Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Oct 9, 2012 at 11:11 PM
    #1301
    JoeTacoma02
    JoeTacoma02 Well-Known Member
    To my knowledge there is no battery in there and yes, I'm assuming your problem is the same as all of ours.
  2. Oct 9, 2012 at 11:16 PM
    #1302
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Mine just broke again!
  3. Oct 10, 2012 at 9:39 AM
    #1303
    txtrd
    txtrd Rookie
    Somewhere Down In TX
    07 TRD Off Road
    K&N drop in filter, nerf bars, alarm & remote start with 2-way paging
    Worked like a charm even with the burnt spot on the LCD. Thanks!
  4. Oct 10, 2012 at 10:13 AM
    #1304
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Tacoma TRD Off Road 4WD
    They replaced the sensor on try # 4....no salted roads....I havent washed my truck in 3 weeks so they cant blame it on "moisture" on the sensor.....
    I asked them to get the voltage at the sensor and the display as changes or doesn't change.....they just refused and threw another display at it......
  5. Oct 11, 2012 at 12:03 AM
    #1305
    titelines
    titelines titelines
    bailey
    kenai
    99 trd 4X4 v6
    front end smashed in
    Could not see that it was broke. While heating the left side of bottom resistor the whole thing moved, obviously the right side was not attached.
  6. Oct 11, 2012 at 8:23 AM
    #1306
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    you guys revisiting this..i had a buddy do mine..he builds tiny ass prototype circuit boards for a living.
    he flipped my resister over to utilize the clean edge on the other side.maybe this is an option for you guys too..he had all the tools..big microscope thing..he reinforced my entire board..he said he would build me a new one next time..ahhaha.
    he did say the original work was crap.
  7. Oct 13, 2012 at 7:34 PM
    #1307
    kbroupow
    kbroupow New Member
    Kevin
    hamilton, ON
    08 Tacoma TRD offroad
    licence plate offroad light mount, 2 hella black magic offroad lights
    This is a great post! My resistors didn't appear to have any poor connections but I put some solder on the connections and it worked! There's a great video on YouTube if you would benefit from a visual. Just type in Toyota Tacoma compass repair and it should show up.
  8. Oct 15, 2012 at 8:33 AM
    #1308
    Rebelsaints51
    Rebelsaints51 New Member
    Hattiesburg, MS
    07 4x4 SR5 TRD Sport
    Long time lurker, first time poster. I just had to post and say that this fix worked perfectly. I have used this and other fixes for common problems and this site has saved me alot of money. Thank you all very much
  9. Oct 18, 2012 at 7:59 AM
    #1309
    waynesexton903
    waynesexton903 Member
    wayne
    Prattville, Al
    265-70-16 BFG All Terrain, AVS,window tint.
    When I repaired mine, I beefed up the two 510, and the three 181 diodes. when finished I coated them with clear silicon to help absorb any vibration and to help support the solder points.
  10. Oct 18, 2012 at 2:52 PM
    #1310
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Finally got the fix for mine....it is the wire harness!!! We will see if Toyota steps up and takes care of this one for me.....
    ****spoke too soon...they still have no idea what is wrong.....
  11. Oct 19, 2012 at 6:50 PM
    #1311
    Fly Navy
    Fly Navy New Member
    Chuck
    Prescott, Az
    07 Prerunner TRD SR5 Debadged
    Wow, this forum really puts the meaning in neighbors helping neighbors. thanks for the tip- I just fixed mine in about five minutes. It does have the burn mark on the LCD, but it still works. I'm new to this group- can't wait to make one of the Tacoma events.
  12. Oct 20, 2012 at 3:18 PM
    #1312
    outd00rs
    outd00rs Member
    Virginia
    Tacoma 4X4
    Just did this again for the second time and fixed my problem. I went ahead and soldered all of the resistors because I couldn't tell which one had the problem.
    Tested it out and worked great. Hopefully it'll hold another 3 - 4 years.
  13. Oct 24, 2012 at 10:43 PM
    #1313
    Kevin W
    Kevin W New Member
    Kevin
    Chilliwack
    Tacoma
    I just got my 2005 tacoma a couple of weeks ago and this temp gage compass wasn't working. The Tacoma dealer said it wasn't worth spending the money to fix as it cost hundreds of dollars. Well he was right there. It wouldn't have been worth spending hundreds of dollars but it was worth spending 30 minutes to do the quick fix suggested on this sight. It worked for me! Thanks so much for saving us all money on something that is so simple when someone takes the time to explain it.
    Kevin
  14. Oct 26, 2012 at 2:23 PM
    #1314
    tree1955
    tree1955 New Member
    Tbird
    Nebraska
    06 Tacoma
    Yup you got another beer coming from here.
  15. Oct 31, 2012 at 8:43 AM
    #1315
    ToyTaco408
    ToyTaco408 Taco Life
    Bay Area
    2005 Silver Tacoma Double Cab TRD Sport SR5
    Thanks so much for this. I literally did this in about 30 min on my lunch..the only reason i took long was because i couldn't find solder..literally easy and anyone can do! T10 torx & screwdriver
  16. Oct 31, 2012 at 2:16 PM
    #1316
    sporter
    sporter New Member
    Alabama
    2006 Prerunner SR5 TRD
    Great thread! I fixed mine in about 15 minutes, the only casualty was one of the little plastic tabs on the cover to the gauge module. A little crazy glue seemed to take care of it.
    I soldered both resistors, both sides. Plugged it back in, and it works like a charm. I see some people are having to re-do it. I sure hope I can avoid that. Hopefully the double-sided solder will make it permanent fix. If I do have to redo the job, I'll use new resistors.
    I just bought my 2006 Tacoma, and with 133K, this was the ONLY thing that was not working. It's a small thing, but so nice to have it working now. My new truck (new to me) looks and feels like a real new truck now.
    Thanks, all.
  17. Nov 1, 2012 at 8:19 AM
    #1317
    jj05
    jj05 New Member
    05 prerunner
    Independent fog lights, leads on hood scoop, blue led's map lights,
    I just recently joined TW and I've learned a lot from it. I have a really good question. Let's say I solder the 510s and I have a blacked out LCD and it still doesn't work, I think that the black burned color is like that of a bulb burned out I was wondering if anyone has figured how to fix that?
  18. Nov 1, 2012 at 3:20 PM
    #1318
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    The burn mark on the display is normal, they all have that. That is the fire mark where the glass was sealed after filling the display with a gas. Lay a good ribbon of solder on each side of the resistors.
  19. Nov 1, 2012 at 6:44 PM
    #1319
    jj05
    jj05 New Member
    05 prerunner
    Thanks 45longcolt!. OK I've tried the new 47 ohm resistors from radio shack and nothing so I put one of the 510s on BC that's the only one left on the board and it worked!!, but what I noticed is that others really hot anyone has this same issue???
  20. Nov 4, 2012 at 6:34 PM
    #1320
    dbbd1
    dbbd1 Well-Known Member
    I have been having the "stuck" display also. It will just freeze up on any temp and stay there. For the time being, I have be able to "get it going" by unplugging the sensor behind the grille, turning it on, then off. Then I plug in the sensor and turn it back on again. Then it's working normally. I am looking into this problem (hence why I am here). I knew about the 510 resistor but now I am wondering if it could relate to my new problem. Or a sensor issue?
    no salt on the roads, dry or wet, cold or hot=all o difference
