Overhead Compass/Temp Fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by misc, Nov 9, 2008.
  1. Nov 5, 2012 at 1:33 PM
    #1321
    tacos 4ever
    tacos 4ever Member
    TJ
    Riverton
    07 Access Cab 4.0 V6 Debadged
    LED's all the way around, Flat black aluminum grill, Bushwhacker pocket style flare's, Leer tonneau cover w/lock synced to door locks, Carr aluminum side steps Audio: Pioneer AVIC 920bt head unit w/backup camera and sirius sat. radio, JL Audio speakers all around pushed by JL 1200w 4 channel amp, two 10" Boss Audio phantom series subs in custom box pushed by a Boss 4000w mono amp wired in at 1.4 ohms (thing hits like the f#*king hulk himself!!)
    Wow, big ups to misc!!! Like ppl said before, 20 mins, 10 c worth of solder, and bammm!! Saved me hundreds (which I never would have spent anyways) and I got a working overhead consol!!
    Also like ppl said before, even if it looks fine, solder them shits anyways!! Worked like a charm.
    Thanks for the great write up!!
  2. Nov 5, 2012 at 8:33 PM
    #1322
    Ernesto4
    Ernesto4 Well-Known Member
    North Hollywood
    15 Tacoma access cab 5 lug SR5
    I have a question about the overhead compass. I own a base model 5 lug and mine did not come with this. I would like to add it on to my truck and I was wondering Wat would I need to do that?? Do I just buy the part or is there more to it than that? Any help will be greatly appreciated. Thanks
  3. Nov 6, 2012 at 6:50 AM
    #1323
    Sandy sangha
    Sandy sangha Member
    Sandy
    Vancouver
    08 Tacoma trd 4x4
    hey my compass works but the temp show this ---F how do i fix that in the manual it says take it to the dealer if says that i replaced it because the other didnt work at all so when i put this new one in the compass is fine but the temp just shows 3 lines
  4. Nov 6, 2012 at 6:53 AM
    #1324
    Sandy sangha
    Sandy sangha Member
    Sandy
    Vancouver
    08 Tacoma trd 4x4
    hey the sensor for the gauge inside is behind the grille i couldnt find it in my truck it shows the compass but the shows 3 lines (---) cant figure it out
  5. Nov 6, 2012 at 11:39 AM
    #1325
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    first make sure you're prewired for it. check and see if you have the ambient temp sensor in front of the radiator. I've read a few that it's pretty hard to hook one for 5 lugs. I might be wrong.
  6. Nov 6, 2012 at 11:45 AM
    #1326
    adio
    HI
    so do you have the ambient temp sensor?(looks like this. pic below). is the temp/compass gauge you just installed from an 05-08 Tacoma? only 05-08 temp/compass are compatible for 05-08(makes sense). 09-above is different
    D9A1AAF3-C37C-4797-93C9-63AFCA78297A-483_2f3a9d8dad5e47bc6203e8ccb442be8f588d3470.jpg
  7. Nov 6, 2012 at 1:54 PM
    #1327
    MMAN412
    MMAN412 Well-Known Member
    Fruit Cove, Florida
    07 dbl cab
    bull bar, custom Got Duals w/ 4in tips, off road lights, general gabbler AT2 tires, cb with whip, 100w pa system, 3in Procomp Suspension
    im in Jax, Fl. i've been to Radio shack ( along with other stores) and nobody seems to have the correct resistor. the 510 seems like its impossible to find. Where did yall get yours at? online? I've been w/o it now for about 5 months. i just can't take it any more. Thanks
  8. Nov 6, 2012 at 4:18 PM
    #1328
    Sandy sangha
    Sandy sangha Member
    Sandy
    Vancouver
    08 Tacoma trd 4x4
    i have a problem with my mine same thing the compass works but the temp shows --- its the symblo for celsius and farhen but no number on screen just the 3 lines any suggestions
  9. Nov 6, 2012 at 4:20 PM
    #1329
    Sandy sangha
    Sandy sangha Member
    Sandy
    Vancouver
    08 Tacoma trd 4x4
    ya compass works fine i will check and see if the sensor is there for temp
  10. Nov 6, 2012 at 4:23 PM
    #1330
    Sandy sangha
    Sandy sangha Member
    Sandy
    Vancouver
    08 Tacoma trd 4x4
    but the compass works fine dont know what year it was taken out from but the compass should not work either if that was the case
  11. Nov 6, 2012 at 6:14 PM
    #1331
    adio
    HI
    Sandy sangha- you might want to check the 510 resistors inside the gauge
  12. Nov 6, 2012 at 9:40 PM
    #1332
    CINER
    CINER Active Member
    Cindy
    Fresno, CA
    Tacoma TRD Off Road 4WD
    The dealer has my truck AGAIN (7th time) for this problem..they are leaning in the direction of the wire harness.....
    Good Luck with yours!
  13. Nov 10, 2012 at 5:56 AM
    #1333
    tacomike36
    tacomike36 Member
    mike
    canada
    08 TRD Off Road
    tint
    So mine stopped working the other day. It literally took me longer to find and read the thread then it did to do the repair! Thank you very much this is a great write up. The 510 resistor was not only broken on one side but had actually popped right up and away from the board almost like a breaker would do lol.
  14. Nov 10, 2012 at 7:45 AM
    #1334
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    If you're looking for the chip resistors they're difficult to find... you should be able to find some carbon film 47 ohm resistors like in this post http://www.tacomaworld.com/forum/2nd-gen-tacomas/18497-overhead-compass-temp-fix-65.html#post5708183. Good luck.
  15. Nov 12, 2012 at 3:35 PM
    #1335
    MMAN412
    Fruit Cove, Florida
    07 dbl cab
    thanks for the advice man. going to try this asap. will post back with the results!
  16. Nov 16, 2012 at 7:44 AM
    #1336
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    I posted in this thread back in Sept after re-soldering my 510 chips, I did the same on my inlaws 06 as well. Two months later they were both out again.
    I did mine right this time, got rid of the 510 and replaced with two 51ohm 1/4w resistors. They were $4 for a package of 4 at my local electronics shop so I have enough to fix my Inlaws again too. :D
  17. Nov 17, 2012 at 9:57 AM
    #1337
    MMAN412
    Fruit Cove, Florida
    07 dbl cab
    Thanks Deviltaco and 478dblsport for the great advice on the accessory meter! working great!
  18. Nov 17, 2012 at 10:35 AM
    #1338
    478DblSport
    Byron, GA
    :thumbsup: That's what we're here for.
  19. Nov 21, 2012 at 11:38 AM
    #1339
    WhoreHey
    WhoreHey Active Member
    Jorge
    Yorba Linda
    06 DC SB PreRunner TRD Off Road
    just getting started : (
    Question... I was missing 1 - 510 resistor, so tried to fix it as shown on page 65 with only 2 - 1/4 watt, 47ohm resistors and it didn't work. So I added the 1 - 510 resistor I had left on top of the 2 - 47ohm resistors and it worked... is this safe, it felt pretty hot so I just want to be sure it is ok this way??
  20. Nov 21, 2012 at 2:16 PM
    #1340
    478DblSport
    Byron, GA
    Hmmm strange... Are you sure your 47ohm R's are "bridged" across the 4 contact pads of the circuit board & not just 2 of the pads? Then when you "bridged" the 510 across the top 2 pads you completed the connection? Sorry, I'm just trying to figure out what you got... How about a picture?
