Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Dec 25, 2011 at 10:45 PM
    #1081
    JKD
    JKD Well-Known Member
    Black mark on screen: see below my post.
    Try soldering the 51 ohm resistors anyway.Hairline cracks in the solder are enough to open the circuit.
  2. Dec 26, 2011 at 12:19 AM
    #1082
    babyboi2284
    babyboi2284 Well-Known Member
    Brian
    Lockport, Louisiana
    09 Barcelona Red X-Runner
    LS 6k projectors w/ white halos, 6k fogs, T-Rex Angry Lids, NST SSK, Coupe Shift Knob, BHLM, LFM, DLM, FLM, JL 500/1 amp, JL 10"w6v2, subX wanna be made by me, Magnaflow muffler, 5% tint, k&n drop in filter, Craven Speed Stubby, map light mod
    I've seen that black "burnt" mark on all that I've repaired. It doesn't affect the screens operation at all. Just try to re solder the joints anyway even if they look perfect. Like mentioned above...a hairline crack makes a world of difference with solder.
  3. Dec 26, 2011 at 8:48 AM
    #1083
    TacomaTno
    TacomaTno Member
    Tino
    Hacienda Heights, Ca.
    06 PreRunner Radiant Red
    Husky floor liners,Bestop Supertop,Tailgate Theft deterrent (Hose Clamp Mod),CoverKing Seat Covers
    Yeah mine has the burn mark on the screen too, I went ahead & soldered it anyways since I had already had it out and it worked, so it's worth a shot to try the fix. Good luck.
  4. Dec 29, 2011 at 9:24 AM
    #1084
    DIYFool
    DIYFool New Member
    Oldsmar, FL
    06 Prerunner SR5 TRD Sport
    After putting up with an inoperable temp. display/compass for quite some time, and fearful of taking it to the dealer, I read your posting and decided to take a look at the circuit board. Thanks for the detailed step-by-step instructions, as well as the pic of the circuit board. Especially helpful was the advice on delicately handling the plastic clips so they would not snap. Sure enough, the solder bead along one 510 resister was burnt (yellowish), so I laid a piece of solder along the length of the connection (and I'm no soldering artist). While I was skeptical that was all that was wrong, much to my surprise, the unit now works! I would also note that the LED display does have a burn mark in the upper left hand corner, as has been reported by others in this thread. Thanks, again. Without such explicit instructions, I would have never attempted this fix, which turned out to be pretty easy. No telling what the dealer would have charged to replace the circuit board--you know they would not have soldered it!
  5. Dec 30, 2011 at 7:55 AM
    #1085
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
  6. Dec 30, 2011 at 8:22 AM
    #1086
    JKD
    It's a Vacuum Fluorescent Display (VFD), and that mark is not a burn mark, it is an artifact of the manufacturing process.
  7. Dec 31, 2011 at 3:14 PM
    #1087
    SeaPig173
    SeaPig173 Well-Known Member
    SE USA
    Anybody have issues with the temp being wrong after the fix? I know it's cold here in Monterey but its surely not 20 degrees F. Or maybe it is and I need to calibrate myself...
    BTW, great write up and simple fix. I put it off thinking it would be more of a PITA, I didn't know the whole fix would take ten minutes!
    Cheers,
    SP
  8. Dec 31, 2011 at 7:48 PM
    #1088
    yamalarishauler
    yamalarishauler Active Member
    scott
    eastern wa.
    05 pre-runner with a few mods.
    leveling kit installed with a 3in.lift, Carr side steps, ride- rite air bags, bigger tires- b.f.g's, custom ultamate rack for my quads, Kayak rack for boating excursions, seat covers, no emblems on tailgate, even took off the trd decals from the truck bed, ALL BLACK!
    thanks so much for that info. i will give it a try. mines been out for two yrs.
    dealer wanted over $900.00. so i just thought i'd have to settle for it not working!
  9. Dec 31, 2011 at 7:54 PM
    #1089
    yamalarishauler
    scott
    eastern wa.
