Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Oct 16, 2011 at 11:25 AM
    #981
    mme
    mme Member
    Mary
    Ruston, Louisiana
    '07 Tacoma 4wd
    Nerf bars
    Just do it. Too easy.
  2. Oct 17, 2011 at 4:09 PM
    #982
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    i just bought a truck and mine wasnt working im so taking mine apart 2moro and gonna see if that fixs it. i was already gonna call toyota and a junkyard i use to work for Lexus toyota scion so i get good discounts but cant beat that fix. thanks!!
  3. Oct 19, 2011 at 8:45 AM
    #983
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    WooHooo! First Post! Very easy. My soldering iron did not have a fine point and I was afraid I was going to burn the resistor. I "tinned" and loaded the tip, touched the contact, and brought in more solder to the tip. Works!
  4. Oct 20, 2011 at 12:47 AM
    #984
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Great job Greg.:woot:Thanks.Rack of green for you.:thumbsup:
  5. Oct 23, 2011 at 12:56 PM
    #985
    zachmagee
    zachmagee New Member
    Zach
    Baton Rouge, Louisiana
    So i feel like this is kind of a silly question, but does anyone have a picture of what im soldering or can someone describe what it is that i need to solder? Mine isn't working so i have it all taken apart and just need to know what it is that needs to be soldered.
  6. Oct 23, 2011 at 1:48 PM
    #986
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Go to post 38. Good luck!
    http://www.toyotanation.com/forum/sh...=172978&page=3
  7. Oct 25, 2011 at 4:55 PM
    #987
    Dorbs2457
    Dorbs2457 New Member
    Sean
    Colorado
    4 inch lift
    Mine went out Monday, gave it a good smack today and it's working again. If it goes out again I'll be doing some soldering!!
  8. Oct 26, 2011 at 1:31 PM
    #988
    MistaLos
    MistaLos Member
    New Mexico
    Super White TRD SR5 OR 4X4
    Removed mud flaps, plasti dip door badges, removed the rest, plasti dipped stereo council as well as shifter council, tailgate lock (hose clamp)
    That's exactly what mine was doing before it finally went out. It just recently went out again so looks like I'm soldering for a second time :mad:
  9. Oct 29, 2011 at 9:57 AM
    #989
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    just started noticing this on my truck. looked up yesterday and noticed it was out. looks like ill be pulling it apart and checking the connections. makes sense to me as ive already checked the fuses and all are in good condition.
  10. Oct 29, 2011 at 12:00 PM
    #990
    USAFVol
    USAFVol Well-Known Member
    07 TRD Sport
    Mine went out a few weeks ago, found this thread.
    My 510's didn't look disconnected or messed up. I also had the burn mark on the LCD.
    I gave it a try anyways and it worked. How long, I do not know.
    While I had the console down, I popped the map light covers off and put in LED's. A good combo mod/fix if its on the list.
  11. Oct 31, 2011 at 3:22 PM
    #991
    BoTacoGA
    BoTacoGA Damit man
    Bo
    Newnan, GA
    08 Rugged OffRoad TRD
    Hid headlights an fog lights, LED blinkers an brake light bulbs. anytime fog light mod, brighter reverse light mod, Access Vanish bed cover, color match grill, black rocker guard painted skid plate, rear TSB, 5100's with front set at 1.75, BF T/A KO 265/75/16, yo mama riding shotgun.
    Just did mine today. It works again. Thankx!!
  12. Nov 1, 2011 at 7:06 AM
    #992
    laroe
    laroe New Member
    Ross
    Granville, OH
    07 Tacoma 4x4
    What happened to the pictures?
  13. Nov 1, 2011 at 7:15 AM
    #993
    Jez
    Jez Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    Good write up! Thanks to this thread I was able to fix mine! About a months after I fixed it the dang thing went out again....had to re solder the heck out of it and now it has worked fine for over a year!
  14. Nov 1, 2011 at 12:15 PM
    #994
    toyotatacomaTRD
  15. Nov 1, 2011 at 4:08 PM
    #995
    Greg S
    Greg S New Member
    I imagine that's about all it needs in most cases. It was for me anyway. I do have to ask what people are using to see that the solder has come loose? A microscope. All I saw was some oxidation on the resistor's solder joints. Brushed it away with new toothbrush, put it back together and it worked. I wouldn't worry about the hot days. Doubt very seriously that the heat from overhead could deteriorate a solder joint. Anywho, thanks to the OP for instructions on how to take apart and put back.
  16. Nov 2, 2011 at 5:04 PM
    #996
    elario07
    elario07 Member
    Eli
    Wichita, KS
    Taco Trail
    Replace tweeters for Subaru plug n play kickers. Also replace front and back speakers with kickers. Added a Kenwood KSC-PSW8 250W Max (150W RMS) Single 8" Under Seat Powered Subwoofer Enclosure W/Remote Control. I went with Kenwood because it’s the same as JVC but cheaper.K&N reusable filters for engine & cabin
    Thanks fot the tip. I just encounter that problem. It was an easy fix I had a reading glasses repair kit. I simply grab my lighter heated the tip of the flat screw driver. once it got red I place it on the "510" and easy fix I did not have to spend money.
  17. Nov 6, 2011 at 6:09 AM
    #997
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Again Tacoma World comes through with flying colors. Since the temp was just about freezing this morning I warmed my truck up to first keep me warm and then to warm the plastic up a bit and went at it. Took it down and then inside for 10mins then back out to test and install. Works perfectly. The 510 resistors are flat small rectangular resistors that are clearly labeled "510."
  18. Nov 6, 2011 at 11:46 AM
    #998
    MurfsTacoma
    MurfsTacoma Active Member
    Jordan
    Riverside
    05 Double Cab 4x4 TRD
    Grill, PushBar, BHLM, K&N, Delta 50 Flowmaster, A.R.E cover, 5100's
    Tacomaworld rocks! Overhead temp/ compass stopped working...no cracks visible on the 510 resistors. Bought micro solder gun. Re soldered it anyways...good as new. $15 well spent. Only casualty is a burnt finger...soldering guns get HOT:D
  19. Nov 6, 2011 at 3:56 PM
    #999
    Dorbs2457
    Sean
    Colorado
    4 inch lift
    Well I took mine apart and the entire 510 chip is missing. Anyone had this problem?
  20. Nov 6, 2011 at 6:56 PM
    #1000
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    My temp/compass went out. Took it apart, soldered the 510 resistor and while I had it on the work bench installed by led map lights. Everything is working good. Appreciate all the good info on the forum.
