Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Aug 2, 2011 at 8:26 PM
    #901
    tjphife
    tjphife New Member
    TJ
    Colorado
    07 TRD Quadcab Offroad
    I just did this process to my 07 Tacoma and it worked great! Thank you for posting up such a thorough write up. Both of the resistors were unsoldered from the board. One resistor detached completely from the board. I soldered both ends of both resistors to the board. Thanks again.
    -Travis
  2. Aug 3, 2011 at 12:47 PM
    #902
    fat.tires
    fat.tires New Member
    05 SR5
    2" lift, tinted windows
    Step 1 DIY - re mounted the existing 510's. It worked for a while then went dead again.
    Step 2 DIY - went with the axial lead resistors that Silconmethod has recomended. No luck, something else must have come loose or fried.
    Step 3 - Sending my board to Greg at Siliconmethod today!
  3. Aug 5, 2011 at 11:41 AM
    #903
    Raddbus
    Raddbus Well-Known Member
    Russell
    Santa Maria
    TRUE BLU TACO
    Illuminated 4X4 switch, 3" lift,
    Just got in my truck this morn and the temp/compass isn't working again. Will have to check it when i get home, will re-solder again.
  4. Aug 5, 2011 at 1:34 PM
    #904
    CanuckPT
    CanuckPT Member
    Damon
    West Chestefield, NH
    2006 Tacoma Sport
    ARE Cap with Yakima Rack Sno Way Plow Curtiss Speed Cast Sander
    Thank you for such detailed instructions with the photos!!! I stopped and bought a soldering iron on my way home from work today and in about 15 minutes those beautiful orange lights above my head were lit back up!! I really appreciate your efforts - it's easy to do everyone!!! :)
  5. Aug 7, 2011 at 11:45 AM
    #905
    pl87pll
    pl87pll Member
    Preston
    Georgia
    06 Tacoma 4wd Access Cab
    K&N Cold air intake,Dual exhaust Magna Flo.
    I am about to do this repair and I was just wondering how do you go about reseting it once you finish so it can read the direction correctly?
  6. Aug 7, 2011 at 5:28 PM
    #906
    bradpenton
    bradpenton Well-Known Member
    Birchwood, TN
    TRD Sport 4WD
    Awesome fix. Mine was hanging on by one side when i opened it up. Thanks for the detailed pics. I owe you one as well.
  7. Aug 7, 2011 at 10:12 PM
    #907
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
  8. Aug 8, 2011 at 9:40 PM
    #908
    yamabiker
    yamabiker Well-Known Member
    Utah
    2006 Double Cab SR5 TRD
    The compass/thermometer in my 2006 DC Taco has gone out. I will be trying out this fix. Thanks Taco Brothers
    Yamabiker
  9. Aug 11, 2011 at 7:23 PM
    #909
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Hey guys. First timer here - first post, first Toyota. Straight away - this thread is awesome! Add yet another hot iron fix! Just bought a 07 Tacoma with a "busted" accessory display. Discounted accordingly and fixed in a flash! :)
  10. Aug 11, 2011 at 7:26 PM
    #910
    elmo7
    SC
    07 DC TRD OR 4x4
    There's a page in the manual that tells you what to set it to based on your part of the country; like a time zone, if you will. Plus there's a drive in a circle procedure to reset it if necessary.
  11. Aug 13, 2011 at 10:05 PM
    #911
    fat.tires
    05 SR5
    3rd time's a charm - Returned to me in working order for $49 in under one week. Nice work, thanks Greg!!!
  12. Aug 14, 2011 at 4:31 PM
    #912
    dirtySD
    dirtySD Member
    San Diego
    19' 4Runner TRD Off-Road Premium
    i wanna get this done this tonight but i was just wondering if theres a special type of solder i should be using? can anyone let me know? help would be appreciated
  13. Aug 14, 2011 at 10:22 PM
    #913
    Siliconmethod
    Greg
    MO
    You are quite welcome!
  14. Aug 14, 2011 at 10:25 PM
    #914
    Siliconmethod
    Greg
    MO
    Use standard 60/40 solder w/ rosin core, and use a thin diameter such as .032".
    Don't use large diameter, acid core, RoHS, high temp, or any other types of solder.
    You can find the recommended type at Radio Shack or equiv for a couple bucks.
  15. Aug 15, 2011 at 12:13 PM
    #915
    yamabiker
    Utah
    Well that was easy. One of the 510 resistors(assuming they are resistors) came off the circuit board with just a touch. I soldered both just to be safe. Plugged it back in and bingo. Compass & thermometer is back.
    Interested in how long this fix will last. How long as yours been working? I beefed up the solder connections as much as I could.
    Thanks again Taco Brothers
    Yamabiker
  16. Aug 16, 2011 at 2:59 AM
    #916
    Foxer1984
    Foxer1984 Member
    Luray
    05 Tacoma TRD SR5
    I just fixed the compass/temp in my 05 thanks for the instructions.
  17. Aug 16, 2011 at 8:41 AM
    #917
    Landon07
    Landon07 Member
    Landon
    North Carolina
    07 4x4 trd off road, speedway blue
    k&n air filter, bull bar, 3" rough country lift
    do you have to worry about the computer board melting when soldering?
  18. Aug 16, 2011 at 6:24 PM
    #918
    deerslayer75
    deerslayer75 Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    Can the led's be changed in there to make it a different color? If so how many are in there?
  19. Aug 16, 2011 at 11:36 PM
    #919
    Foxer1984
    Foxer1984 Member
    Luray
    05 Tacoma TRD SR5
    I dont know if it would melt the board. I'm sure mine got pretty hot because I'm not the best at soldering so it took a little while and mine works good so far.
  20. Aug 17, 2011 at 7:03 AM
    #920
    deerslayer75
    Tim
    jersey shore
    Anyone else tried to change the color of the led's in there? How many are in there? Are they the same as the cluster?