    THANKS FOR THE INFO. ON THE REPAIR PROCEDURE. I'LL GIVE IT A TRY. MINES BEEN INOP. FOR A COUPLE OF YRS. NOW! THOUGHT I'D NEVER GET A NEW ONE...$900.00+ THATS ROBBERY!!!:eek:
  10. Jan 1, 2012 at 7:33 AM
    #1090
    Siliconmethod
    Greg
    MO
    -The temp gauge will calibrate itself after a few days. It will be off kilter, especially if the temps are different from when you removed the display vs re-installing it. Also, make sure it is reading Fahrenheit as opposed to Celsius if that is what you are used to.
  11. Jan 2, 2012 at 11:13 AM
    #1091
    SeaPig173
    SE USA
    Yup, it calibrated itself, as you said. I checked it yesterday, it was good, I was just too lazy to edit my post or update. Thanks for the reply. This was a GREAT fix!
    Cheers,
    SP
  12. Jan 4, 2012 at 1:36 PM
    #1092
    weez187
    weez187 Well-Known Member
    Jersey
    06 tacoma sr5 trd package stock
    awesome post thanks for this quick fix. i wouldve never caught them sticking up
  13. Jan 6, 2012 at 12:05 PM
    #1093
    IB Slingin
    IB Slingin Well-Known Member
    HEADS UP GUYS!!!
    I know its been mentioned before but...my 510 resistors looked PERFECT. I was convinced it was something else. I went ahead and soldered all four edges anyway. Put it back together and the damn thing started working!!! Awesome fix!!!
  14. Jan 6, 2012 at 3:30 PM
    #1094
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    You can't always see the crack along the edge of the 510's but it is best to solder ALL of them on each side.
  15. Jan 6, 2012 at 4:12 PM
    #1095
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    What a sense of satisfaction this was! And a relief! Done and done :)
  16. Jan 7, 2012 at 2:13 PM
    #1096
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    I read this thread about a year ago and the display went out on my 2007 Taco this week. My son and I completed the repair in about 10 minutes!
    Many thanks!
  17. Jan 9, 2012 at 11:23 AM
    #1097
    Rocketman
    Rocketman Member
    Downingtown, PA
    2007 DC TRD Off Road
    Just re-soldered mine this weekend! Works like a champ now! Thanks everyone.
  18. Jan 16, 2012 at 10:58 AM
    #1098
    GTACO
    GTACO GTACO
    Gabriel
    Murrieta, CA
    07 PreRunner
    Camburg Spindles, Total Chaos UCAs & LCAs, Fox 2.5 c/o front, Fox 2.0 rear, All Pro 3" leafs, Dumped Borla muffler, AFE intake, DTF front bumper, Demello rear bumper.
    Finally got a chance to do this fix.
    About 10 min later, done! :woot:
    Worked great
  19. Jan 17, 2012 at 5:18 PM
    #1099
    Buzzbubby
    Buzzbubby Still Learning Member!
    PA
    07 Double Cab Long Bed TRD 4x4
    Nerf bars, vent shades, trifecta trifold tonneau cover, tinted windows stubby antenna...more to come
    Mine just went out tonight. First place I went to is here to see what the problem was. Mine right now is fading in and out, sometime not working sometimes does. So Im going to try this this weekend. I also looked this up on youtube to see if someone had step by step. And there is. Just searched Toyota Tacoma compass/temp fix. And there it was a video. Seems pretty easy. Thanks everybody!
  20. Jan 17, 2012 at 5:30 PM
    #1100
    ILikeTacosToo
    ILikeTacosToo Well-Known Member
    Kyle
    VA
    08 DC 4X4 TRD Off Road
    ARB front locker, alpine nav, image dynamics i5800, Polk audio front rear and subs, TOYTEC 3 inch coilovers wiht AAL, awesomest driver ever!
    Wow, i should have known there would be a post on this here. Have to thank Buzzbuddy for posting seconds before i went to the homepage to read the most recent threads... otherwise i would have just been frustrated with my stupid compass and kept trying to hit it till i broke my hand or the damn thing. gonna fix mine tomorrow at work, good use for the outlet in the bed to heat up my soldering iron.
