Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jan 17, 2012 at 7:25 PM
    #1101
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    I fixed mine 3 times before I finally decided to send it in to Greg at siliconmethod.com. I realized soldering wasn't something I was good at. It would work for a month or two, then just stop. I am very happy to have it working again and to get rid of that "when is it going to go out again" feeling. I highly recommend his services.
  2. Jan 19, 2012 at 7:37 AM
    #1102
    RogueAgent
    RogueAgent New Member
    Colorado
    06 Taco TRD OffRoad - 6Spd
    Fixed mine last night. One of my 510s had popped completely off the board, while the other had visibly cracked solder on one end. I soldered both and am back in business.
    Really appreciate the info, glad it was an easy fix. It's sad Toyota didn't do the right thing for everyone especially considering it was an upgrade option that people pay more for.
  3. Jan 20, 2012 at 6:00 AM
    #1103
    ILikeTacosToo
    ILikeTacosToo Well-Known Member
    Kyle
    VA
    08 DC 4X4 TRD Off Road
    ARB front locker, alpine nav, image dynamics i5800, Polk audio front rear and subs, TOYTEC 3 inch coilovers wiht AAL, awesomest driver ever!
    Fixed mine two days ago. works like a champ now. thanks for the info!
  4. Jan 21, 2012 at 11:21 AM
    #1104
    TacomaRebel
    TacomaRebel Member
    S. Mississippi
    07 PreRunner TRD OffRoad
    I got my display out but I can't tell how to get to the back side of the board to solder the connections. The top side looks fine. The board isn't screwed down. There is one post that holds it to the board. Do you have any photos where you soldered the connections? Thanks!
  5. Jan 21, 2012 at 11:27 AM
    #1105
    toyotatacomaTRD
    This should help.
  6. Jan 21, 2012 at 1:23 PM
    #1106
    TacomaRebel
    TacomaRebel Member
    S. Mississippi
    Thanks for posting the photos. I wasn't sure which side of the 510 chips to solder. My thinking was on the backside of the electronic board. I soldered mine & clean them with some flux first. When I put the solder to it the dang chip moved on me so then I had to get some tweezers & move it back it to place while melting the solder. Tested it out first by taking just the temp unit out & plugging it in, then mounted it back to the console piece & then remounted into the overhead. Thanks to everybody for this easy fix.
  7. Jan 21, 2012 at 1:40 PM
    #1107
    TacomaRebel
    TacomaRebel Member
    S. Mississippi
    Just fixed mine today. It is really easy. Mine wasn't working when I bought the 07 truck last year. I took the console out & disassembled it down to just the compass unit. But I couldn't find any photos on this forum showing where to solder the chips. Finally found some. My thinking was that the solder was on the backside of the electronic board (most are). Apparently the 510 chips are glued to the board as one of mine moved when I went to apply solder.
    I had to locate all my solder supplies, hadn't been used in 20-25 years I guess & had moved with me several times. I cleaned the chips with a little solder flux & used some lead free solder. Had to unsolder the one chip as it moved on me while I was soldering. got it almost back in position. Add solder to other sides. Took the unit back out to my truck & plugged in just the compass unit turned on the key & it worked. Brought unit back inside & put the cover over it & superglued the one clip that broke off, screwed it back down to console unit, connected the wires back, popped it back into the overhead, tried it one more time. Compass showed I was facing West which was correct, temp showed 87 degrees F. Which seems a little high the temp in S. Mississippi is 73, in January. My guess is the sun on the truck & the fact that I had just driven the truck may have an effect on the reading. If not correct I will have to see if it can be calibrated.
    Good luck to all who try this fix, it is really easy & if you know how to solder, even better. If not you can send your unit (not the whole console) to autoclockrepair.com & they will fix it for you for around $35 with lifetime warranty. cost you about $2 to ship it. They also replacement units for $135. They still beats toyota's ripoff of $900 or whatever they charge.
  8. Jan 22, 2012 at 11:09 AM
    #1108
    Turkeyslayer
    Turkeyslayer Member
    Northeast Ohio
    07 SR5 TRD
    Bug Deflector,Side Steps,EX-Tang Tonnau Cover ,Goodyear Duratracs...Their Great!!!
    Thanks just got mine done!!!
  9. Jan 22, 2012 at 5:20 PM
    #1109
    simple1
    simple1 New Member
    07 4x4 TRD
    Thanks for the tip - fix worked great for me. Now I won't have to thump the display constantly :)
    Suggestion for others - best to use a pencil tip soldering iron. After you heat the resistor, take it completely off and use some solder wick to clean the contact surfaces on the board. If you don’t have a way to secure the resistor just tin one of the board contacts with a little solder. That way you can just heat and stick, much easier if you only have two hands like most of us. With one side secured you can get a good solder joint on the other, then finish up the first side.
