soldered the sides of the other... plugged it in and it began to smoke.. My LCD has the burn smudge on the corner as well. Guess i'll take to a professional to resolder and cross my fingers? Those things are so dang small!
  5. Jul 13, 2011 at 2:56 AM
    #885
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    Curt,
    Did you happen to see what component let out the magic smoke? Chances are you had a solder bridge that went to ground; usually a transistor burns up when that happens.
    -greg
    Repair your broken Tacoma compass
  6. Jul 13, 2011 at 9:57 AM
    #886
    Case98
    Case98 New Member
    New York State
    Black TRD sport
    As several other people have said the resistor 510 looked okay so I soldered both resisters on both ends. And now it works perfectly. Thanks everyone
  7. Jul 13, 2011 at 10:02 AM
    #887
    J4RR
    J4RR Well-Known Member
    The OC
    07 DC LB TRD SPORT 4X4
    Mines been out for over a year, just never got around to fixing it. Took me less then 5 minutes, great fix. Resistor is really small so take ur time!
  8. Jul 13, 2011 at 11:21 AM
    #888
    sloppyjoe
    sloppyjoe They are more like guide lines.
    All Over
    Silver and simple
    Non
    Very true, the pictures in the write up make you think it is a much larger item you are looking for. But it is not hard to locate once in there looking at it.
  9. Jul 13, 2011 at 5:33 PM
    #889
    patwrik
    patwrik Well-Known Member
    San Diego, CA
    05 DBL CAB
    LOL, mines been out for 3+ years...Thanks OP...
  10. Jul 17, 2011 at 3:25 PM
    #890
    sioux_hockey_guy
    sioux_hockey_guy Well-Known Member
    Bismarck, ND
    Black '08 TRD OR 2" Leveled
    Eibach front springs, Billstein 5100's set at .85" Rear blocks (1.5"?) w, TSB. To be replaced w/ AAL
    Thanks for the writeup. Buddy just stopped by with his solder pen and everything works. It was hanging at a 45 angle so it was obvious what the problem was. Thing is I wouldn't have pulled it down if it wasn't a common problem. Gotta love TW! + rep your way OP.
  11. Jul 25, 2011 at 11:37 AM
    #891
    poodleracer
    poodleracer Member
    Josh
    Monterey
    White TRD Offroad w/ Locking Diff
    Thanks for the write up worked like a charm took me about 25 min total. When I pulled the lens off the circuit board i saw that the screen had a burn mark on the inside near the corner like a light bulb looks after it has burned out. At that point I was not sure i could fix it. Also, both 510 resistors had small cracks in the solder joints. I re-soldered both, crossed my fingers, and plugged it in. When it lit up like normal I gave myself a high five and went on my way.
    Good Work on this tip!
  12. Jul 25, 2011 at 1:50 PM
    #892
    avalos13
    avalos13 New Member
    Teri
    Tucson, AZ
    TRD Sport
    Your post was very helpful. Just fixed mine yesterday. Thanks!!
  13. Jul 25, 2011 at 4:48 PM
    #893
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    im sure its in here somewhere but what kind of sodder do i use lead or lead free does it matter
  14. Jul 25, 2011 at 11:39 PM
    #894
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    As long as it is rosin core ur gtg
  15. Jul 26, 2011 at 7:40 AM
    #895
    anvilmanco
    anvilmanco Active Member
    Aurora, Colorado
    07 Tacoma TRD Sport -Stock
    What a great Forum this is. I recently got a 2007 with the Temp / Compass display but it's so dang dim, I can't hardly read it. Do you all think it could be failing? I don't know if they were really bright originally. I'd sure like to make it easy to see.
    Thanks,
    Keith
  16. Jul 26, 2011 at 1:48 PM
    #896
    tacoman2011
    tacoman2011 New Member
    San Jose California
    2007 Toyota Tacoma Prerunner 4x2
    I did this today at work and now my compass and temp gauge works!! YEEEEEhaW
  17. Jul 29, 2011 at 11:58 AM
    #897
    jward
    jward Member
    Jeff
    ohio
    06 TRD Access Cab 4x4
    None yet
    Mine quit workin completely. Is that what yours did, or did you just have screen probs like the other guys.
  18. Aug 1, 2011 at 10:27 PM
    #898
    SirGeoff
    SirGeoff Well-Known Member
    Geoff
    West Coast - Vancouver Island, Canada
    2006 SR5
    Thanks Squirrel, another happy Forum reader. I did manage to break one of the small plastic clips on the elelctics cover, but a peice of electival tape holds it on just fine. One of my 510's had fallen off altogether bu I found it on the floor, and resoldered it.
    Now I feel ready to take on replacing the sterring Wheel Clock-spring for the airbag; and then, if I can find parts at a wreckers, I will add fog lights, switch and relay to my pre-wired 06 Tacoma.
    With that expertise I can then start charging my friends the $84/hr Toyota rate - one sure way to lose friends, just as my Toyota Dealer has lost me as a customer!!!
    Many thanks...
  19. Aug 2, 2011 at 11:24 AM
    #899
    avalos13
    avalos13 New Member
    Teri
    Tucson, AZ
    TRD Sport
    At First the reading was fading, then completely stopped working. I printed out the step by step instruction on how to fix and now it works just fine.
  20. Aug 2, 2011 at 3:18 PM
    #900
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    So I originally tried to just re-solder the existing resistors...plugged everything back in, no worky...
    Then I found a guy on here who had purchased a bunch of replacement resistors, he said he would be more than happy to send two of them my way in hopes that that would fix it...got them soldered in today.... still no worky...
    any ideas guys?
    btw thanks beaver_scott for helpin a forum brother out and sending those resistors my way free of charge...rep for you sir!
