Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Sep 17, 2012 at 3:14 PM
    #1281
    Diode20
    Diode20 New Member
    Brea, CA
    06 Toyota Tacoma
    I was browsing this sight to update my gf's tacoma. I saw the gauge fix. I asked my gf about her's. She said it's been out for years.
    I followed the instructions, and voila, works. In my case, both resistors where disconnected. You can't really tell. But if you gently lift the resistor, you will notice it's not soldered in anymore.
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=170187&stc=1&d=1347920034
    http://www.tacomaworld.com/forum/attachment.php?attachmentid=170188&stc=1&d=1347920034
  2. Sep 17, 2012 at 3:26 PM
    #1282
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    That repair will get you some points for sure! See above in red, do not try to lift one edge as they are very brittle and will snap in two pieces or more. Just add solder to what is already there to build up the thickness of solder on each end. Just a helpful tip to prevent someone from snapping it into.
  3. Sep 17, 2012 at 11:58 PM
    #1283
    DevilTaco
    DevilTaco Well-Known Member
    Scottsdale, AZ
    07 Sport 4x4
    Just thought I would add a quick update:
    (OP feel free to copy this info to the first post)
    I used the "Siliconmethod" :)
    (AS Siliconmethod HAS SAID, IF YOU JUST TRY AND RESOLDER THE FACTORY 510 RESISTORS, YOUR DISPLAY WILL FAIL IN TIME. SAVE YOURSELF SOME TIME AND JUST DO IT RIGHT THE FIRST TIME)
    Assuming you have a pen-tip soldering iron like I did, the resistors and solder are just over $5 at RadioShack.
    1. Like most owners I am greeted with this, a dead display:
    2. Drop in to your local RadioShack and pick up some 60/40 Rosen solder, and a pack of these:
    (47-ohm resistors - 1/2 watt - 5% tolorance) RadioShack Item number: 271-1005
    Take a razor blade and pry off the factory 510 resistors, this is rather easy and clearly proves where the problem lies. Toss them in the trash:
    Add a drop or two of solder to the original connection points, this will be used to tack the resistors in place. Take the resistors and bend both ends 90 degrees, then bend them more to align with the drops of solder. Repeat, then add final solder to make everything permanent. Should look like so:
    5. Reinstall and enjoy the extra $165 dollars in your pocket!
    ***Be sure to update your region code by holding the button until the "VAR" appears. Finally calibrate the direction by holding the button down until the the "CAL" appears, then use an open lot to drive in a counterclockwise circle at or under 5mph. One circle, two max should be enough.
    Goodluck,
    -Jb :)
  4. Sep 19, 2012 at 12:10 PM
    #1284
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    Just fixed my neighbors Tacoma display, using the information here. Thanks for the tutorial and sharing your knowledge!
  5. Sep 25, 2012 at 1:40 PM
    #1285
    Frank L
    Frank L New Member
    Frank
    New Jersey
    07 Tacoma SR5
    3 INCH READY LIFT 17 Helo Wheel Dick Cepek fun country II 33 Hid H4 High/Low and fog H10 Westin bull bar Dee Zee Nerf bars
    Hello new on the forum.Just wanted to say thanks .Had a issue with the compass not working for over a year took to toyota dealer to get repaired and was very expensive but your quick fix works great. once again thanks.[​IMG]:thumbsup:
  6. Oct 2, 2012 at 11:10 AM
    #1286
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    Just got done doing the Temp / console fix. Very easy to do just following the instructions found in this thread. It was working early this morning, around noon I was back in the truck & looked up at it, not working. I knew what was wrong as soon as I looked at from reading about this before. Took me about 35 to 40 minutes from start to finish. This fix saved me a pile of cash !
    Thanks everybody on Tacoma World for the info here. :D
  7. Oct 2, 2012 at 9:04 PM
    #1287
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Tacoma TRD Off Road 4WD
    Curve ball.........what do you do if temp/compass work, but temp sticks on any given temp at any given time? I have been back and forth on this issue with the dealer....my temp will say 69 degrees all day, when it is a scorching 103 out...they have replaced both display and recently, the sensor...still a no go...intermittant problem = cranky owner.....
    How long does it take you temp gauge to adjust?
  8. Oct 2, 2012 at 9:07 PM
    #1288
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Exact same problem since day 1. Three years later and several trips to the dealer no change. Its an intermittent issue that only seems to happen during 2 situations:
    A- its way too dam hot (100+)
    B- the sensor gets wet after a wash
    It eventually updates by the end of the day. I only notice it about once a month.
  9. Oct 2, 2012 at 9:12 PM
    #1289
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    damnit, mine broke again today. My fix lasted for 3 years though using original resistors.
    TBH with the above post using radio shack resistors, I don't know how that would work any better considering you're still soldering to the same connection point. It just needs a tad more solder if you ask me.... or, if the board allows, drill through the board and sink the radio shack resistors in. I may just do this instead of resoldering.