  10. Jan 24, 2012 at 2:09 PM
    #1110
    Muscles
    Muscles Well-Known Member
    Kyle
    San Diego
    05 PreRunner TRD
    K&N Air Intake
    fixed mine today easy money :)
  11. Jan 26, 2012 at 10:15 AM
    #1111
    yellowlab
    yellowlab Active Member
    Bellevue, WA
    2007 DC LB TRD
    Stock TRD, but ordered up 5100 Billys. Grillcraft, Pioneer Avic with NAV, DVD, Backup Camera, Ungo Box, Truck Cover Tonneau, TRD seat covers, Weather Teks, Toyota Side steps,
    I waited far too long to get this easy fix done. Thanks to Tacoma World and Tacoma Nation forums!
  12. Jan 26, 2012 at 4:33 PM
    #1112
    whatcaneyedo
    whatcaneyedo Member
    Russell
    Prince George, BC
    07 Double Cab TRD Sport
    Same old story... I googled my problem and it landed me here on page 56 of this painfully long thread. Considering how common this problem is Toyota really should have recalled the part by now. Anyways, one of my 510 fell out completely and was never seen again so I went to Radio Shack to buy a 51 ohm 1/4watt resistor. The closest thing they had was 47 ohm 1/4watt so that is what I soldered. So now I have a 47 and an original 510 in parallel. Everything seems to work again which is great but because of my limited experience with circuits I'm wondering if having the two different resistors is going to be a problem?
  13. Jan 26, 2012 at 5:50 PM
    #1113
    Dromlace
    Dromlace Well-Known Member
    Michael
    Montgomery, AL
    2006 Tacoma TRD Sport
    same situation here man. checked it out, didn't see anything wrong..
    then i read your post and figured i'd give it a shot and sure enough it worked.
  14. Jan 28, 2012 at 11:51 PM
    #1114
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
  15. Jan 29, 2012 at 1:42 PM
    #1115
    toniodiaz
    toniodiaz Crazy and lovely member
    Maruko
    Southmerica
    2011 SR5 TRD Sport Silver Double Cab and now 2013 SR5 TRD Sport Red Double Cab
    TRD Supercharger, TRD Catback, aFe Cold air intake system, HELLA Rallye 4000 Celis lamps, Spyder Smoke CCFL Halo projector Headlights, JBA Ceramic Coated Long Tube Headers, Centric Cross Drilled Front Brake Rotors, URD smaller diameter S/C pulley, Roof Rack, Recon Tail light bar, 3" OME Leaf pack at the rear with 5100 Bilsteins and Regulable 2.75" Toytec Red Springs with 5100 Bilsteins in the front, Total Chaos UCA, Front TRD Skid Plate, Black Tube Step Bar, Black Emblems and TRD Sport Stripes decal, I JUST FINISHED MY MOD TO THE PARKING, DTR AND TURNING LIGHTS, When you hit the turning switch, DTR ad Parking lights turn of on the side the Turn signals are flashing, so they don't disturb their intensity. Everything installed with my own little hands and help of my dear friend and of course, your mods.
    Any idea where can I find those resistors, since one of mine is broken. How can I order them, are they 510ohms anything else?
  16. Jan 29, 2012 at 2:27 PM
    #1116
    joew94th
    joew94th Member
    Cameron Park, CA
    06 PreRunner TRD offroad
    Radio Shack! They won't look the same, but they'll work the same.
  17. Jan 29, 2012 at 4:24 PM
    #1117
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Go back through the thread some or someone chime in for this guy as they are NOT 510 ohms, I think they are 51 ohms but my memory on it is lacking right now. Also make sure they are at least 1 watt in current/temp ability. You put smaller ones in there and you gonna get some stuff too hot.
  18. Jan 30, 2012 at 9:35 AM
    #1118
    whatcaneyedo
    whatcaneyedo Member
    Russell
    Prince George, BC
    So which is it then? 1 watt or 1/4 watt? In this link he recommends 1/4 watt 51 ohm or 47 ohm. I went to our Radio Shack and all they had was 1/4 watt 47 ohm so that is what I've used. But if I'm going to overheat something I'd like to know so that I can order the correct resistor and do it right.
  19. Jan 30, 2012 at 3:23 PM
    #1119
    45longcolt
    DFW Area
    2020 Off Road
    If that link says 1/4 watt then it is OK as he has done the research on it enough to know that 1/4 watt is OK.
  20. Jan 31, 2012 at 3:53 AM
    #1120
    Siliconmethod
    Greg
    MO
    Yes, 1/4 watt is just fine for this application. The axial lead wires will help with heat removal / dissipation also (acting as a heatsink), so that is a bonus.
    Bear in mind that if you go with resistors higher than 1/4 watt they will work just fine, but the lead wire gauge is larger and will make soldering them on / adjusting them to fit a bit more difficult.
    Greg @ Siliconmethod.com
