Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Nov 9, 2011 at 8:50 AM
    #1001
    taco suprme sport
    taco suprme sport Member
    The thread is great, the instructions where easy to follow, one clip vanished in to the black hole of space....however it did not change the status on mine. That status is blank screen, dead.
    Any suggestions or direction on repair or reasonable priced replacement compass/temperature boards would greatly be appreciated.
    FYI: There did not appear to be any smoking gun on the 510 resisters on my board, soldered them twice with no change. The unit died slowly, intermittent non function followed by dead...prior to its demise I got it to work by tapping on it. I also checked wire harness, appeared to be fine
  2. Nov 9, 2011 at 8:35 PM
    #1002
    lenitnes1
    lenitnes1 New Member
    Prerunner
    I just did mine tonight... one shot and it worked. My suggestion to future fixes... do not push down the resistor/s, just put a good amount of solder on the broken connection. The circuit board expands/contracts as temperature changes, using a wire to reconnect the resistor to the board can also be helpful to compensate for this warping reaction.
    Freeheelbillie likes this.
  3. Nov 10, 2011 at 10:19 AM
    #1003
    SirGeoff
    SirGeoff Well-Known Member
    Geoff
    West Coast - Vancouver Island, Canada
    2006 SR5
    Taco Suprme - don't give up.. assuming you considered the unit dead, you have nothing to lose. Keep trying with the soldering, but don't go to the trouble of reinstalling it just plug it in until you get it to work. Mine didn't work the first time either on what I thought was a good solder.
    As for the clip, feel inside the hollow below the clip hanger it has to be there.
    Mine was a second hand unit from EBay (to replace the sun-glasses holder) cost me $250, which is half the shop price - just keep your eye out.
    Good luck...
  4. Nov 10, 2011 at 2:40 PM
    #1004
    mme
    mme Member
    Mary
    Ruston, Louisiana
    '07 Tacoma 4wd
    Nerf bars
    Did you mash that reset button several times? I thought I'd failed too until my husband hit the button a few time.
  5. Nov 10, 2011 at 3:45 PM
    #1005
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    I need to buy a soldering gun, any suggestions from you guys? Im pretty sure I need to get one with a small tip from what I've been reading. I might check homedepot or OSH this weekend.
  6. Nov 10, 2011 at 4:46 PM
    #1006
    el_smurfo
    el_smurfo Well-Known Member
    They are pretty big parts and take a while to heat up, so don't get a really small one. Any generic $10 solder wand will work though.
  7. Nov 10, 2011 at 6:19 PM
    #1007
    trd sport
    trd sport Well-Known Member
    queens,ny
    07 double cab trd sport
    Are there any pics of this repair? Could not find any in all of the posts.. Please help.
  8. Nov 11, 2011 at 4:44 AM
    #1008
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    @ Dorbs2457: you need a 47 or 51 ohm resistor to take the place of the missing one. Radio shack should have one.
    @ Taco surprme sport: send it to us before you buy a new one; there are other components that commonly fail, besides the resistors. I replace the caps, transistors, and resistors if need be.
    @ Kimo: see my suggestions here for irons. Don't buy a large wattage iron! Low wattage / tip size is better suited for SMT work.
    @ trd sport...see the first few posts of this thread for pics of the repair. Good luck!
    -greg
    We repair all years of Tacoma overhead displays...GUARANTEED not to fail again. (We heatsink everything!)
  9. Nov 11, 2011 at 7:05 AM
    #1009
    USAFVol
    USAFVol Well-Known Member
    07 TRD Sport
    What is your question? Taking it apart? What chip is the problem?
    When you get everything open, the circuit board will have different chips on it. There are two that say "510".
    Mine were still in place but some people have said theirs was disconnected/missing. If they are missing, I would go to radio shack or something and ask for a replacement.
    Just solder the ends down. Mine did not look broken but I figured I might as well try and it worked.
  10. Nov 11, 2011 at 7:06 AM
    #1010
    singletrack mind
    singletrack mind Member
    Chattanooga, TN
    2016 Magnetic Grey 4wd TRD Off Road SB Auto
    OEM Tri Fold Tonneau, OEM Mud flaps, OEM Rubber Mats
    I tried soldering mine and it didn't work. I am ready to follow your advice and get the 510 amps from Radio Shak(I may have some in the kit I bought to hook up the steering wheel controls to my radio) but am unclear on how to connect the amps. Do you have another pic or more info. on what to do? Thanks
  11. Nov 11, 2011 at 7:11 AM
    #1011
    USAFVol
    07 TRD Sport
    I wish I could help with that answer. I honestly have no idea. Take the circuit board into radio shack and see if they can give any advice.