  10. Oct 2, 2012 at 9:19 PM
    #1290
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Mine seems to "act up" on my days off, when running errands, (so i notice it and get pissed off)
    happens no matter if I just gave it a bath or not.....i have noticed it more this summer than last winter......
    inaccuracy sucks....i know it is hotter than the hubs of hell outside, but I paid enough money for my truck, the damn thing should tell me the exact temp of HELL....
    At least mine isnt the only one that is doing this.....
  11. Oct 4, 2012 at 11:51 AM
    #1291
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Another happy customer, everything came off easy, one 510 was rattling around; Resoldered and Bob's your uncle.
    Now what to spend the $$ I just saved on..
  12. Oct 5, 2012 at 11:29 PM
    #1292
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Back to the dealer for another look....they have no clue, so they starting throwing parts at it.....replaced the display again...now it is sticking at 84° all the time and it smells like burning rubber when standing next to my truck...
  13. Oct 7, 2012 at 11:31 AM
    #1293
    Siliconmethod
    Siliconmethod Well-Known Member
    Greg
    MO
    Cindy,
    What parts have been replaced by the dealership in trying to fix your stuck temperature problem? Only the accessory meter? (the display)
    If I were them, I would replace the temperature sending unit first, and then look at wiring. Have they done that for you?
    -greg
    Tacoma compass/ambient temp gauge repair
    *edited because I re-read your posts. I see that they replaced the sensor (sending unit) already. That pretty much leaves wiring / connectors as the culprit, which is a definite possibility...but not one the dealership is going to want to tackle. If you know someone handy with a multimeter, check for resistance in the wires leading from the sending unit to the display. Check for shorts, too. If something like that can be identified and 'proof' of a defect shown to the dealership, they will be more inclined to take action. Good luck!
  14. Oct 7, 2012 at 11:42 AM
    #1294
    Siliconmethod
    Greg
    MO
    DevilTaco,
    Good job! Excellent soldering skills there, my friend. That repair will last forever.
    On the 181 resistors, you may want to fill in a bit of new 60/40 on top of the old solder. I've seen a few of those fail, also (about one in every 30 repairs).
    I just do a preemptive strike and hit them all.
  15. Oct 8, 2012 at 1:04 PM
    #1295
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Been back and forth with the dealer since I picked it up....i guess the display is supposed to update every 2 minutes, so I asked them to look into what sends the signal to update....I'm not taking it back til they have another solution besides just replacing the two things they have already replaced......this will be try #6 for them to fix it....
  16. Oct 8, 2012 at 4:31 PM
    #1296
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    Still looking for a console if anyone got one they want to get rid of....
  17. Oct 8, 2012 at 8:07 PM
    #1297
    turbo325ii
    turbo325ii Active Member
    Brett
    Provo
    06' Double Cab TRD off road
    none
    CONFIRMED FIX: Thnaks for all the info guys!
    Thought I was sunk because the display has a burnt looking mark on the top corner. But all works well.
    Truck just went from dope to baller with this fix!
    96067745-60BD-4F77-99A7-415C5B6E960B-314_dd0ee90faecb3ef6a8e8d5cb063978629edc3c04.jpg
    1F35074D-AFDB-47D9-AFA9-BA79E27DF729-314_c06eea6277e53005d22fa9747c483d629ae872a8.jpg
  18. Oct 9, 2012 at 3:27 PM
    #1298
    Siliconmethod
    Greg
    MO
    Cindy,
    Try #6?? That is crazy. Sorry you are having such a rough time getting this taken care of.
    The meter is receiving input of *some* kind on a continuous basis, because when there is no sending unit installed it displays dashes where the temp readout should be. I'm 90% sure the meter is not the issue.
    Have you looked to see if the dealership really changed out the sending unit (sensor?) It is visible between front grill and radiator.
    They need to be checking voltages / ohms and not just replacing things willy-nilly. It is wasting your precious time (and patience) in addition to unnecessary parts.
    The wiring could easily be the issue. Are you up north where the roads are salted in the winter?
  19. Oct 9, 2012 at 7:30 PM
    #1299
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    Round two with mine
    Broke a tab each time :(
    Not the prettiest but it works..thought for sure I would have messed things up. 2nd time soldering..think I know how it works now :p
    Is the calibration really necessary?
  20. Oct 9, 2012 at 8:35 PM
    #1300
    Rexio_Mty
    Rexio_Mty hi everyone
    Monterrey, Mexico
    Tacoma TRD Lunar Rock 2022
    None
    you´re the man...its that i want to know....my taco is 2008 and now lights is off looks black, out off....i though was about battery inside the overhead compass/Temp do you think i need to do same as you did...
    thanks compadre!!
