Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Jun 19, 2012 at 2:15 PM
    #1221
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    You gentlemen speak the truth. That's why when I fixed mine I wicked away the lead free solder, applied flux, and soldered them in with good ol' 63/27 tin lead solder then cleaned the joints up with alcohol. No problems for 2+ years.
  2. Jun 27, 2012 at 12:54 AM
    #1222
    WrathRacing
    WrathRacing Member
    Marco
    Fontana Cali
    06 Tacoma
    Mine just went out 2006 trd...took everything off and the resistor had came off the solder...time for a easy fix I hope. Will c tomorrow!
  3. Jun 27, 2012 at 8:52 PM
    #1223
    slowpyro
    slowpyro New Member
    Minnesota
    TRD Offroad
    I knew there wasn't a chance in hell this would work for me, but sure enough it did. I am speechless and thankful!!!!! 15 minutes and everything is back to normal.
  4. Jun 28, 2012 at 3:29 PM
    #1224
    Vikinglord
    Vikinglord Active Member
    Michael
    Nashville
    Gold Prerunner
    Man, mine stopped working yesterday. Time to break out the soldering iron. I thought it was a fuse, but sounds like this is common.
    Will report back. Thanks!
  5. Jun 28, 2012 at 4:18 PM
    #1225
    Vikinglord
    Michael
    Nashville
    Gold Prerunner
    Well I will be a money's uncle. I took it out, disassembled. (They are not kidding about being careful when taking the smoke glass cover off. I broke one clip.) I did not see any burn marks or disconnections around the 2-510 resistors, but I globbed some solder around all 4 connectors. Hooked it up top test and....
    VOILA!
    Yes, it really is 105 in Nashville right now. Put it all back together. All of 15 minutes start to finish. Works perfectly. It is nice to use my EET degree from time to time.
    I LOVE this forum!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :bananadance:
  6. Jul 3, 2012 at 1:52 PM
    #1226
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    I just attempted the fix. IT'S ALIVE!!! At first, just as everyone mentioned. None of the solder were cracked, but a burnt mark on the display screen. I figure "what the Hell, it's already broken". Soldered both 510 resistors and TW thank you!!!:D:D:D:D:D:cool:
  7. Jul 3, 2012 at 6:43 PM
    #1227
    SaraLynn44
    SaraLynn44 Well-Known Member
    Sara Lynn
    Fresno CA
    08 PreRunner
    Engage Long Travel Deaver's 2 10" Kicker subs Fuel Rims Nitto Tires
    I did this fix it works now but its stuck on 75 degrees any ideas?
  8. Jul 3, 2012 at 9:00 PM
    #1228
    joes06tacoma
    Joe
    Central Coast, CA
    Mine stuck on 100 degrees when I resoldered it. I just drove around for about a half an hour and it very slowly came down into the 60s, which was the temp outside at the time. I think it recalibrates itself.
    If you just put it back together, give it a couple of drives to adjust itself before getting too excited about it.
  9. Jul 12, 2012 at 7:57 PM
    #1229
    Monotak
    Monotak Member
    Trent
    Utah
    07 TRD Off Road 4x4 6spd
    RevTek 2.5" Lift Kit Volant Cold Air Kit FlowMaster 40 Series Dual left side exit exhaust
    So grateful for this fix! I have been driving around for three years not knowing what temp it is outside and what direction Im going. No more getting lost or worrying about if I will need my jacket or not. Not serious, but I am grateful for the directions on the fix.
  10. Jul 13, 2012 at 7:00 PM
    #1230
    tonyr07
    tonyr07 Tman
    Washington State
    05 Tacoma TRD
    K&N Airfilter, flowmaster exhaust
    I was experiencing the same issue. I found your post and followed the directions. I removed the temp/compass mother board and took it to a friend of mine that works with electronics out of his home. He was able to re-solder the 510 resistors in less than 30 minutes. I re-installed the head unit and it worked immediately. Cost=$20.00.
    Thanks again.
  11. Jul 14, 2012 at 1:58 PM
    #1231
    Tacomojo
    Tacomojo Mojo Mofo
    Nashville, TN
    2019 TRD Pro, AT, White
    Neat! Neat! Neat! Mine crapped out a few days ago and I was thinking it was a fuse issue. Thanks to The Fix outlined here, I was able to quickly get it working again. TW saves the day!!! :cool:
  12. Jul 16, 2012 at 4:23 PM
    #1232
    20phileagles
    20phileagles Member
    Virginia
    2008 Prerunner
    I had my windshield replaced by some half-ass company and the day after, I noticed my temp and compass didnt work. I called and cussed the poor guy out, big time. I thought he cut a wire!
    After reading this thread, I fixed it in about 15 min. Thanks alot OP
  13. Jul 24, 2012 at 2:36 PM
    #1233
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    mmmm....i was wondering why my broke. thought it was a fuse of some sort. guess not.
  14. Jul 24, 2012 at 6:22 PM
    #1234
    OxyGuy
    OxyGuy Well-Known Member
    Conway, SC
    2007 PreRunner
    I fixed mine. Whoever figured this trick out, I'd like to buy 'em a beer.
  15. Jul 24, 2012 at 11:55 PM
    #1235
    Avi8tor
    Avi8tor Member
    Hawaii
    2005 Toyota Tacoma PreRunner SR5 Sport
    TRD performance exhaust, TRD cold air intake, tow kit
    I will try this fix for my truck. I have an 05 Tacoma and noticed that my temp/compass was not illuminated one day and then it worked the next. Fast forward on month or so later and now it does not work at all.
  16. Jul 27, 2012 at 4:29 PM
    #1236
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    nice fix. I didn't even add new solder. Just heated what was there and smoothed it with a plastic pick.
  17. Jul 27, 2012 at 11:02 PM
    #1237
    Thurl1103
    Thurl1103 Member
    Gresham
    07 PreRunner SR5
    I just bought a 07 PreRunner; it's got it's little things.....LIKE THIS PROBLEM HERE!!! BOOM!!!! I knew TW would be a great place to be!! Now I just need to get a soldering iron.
    hahaha......Thanks misc!!!
  18. Jul 31, 2012 at 2:39 PM
    #1238
    FCMtaco
    FCMtaco Member
    Patrick
    Jacksonville, FL
    2007 trd Super White 4x4 Double Cab
    Excellent write up! Took me 15 minutes start to finish and now I have a working compass/ thermometer.
  19. Aug 1, 2012 at 7:20 PM
    #1239
    Avi8tor
    Avi8tor Member
    Hawaii
    I looked at the circuit board a second time and sure enough there was crack in the connection of R510. After 5 minutes of my time it works like new. Thanks again for the advise.
    :D
  20. Aug 2, 2012 at 5:36 AM
    #1240
    gatorgreg
    gatorgreg New Member
    Greg
    Tallahassee, Florida
    4x4, double cab, ext. bed
    Repaired compass and therm. & mudflaps replaced with horsestall rubber mat material and 1/4" lag bolts and fender washers
    the resistors looked OK, could not see any air gaps, so I heated both ends of the 510 resistors with my iron and re-attached and it is working! It would be nice if everything could be fixed in 15-20 minutes and for 10 cents.