    Hopefully someone on this massive board has an idea.
  12. Nov 11, 2011 at 12:43 PM
    #1012
    TRD Larry
    TRD Larry trd larry
    Larry
    South Park, PA
    2019 Tacoma Black,Sport,Premium and Tech Package
    Sport pedals,, Magnaflow cat back exhaust system,Kuhmo 275x55x20, Platinum #220 Abyss wheels 20x9.5. Under hood lights, OEM LED cargo bed lights, extra D-rings installed in bed, AC mod, diff. breather mod, OEM LED puddle lights and footwell lights, Homelink mirror, oil catch can, raptor grille lights, replaced chrome grille molding with black molding, tailgate lock/unlock and tailgate opener, console organizer, glove compartment organizer, Caliraised stealth LED light bar, TRD Cold Air Intake, Lighted cup holders, Meso extended fuse cover, Meso stage 1 tail lights, Meso switch panel, Door bowl lights. Anytime front and rear backup camera mod. TRD Pro Rigid fog lights.Door edge guards. TRD Pro shift knob with Boomer's TRD LED light (Red for security, blue for interior), Glass Break Sensor, sensor with LED light tied into the security LED light, OEM LED Headlights, Sequential LED Turn Signals.
    It is hard to see if the solder is broken on the 510. I got out a magnifying glass and then I could see where the solder was broken. I ran new solder on both of the 510's and then plugged it in to be sure if worked. Once everything worked I put it all back together.
  13. Nov 11, 2011 at 4:43 PM
    #1013
    kimo
    Knuckle Head
    Kauai
    DID IT !!! Hope it last awhile now. It went exactly how described in instructions at begining of this thread. I even had one metal clip come off and fished it out of the roof bracket it pops into. I was careful not to break plastic tabs on lens cover, they are snug ( take your time). Once I got to circuit board I could see right away that one end of the 510 resistor was popped up a little. I soldered a bead on the ends of both resistors and tried it before re-installing it. Fired right up!!!
    Only thing is....its in the low *60's outside temp here right now. It is reading *72....I guess it takes some time to re-set???? Will go for a drive tomorrow and see.
    Thanks for all the imput TW
  14. Nov 11, 2011 at 4:48 PM
    #1014
    kimo
    Knuckle Head
    Kauai
    Thanks for input and advice on your website. I will keep you guys in mind for future repair If I need it down the road...Kimo
  15. Nov 11, 2011 at 4:54 PM
    #1015
    Jax
    Jax Well-Known Member
    Phoenix
    06 Pre-runner
    I did this today and it works great. It didn't seem to work at first but I don't know if that was due to not soldering both resisters or because i didn't hit the power button. After I soldered the second resistor and then plugged it in it didn't look like it worked until I hit the power button on the overhead console. I am not the neatest when it comes to soldering circuits so mine were fairly large globs and it still worked out just fine. Thanks for the help with this fix everyone!
  16. Nov 12, 2011 at 5:40 PM
    #1016
    jinxed77
    jinxed77 Well-Known Member
    06 4.0L TRD SR5 4x4
    Did mine today too. I don't even know how long it was out. It worked back in the summer and didn't look at it again till 11/9/11. Don't have to have it but it annoyed me not working.
  17. Nov 14, 2011 at 8:29 AM
    #1017
    jtice
    jtice Well-Known Member
    West Virginia
    2011 TRD Off-Road
    Pioneer P4100DVD, 10" Pioneer Shallow Mount Sub
    It seems that most the issues listed here are of the temp and compass not displaying at all?
    My compass works, but my temp just shows 3 dashes. ---
    Anyone had this issue, and know how to fix it?
  18. Nov 14, 2011 at 9:13 AM
    #1018
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    I fixed my yesterday. I only put on a piece a electrical tape over the 510 to hold it down. It works. Haha.
  19. Nov 14, 2011 at 11:08 PM
    #1019
    andrewlam
    andrewlam New Member
    so, i fixed it one alreaady. stop working again last week, so i fixed it again. and now its burnt out again. ya my soddering sucks but is there a different resistor i can replace it with. its always get super hot when i put the 510 back on
  20. Nov 14, 2011 at 11:09 PM
    #1020
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Guessing your resistor is bad then....idk where you can get a replacement tho
