Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Sep 1, 2011 at 3:11 AM
    #941
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    I fixed mine last Friday. Thanks to this thread. I sure hope it last for more than a couple of months.
  2. Sep 2, 2011 at 4:31 PM
    #942
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    If you are still needing the metal clip, the part number is 90084-46017. My dealership had them in stock for $1.71 each.
  3. Sep 4, 2011 at 4:33 PM
    #943
    pmosin
    pmosin Well-Known Member
    SoCal
    07 Access Cab 4x4 TRD 6spd
    ARE Camper shell
    thanks for this post. This happened on my 07 Taco a month or two ago.
    Took it apart, soldered the 510 resistors and tried it. Make sure to press the compass/temp button a few times; in my case it was off by default.
    Worked like a charm, like others said, despite the fact that the soldering is sloppy. Thanks for the cheap and easy fix! Easy enough for a noob like me to do it.
  4. Sep 4, 2011 at 9:53 PM
    #944
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    then what is this thing with the black mark on the corner?
  5. Sep 8, 2011 at 10:02 AM
    #945
    steveni70
    steveni70 Member
    CO
    07 TRD OR DCSB
    I just got around to trying this. Worked like a charm, except I forgot to push the button at first and figured it was still broken. I couldn't see or feel any separation at the resistor, but put a multimeter on it and wasn't getting any reading. I just touched the soldering iron to it and got a little solder on there.
  6. Sep 8, 2011 at 8:26 PM
    #946
    MikeChestnut
    MikeChestnut New Member
    The compass/temp on my over head console went out about a month ago and I called Toyota and they said that it is somewhat common for this to happen; and they wanted $900 to replace it, including labor. I read this thread and thought I'd give it a try. The step by step instructions were VERY simple and when I looked at the resistors, I couldn't see any problem at all. I used a magnifying glass and still couldn't see a problem. So, I decided to give the solder a shot any way because I figured I had nothing to loose. I put a little solder on both ends of both resistors. When I plugged it back in, it worked PERFECTLY!! What a great money saver. The whole process took me less than 20 minutes and didn't cost me one cent!:D
  7. Sep 8, 2011 at 10:12 PM
    #947
    hypeitup
    hypeitup Well-Known Member
    Jackson Hole Wy
    2005 TRD Sport Indigo
    Ome 3" full suspension lift with added toytec topplate spacer
    did anyone else break a clip on the plastic housing. Crazy glue?
  8. Sep 9, 2011 at 12:26 PM
    #948
    ashpaker
    ashpaker New Member
    Vancouver, BC Canada
    07 TRD Sport 4X4
    Hey - am new to the Tacomaworld. This fix has been successful for people that have the burn mark on their displays? i've tried re-soldering the resistors (the ones marked 510), no dice. replaced the resistors with wire 47 ohm ones, still no dice. any suggestions.
  9. Sep 10, 2011 at 4:52 PM
    #949
    bermslider
    bermslider Well-Known Member
    Squampton, BC
    Double Cab 07 TRD Sport
    K&N Air Filter. 17" XD Revolvers wearing Hankook Dynapro ATM's 265/70/17 treads. Bilsteins in the Front set at 1.75". Debadged. Tail lights tinted.
    Finally borrowed a mates soldering iron and did this. It took, like 30 minutes! Cant believe how easy it is to fix and Toyota want to charge a shitpile for it! Thanks again TacomaWorld!! So Stoked!
  10. Sep 14, 2011 at 2:37 PM
    #950
    PedalDan
    PedalDan New Member
    Santa Clara CA
    Tacoma TRD 4x4
    Smoke LED Tailights Konig Black Alloys
    Thanks for this thread, just completed mine. I have a 05 when I looked at the chip it was standing straight up! One side of the chip was not connected but when I pushed it down to resolder the second side came loose.
    I grabbed my solder wick and cleaned both terminals. Resoldered, reassembled and it worked!
    I'm stoked! Its been out for about two years now. I finally scored a soldering station for some mod's on my Fender Blues Jr. I remembered googling and finding threads about this fix.
    Total time was about 30 minutes.
    PD
  11. Sep 15, 2011 at 10:08 PM
    #951
    Grillya
    Grillya New Member
    ca
    o6 4x4 sr5 trd
    6" fabtech lift,18" rims w/ nitto dune grappler rubber, K & N intake, throttle body spacer, spintech exhaust, Toyota billet grill
    worked great......broke one plastic clip but shit, didn't make a difference glad to have it working.......BIG THANKS!!!!!!
  12. Sep 15, 2011 at 10:53 PM
    #952
    PaidUpTruck
    PaidUpTruck Well-Known Member
    San Antonio, TX
    Tacoma TRD Off-Road 4x4
    Wife noticed that the compass and temp was not working this morning. I remembered reading this thread months back so I searched for it and sure enough, the 510 resistor was the culprit. Before I soldered it, I looked under a magnifying glass and I saw a hairline crack on the solder.
  13. Sep 15, 2011 at 11:50 PM
    #953
    JKD
    JKD Well-Known Member
    The thing with the black mark in the corner is a Vacuum Fluorescent Display. It is essentially a picture tube like an old monitor or television, but using multiple electron emitter points instead of a scanning electron beam (so it can be flat and shallow).
  14. Sep 15, 2011 at 11:57 PM
    #954
    JKD
    There is no burn mark on the displays. The mark you refer to is a "getter", a spot of material that is a result of the manufacturing process. It is heated by RF to adsorb remaining oxygen in the tube after drawing a vacuum and sealing the glass envelope. All of the displays have that mark, and the repair works in almost all cases.
    It is possible your unit has problems other than the common broken resistor solder points.
  15. Sep 16, 2011 at 1:55 AM
    #955
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    @JKD: Good explanation of VFD's. Also, thanks for filling me in on what the 'getter' is. I assumed it was where the vacuum was drawn, but I was incorrect. The oxidation mark makes more sense...bind up the O2 instead of expending energy to draw it out.
    An interesting note: if you shine a UV light source on VFD's, they will glow due to the phosphors.
    For the folks who haven't opened their clamshell to get at the circuit board, please read my DIY guide here. So many of my repairs have previously broken clips because they were opened wrong!
  16. Sep 17, 2011 at 7:01 AM
    #956
    mme
    mme Member
    Mary
    Ruston, Louisiana
    '07 Tacoma 4wd
    Nerf bars
    Fabulous!! So easy. Thanks to whoever posted these instructions.
  17. Sep 18, 2011 at 3:30 PM
    #957
    floridaoccifer
    floridaoccifer Civil Servant
    Took the truck out yesterday for a spin and noticed my compass fading in and out... by the afternoon it was dead. I opened the console and flowed the solder marks on the indicated area as directed... PERFECT!!!
    I really really appreciate this forum and all of its contributing members.
    Thanks again
  18. Sep 19, 2011 at 5:28 PM
    #958
    asalik
    asalik Member
    Allan
    Texas
    prerunner trd
    Great fix just as described...Thanks for the info!
  19. Sep 22, 2011 at 4:47 PM
    #959
    StarBoy
    StarBoy New Member
    Thanks for the excellent instructions. Nothing broke, found the clips and the 510 resistor had a broken solder joint. I soldered both sides and it works like a charm. I was going to have to buy the compass/temp module for $150.
    Thanks again.
  20. Sep 22, 2011 at 5:21 PM
    #960
    SKULLY
    SKULLY Well-Known Member
    Dave
    San Diego
    06 DCSB
